thewraith420
Why is there an MMS.apk in the ZVD ---> ZVJ zip? It broke SMS on CM7 and MIUI, and I spent about an hour trying to figure out why my phone didn't like showing the MMS.apk on the homescreen... until I figured out it was this zip. xD
Well.... If it were for the OV I'd call it a failed attempt at fixing mms but I would assume on the s there would be no need at all.... You should be able to remove it from the zip with 7zip and disable signatures in recovery to flash
Tapatalk'n it from my VM670 running LS670ZVJ Dante Rom
