Results 1 to 9 of 9
- 06-04-2012, 12:35 AM
Thread Author #1
ZVD to ZVJ errors using optiauto-sfx
Im rooted. ZVD. Stock recovery.
Copying files for next stage (may take a few minutes)...
push: copy2sd-zvj/update.zip -> /sdcard/update.zip
protocol failure
Rebooting
If it takes LONGER than 60 seconds to initiate reboot
manually reboot using
POWER button to power OFF, then POWER+VolDwn+HOME
If your phone boots into Android instead of Recovery
please REPEAT the most recent step
Rebooting to Recovery... error: device not found
Done
Any idea want could be wrong?Last edited by IcerC; 06-04-2012 at 01:36 AM.
- 06-04-2012, 01:34 AM
Thread Author #2
Re: ZVD to ZVJ errors using optiauto-sfx
rooted.... Xionia Custom Recovery
push: copy2sd-img/000root/recovery_vj.img /sdcard/000root/recovery_vj.img
6179 KB/s (5341184 bytes in 0.844s)
Installing Recovery - Stock VJ...
---- END LOG ----
Check for any errors. Assuming there are none, recovery flash was SUCCESSFUL.
error: device offline
Rebooting
Rebooting to Recovery... error: device offline
Done
Activity complete - review status logs above if needed
Press any key to continue . . . - 06-04-2012, 05:22 AM #3
Do you have lg drivers installed? Is USB debugging on?
"I drank what!?!?!" ~Socrates
"Man is the lowest-cost, 150-pound, nonlinear, all-purpose computer system which can be mass-produced by unskilled labor." ~NASA, 1965
New users, click here!!
Sprint Sammy GS3 | MB1 | Wicked Sensations JB v2.1 | TWRP 2.4.3.0 - 06-04-2012, 09:40 AM
Thread Author #4
Yes and yes.
I tried uninstalling the drivers, restarted and used ccleaner and reinstalled. - 06-04-2012, 09:40 AM #5
Did you make sure to keep the screen on during the process? Not doing that gave me that error once.
- 06-04-2012, 10:14 AM
Thread Author #6
yeah I did that too.
Going to try the manual method. - 06-04-2012, 10:18 AM
Thread Author #7
push: copy2sd/000root/misc.img -> /sdcard/000root/misc.img
push: copy2sd/000root/install-unroot.sh -> /sdcard/000root/install-unroot.sh
push: copy2sd/000root/install-root.sh -> /sdcard/000root/install-root.sh
push: copy2sd/000root/install-recovery-xionia.sh -> /sdcard/000root/install-reco
very-xionia.sh
push: copy2sd/000root/install-recovery-xionia-misc.sh -> /sdcard/000root/install
push: copy2sd/000root/install-recovery-vj-misc.sh -> /sdcard/000root/install-rec
overy-vj-misc.sh
push: copy2sd/000root/install-recovery-vd.sh -> /sdcard/000root/install-recovery
-vd.sh
push: copy2sd/000root/install-recovery-common.sh -> /sdcard/000root/install-reco
very-common.sh
push: copy2sd/000root/install-misc-common.sh -> /sdcard/000root/install-misc-com
mon.sh
push: copy2sd/000root/install-cleanup.sh -> /sdcard/000root/install-cleanup.sh
push: copy2sd/000root/install-cleanup-cache.sh -> /sdcard/000root/install-cleanu
p-cache.sh
push: copy2sd/000root/func.inc.sh -> /sdcard/000root/func.inc.sh
push: copy2sd/000root/flash_image -> /sdcard/000root/flash_image
push: copy2sd/000root/busybox -> /sdcard/000root/busybox
16 files pushed. 0 files skipped.
2171 KB/s (2482507 bytes in 1.116s)
5596 KB/s (5341184 bytes in 0.932s)
---- END LOG ----
Rebooting
Done
Press any key to continue . . . - 06-04-2012, 10:30 AM
Thread Author #8
did option a: root/install custom recovery. Everything went through.
Did get this error though:
error: protocol fault (status 43 6c 65 61?!)
Didnt seem to mess anything up in the process though - 06-04-2012, 10:49 AM
Thread Author #9
Ok did it. Here's how.
Factory reset from recovery.
Then wiped cache.
Then used option a (root zvd/zvh)
Then restarted computer
Then option b (root to zvj)
Thanks guys
Reply
