Results 1 to 6 of 6
- 06-24-2012, 12:02 AM
Thread Author #1
- 06-24-2012, 12:15 AM #2
Re: link2sd ext2 problem
You can try Mounts2SD, it has the same features plus more and it is easy to install... It works on ICS but I have never used it on GB so I don't know if it works on that, if that's the rom you are onNever mind my bad I though it was the same but it's not - 06-24-2012, 12:48 AM #3
- 06-24-2012, 01:07 AM #4
- 06-24-2012, 07:11 AM #5
You might want to try to put your question to the developer of link2sd. I have found that if I want to use a second partition app or script, I have to find one that works with the current rom on my phone, ie- I could use data2ext on cm7, but would have to use s2e on a different rom or dt's a2sd on yet another rom. I had to add all of the "support files" (the mkfs.ext4, the system/bin files and the system/lib files) on one rom just to get it to format correctly.
My point is that A) moving apps to second partition on the sd really isn't supported by the developers of our roms and 2) if you really feel you need the support, you'll probably have to figure it out yourself. The devs don't like it because it causes more problems than it's really worth. Too many variables have to change to make a rom support it and it becomes all too easy to break the rom. Plus, it has a proven record of data and physical degredation on the sdcard. And it's slower than nand memory, so it causes lag."I drank what!?!?!" ~Socrates
"Man is the lowest-cost, 150-pound, nonlinear, all-purpose computer system which can be mass-produced by unskilled labor." ~NASA, 1965
New users, click here!!
Sprint Sammy GS3 | MB1 | Wicked Sensations JB v2.1 | TWRP 2.4.3.0 - 06-24-2012, 02:25 PM
Thread Author #6
I figured it out, had to go back to an older nand backup... haven't had any problems with the sd becoming degraded so far... only reason I am using link2sd is that the internal app storage on this phone is ridiculous compared to phones that came out after this one... doesn't make sense why these phones have such small memory but now all the new ones have AT LEAST 8-16 gigs of internal storage lol
Sent from my LS670 using Android Central Forums
Reply
