Figured that since we've been having more than a couple people with ROM Manager problems, I'd post a how-to about using GooManager instead.
Like the rest of the flashing threads, I reiterate...
If you have ROM Manager installed, Remove it now. Our phone is not supported and it bricks our handsets.
How to Flash a ROM with GooManager (Already on SD Card):
You need to know the Dev's Goo.im name to find ROMs currently. For instance:
(Only pick the LS670 versions for the Optimus S, VM670 for Optimus V, etc.)
I hope this helps people and helps GooManager eventually become the defacto replacement for ROM Manager for our handset :3
- Start GooManager
- Press Flash ROMs
- If this is your first time using GooManager, click "I already have a supported recovery" (Or something to that extent, DO NOT hit Install Open Recovery Script)
- Press Add ZIp from another location
- Browse to your ZIP
- Press Order & Flash Selected
- Order your Zips (ROM First, Kernel Patches, GApps, then anything extra)
- If you want to create a backup, check Create Backup. Same with wiping cache/dalvik cache partition.
- Press Flash
- PROFIT!!!
- thekraven's CM9 - /devs/thekraven/
- Team Hydro (Cannibal Recovery is in there too) - /devs/TeamHydro
- Quattrimus Nightly - /devs/tdm/roms/quattrimus/LS670/
- Open GooManager
- Tap Browse all files
- tap devs
- Find the developer you want to download ROMs from (using the list above)
- Find the ROM for your device (such as alpha16d-cm9-20120626-kraven-LS670.zip) and tap it.
- Once the download completes, go back to the main menu of GooManager and hit Flash ROMs.
- It will appear in the list of ZIPs to flash, make sure it's checked along with any addons (Kernel, GApps, etc)
- Choose the order of installation for the ZIPs (Recommended order: ROM, Kernel Patches, GApps, extras like SD-Ext mods)
- Check Wipe cache/dalvik cache partition (and Create Backup if you want it to create a nandroid for you)
- Hit Flash
- Follow the on-screen prompts.
- PROFIT!!!
