Please help,stuck in recovery !
Hey guys ok heres what happen LG OPTIMUS V I rooted it everything worked great,I think my brother did a factory reset while rooted,now I cant turn my phone off !! every time it starts back up it goes into the recovery, I see the android recovery screen but I can not chose any options it just resets all and I lose everything ! any help would be great guys
Re: Please help,stuck in recovery !
What recovery are you using?
Sent from my Full Android on Crespo4G using Tapatalk 2
Just wipe and restore the last nandroid backup you made.
what I mean is when the phone comes back on it starts the recovery phase,but I cant pick no options then it just starts up but its back to factory. nadroid ?
Nandroid aka backup hopefully done before new rom install.
Is it a constant boot loop? Are you able to select any options in recovery?
Sent from my LG-VM670
nope no options...just restarts and I have no back up, I was playing around with ginger break next thing I knew it was rooted..then my brother did a factory reset...hope u guys can help,thank u very much
Since it sounds like you have an Opt V, try the stickies in the Opt v forum. Here us a link to hopefully help get you started. Good Luck!!
[Only registered and activated users can see links. Click Here To Register...]
[GUIDE] Unbrick/Upgrade Optimus V [EASY] [KDZ]
THANK YOU..anyone have any ideas please let me know
Sounds like you have the stock recovery still
You need to get a custom recovery installed
Im pretty sure there is a guide to use the update from zip option
I‘ll look for a link
When you are in recover the volume buttons move your cursor and camera selects
Actually watch the video and follow the directions
[GUIDE] Unbrick ANY Soft Bricked Optimus V/Return to ZV5 Stock
