The version 2.3.3 and I've tried every rooting option I have, I don't know if it's my computer, or I'm just retarted...will someone PLEASE help me:/
Are you on zvh or zvj? Which rooting methods have you tried?
This will root you no matter what baseband you are on, but you still need to check if you have zvh or zvh first so you know where to start: http://forums.androidcentral.com/showthread.php?t=166929
Well, first, I used the optiauto one, and it didn't connect to my phone, like it kept saying "waiting for phone to connect" :/ and I use a Toshiba laptopFirst of all we need you're baseband and problem you're having then we can help
I think so I'm not sure...but it said it did.
The zvj upgrade/root only works if you are already rooted. So, if you have zvh run option A then option B to achieved rooted zvj. If you have zvj via sprint, then downgrade first to zvd and root that, then run option B. either way root is required to do option B.
Bleh...it didnt downgrade...I don't understand what I'm doing wrong... D:
