Page 3 of 7 FirstFirst 123456 ... LastLast
Results 51 to 75 of 155
Like Tree11Likes
  1. Thread Author  Thread Author    #51
    Default Re: [ROM][WIP][PORT]Paranoidandroid from optimus one to optimus s
    im going to upload the rom now
    Thanked by:
    ShadowEO and wormy987123 like this.
  2. #52
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Quote Originally Posted by beachkid View Post
    A new build??? Wats fixed
    Looking for good cm9 or cm7 themes??? visit this site for good themes.
  3. Thread Author  Thread Author    #53
    wifi,root,paranoid settings
    and i think mic
  4. #54
    xplode196's Avatar
    Posts
    ROM
    FreeGS3
    Hey, just a suggestion, it'd be extra nice if the date the ROM was last updated was in the title of the thread, so people knew when you came out with a new release. Just a personal preference of mine to make the thread cleaner
    Remember to "Thank" people who help you out!
    Thanked by:
  5. #55
    ShadowEO's Avatar
    Posts
    ROM
    Drew's CM10
    After fixing the symlinks, paranoid settings works fine. :3 Or is that already fixed? 0-0
    Might wanna add some changelogs to the OP.
    Also, this isn't a stock based ROM, so I would recommend removing any APKs related to GApps and place a link to the Goo.im gapps package (Yes, there are APKs related to GApps, even ones that Gapps itself installs in /system/app)
    Using Alpha 2 btw.
    Home button (Soft/Hard) still does not work. along with Search, Camera and Voice Dial.
    EDIT: Also anyone know a good DPI to run Aldiko with? I tried all the settings and the book text still comes out horrible.
  6. #56
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Still gotta wait for 3g bro how close is it
  7. #57
    wormy987123's Avatar
    flashaholic
    Posts
    Global Posts
    392 Global Posts
    ROM
    Stock for now
    Default
    I think its already up there is a beta 2 in the op
    Sent from my LG-LS670 using Tapatalk 2
  8. #58
    drewwalton19216801's Avatar
    Posts
    ROM
    HydroROM
    Default
    Quote Originally Posted by jonny5449 View Post
    Patience is a virtue. That is all.
    Thanked by 2:
  9. #59
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Quote Originally Posted by drewwalton19216801 View Post
    Thx drew........ I have been known to be impatient lol
  10. #60
    Default
    So just outta curiosity in the original paranoid android thread it says something about auto screen Res? Does this mean it'll run games better without screen size issues?
    Or hopefully anyway.....
    Sent from my LS670 using Android Central Forums
  11. #61
    ShadowEO's Avatar
    Posts
    ROM
    Drew's CM10
    Quote Originally Posted by vernotzy21 View Post
    Hopefully that gets fixed, when I was trying to read a book in Aldiko I couldn't get the words to appear right in any DPI. Switched back to Kraven and the books read fine.
  12. #62
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    When my s gets disconnected from sprint this will be my new daily because of stability and it feels like a real tablet
  13. #63
    Default
    Quote Originally Posted by ShadowEO View Post
    Yeah me too its the #1 thing about this rom 2nd would be the tablet ui I'm a full time wifier so it'd be perfect:thumbup:
    ....so long as flash works people say flash sucks on os but I have no complaints
  14. #64
    ShadowEO's Avatar
    Posts
    ROM
    Drew's CM10
    Default
    I saw an APK for ICS flash on here but most of those are really 10.2 or 10.3 (Which does not work properly, if at all, on ICS)
    Whether flash does or doesn't work though is not a problem for the ROM developer though, It's a problem for Adobe.
    Sent from my LG-LS670 using Android Central Forums
  15. #65
    kylemaguire's Avatar
    Resident Teen
    Posts
    ROM
    Quattrimus
    Default
    Well adobe is done with flash on Android so its all good.
  16. #66
    Default
    IV heard that before how could that be?!
    What would we use to stream video
    Like and such flash is important to the end user
    However I have no complaints if they or someone does something new/better
  17. #67
    Default
    Does data work on this rom? Because if not, I know exactly why.
  18. #68
    ShadowEO's Avatar
    Posts
    ROM
    Drew's CM10
    Default
    Flash is only important to the end user because people make it so, however, Video player apps on Android do not rely on flash and most sites are switching to HTML5 for cross platform mobile video supporting both Android and iOS.
    Also, I don't think data works, but then again I can't test it because of how I use the handset like a minitablet with no service.
  19. #69
    Default
    Ill have to disagree with you though because 90% of streaming content is still based on flash when I heard adobe was discontinuing flash I was like WTF!!!
    I like html5 better but all my favorites are still flash so I guess I'm biased
    I don't think data is working either
  20. #70
    ShadowEO's Avatar
    Posts
    ROM
    Drew's CM10
    Default
    Found a replacement for Aldiko for this ROM, Try Moon+ Reader, you'll have to get it from their website though as it doesn't show in the market.
    EDIT: Build prop needs modified as the phone is showing as a P500
    Sent from my LG-P500 using Android Central Forums
    Thanked by:
  21. #71
    xplode196's Avatar
    Posts
    ROM
    FreeGS3
    I LOVE MoonReader +!!! Such a good alternative to Aldiko
    Thanked by:
  22. #72
    ShadowEO's Avatar
    Posts
    ROM
    Drew's CM10
    Default
    Quote Originally Posted by xplode196 View Post
    First time I tried it and I have to agree. I'll upload a LS670 build prop soon.
    EDIT: Here's a LS670 build prop that uses parts of Kraven's CM9 build prop. Just take off the .txt extension and push it to /system/
    You'll want to clear the cache/data of the Play Store and restart though.
    Attached Files Attached Files
  23. #73
    Default
    Yes. Use CAI build.prop and data should work fine.
  24. #74
    ShadowEO's Avatar
    Posts
    ROM
    Drew's CM10
    Default
    Quote Originally Posted by ThatGuyLurkin View Post
    I just modified the ROMs build.prop with some values from kraven's :-). Works great now
    EDIT: OP, Rom works great. The reason there's no 3G or Mobile Network (or calling with the SIP stack) are because you used a GSM-based ROM on a CDMA-based Base Rom. Port from a CDMA based ParanoidAndroid and everything should be working perfectly, it would even stop the force-closes we're getting. (If your no longer updating this ROM, can I ask how you ported it?)
  25. #75
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Wait so it has tablet ui and most things working???
