Results 1 to 19 of 19
- 05-07-2012, 06:34 PM
Thread Author #1
- 05-07-2012, 06:40 PM #2
- 05-07-2012, 06:56 PM #3
Re: need help with roting mvj
if it is of any help I think ZVJ = to MVJ, someone feel free to correct me if I'm wrong
- 05-07-2012, 08:27 PM #4
Yes, zvj and mvj are the same thing.
Have you tried this thread?
[How-To] Automated Rooting of LS670ZVD/ZVH/ZVJ - 05-07-2012, 09:11 PM #5
- 05-07-2012, 09:26 PM
Thread Author #6
- 05-07-2012, 09:35 PM #7
Did you have the correct drivers installed?
Sent from my LS670 using Tapatalk 2 - 05-07-2012, 10:30 PM #8
- 05-15-2012, 06:01 PM #9
- 05-15-2012, 06:17 PM #10
Use this thread.
http://forums.androidcentral.com/sho....php?p=1314752Thanked by: - 05-15-2012, 06:26 PM #11
- 05-15-2012, 06:36 PM #12
- 05-15-2012, 06:57 PM #13
Also make sure you have the stock rec installed. It's the first thing mentioned on that thread. If you have xionia you'll have to run update twice (if i remember correct). that way stock recovery is installed (first run) then the radio will be flashed for service purposes (second run).
also make you choose the update from sdcard option in recovery, because as was already mentioned it sound as though you factory reset your lg and make sure when you place the update.zip on your sdcard that its update.zip not update.zip.zip. and make sure its not in any folders on the sdcard (root of sdcard), so if you downloaded it using your phone, move it out of the downloads folder.Last edited by czifro; 05-15-2012 at 07:05 PM. Reason: made changes
- 05-15-2012, 07:16 PM #14
ok tried it again and nothing, i\I downloaded the update.zip file to my pc then transferred it to my SD on my phone, When i went to update the update.zip my phone could not find it. Am i putting the update zip file somewhere wrong?
sorry if i dont make any sense
- 05-15-2012, 07:21 PM #15
- 05-15-2012, 07:25 PM #16
- 05-15-2012, 07:26 PM #17
- 05-15-2012, 07:34 PM #18
- 05-15-2012, 07:38 PM #19
Reply
