To fix the mms problem on a rom optimized for the optimus v can we just switch out the mms.apk file with one that works on our phone?
lol.. my bad man, thanks for clarifying... to answer your question:
Also some build prop edits
Virgin Mobile needs to be Sprint
And 311490 needs to be 310120
That's for cdma-home-operator-alpha and numeric
Edit: I'd also replace them anywhere else mentioned in the build prop
Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ baseband
Puild.prop is in /system of your ROM. Open it with notepad++ to make edits
If I change these things on the build.prop settings thing do I still have to change out the mms.apk for another that works with the OptiS?
