1. williek113's Avatar
    To fix the mms problem on a rom optimized for the optimus v can we just switch out the mms.apk file with one that works on our phone?
    10-12-2012 10:42 PM
  2. williek113's Avatar
    I meant for any optimus v rom, not the ones u made for the optimus s
    clodfelterac likes this.
    10-13-2012 12:13 PM
  3. williek113's Avatar
    lol.. my bad man, thanks for clarifying... to answer your question:
    I switched the apks and the messaging app worked i just couldnt get mms
    10-13-2012 06:48 PM
  4. thewraith420's Avatar
    Also some build prop edits
    Virgin Mobile needs to be Sprint
    And 311490 needs to be 310120
    That's for cdma-home-operator-alpha and numeric
    Edit: I'd also replace them anywhere else mentioned in the build prop
    Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ baseband
    10-14-2012 05:22 AM
  5. williek113's Avatar
    Where do i get the file for the build prop or whatever cause ive never messed with that before
    10-14-2012 02:19 PM
  6. hlxanthus's Avatar
    Puild.prop is in /system of your ROM. Open it with notepad++ to make edits
    Sent from my Nexus S 4G using Tapatalk 2
    Buddlespit likes this.
    10-14-2012 02:39 PM
  7. Buddlespit's Avatar
    ...And ONLY notepad++. The regular notepad shipped with windows doesn't support the format that most of the editable files (in android) use.
    10-14-2012 04:52 PM
  8. hlxanthus's Avatar
    ^exactly
    10-14-2012 05:49 PM
  9. thewraith420's Avatar
    I've edited mine using es note editor from my phone before lol
    A-android-B likes this.
    10-14-2012 06:05 PM
  10. williek113's Avatar
    Ik I have notepad++
    Sent from my LG-LS670 using Android Central Forums
    10-15-2012 12:04 AM
  11. williek113's Avatar
    If I change these things on the build.prop settings thing do I still have to change out the mms.apk for another that works with the OptiS?
    10-16-2012 05:21 PM
  12. thewraith420's Avatar
    Not sure... I would just so you know if it's not working its not the apk. What rom are you trying for anyway? If it's cm7 EarthnFire78 just released for LS670
    10-16-2012 05:58 PM
  1. Fixing Virgin MMS for ported roms
    By LeslieAnn in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 12-31-2012, 03:56 PM
  2. MMS Problems - Bionic on Eclipse Rom
    By alexdayga in forum Droid Bionic
    Last Post: 04-23-2012, 04:08 PM
  3. [FIX] Problems with MMS on IHO Roms
    By anthonycr in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 03-12-2012, 12:09 AM
  4. Switch keyboard on Desire ROM?
    By tedstien in forum Google Nexus One Rooting, ROMs, and Hacks
    Last Post: 03-01-2010, 07:40 PM
  5. not receiving mms on my droid
    By todd09 in forum Motorola Droid
    Last Post: 12-12-2009, 01:43 PM
