Results 1 to 10 of 10
    Default Please help,stuck in recovery !
    Hey guys ok heres what happen LG OPTIMUS V I rooted it everything worked great,I think my brother did a factory reset while rooted,now I cant turn my phone off !! every time it starts back up it goes into the recovery, I see the android recovery screen but I can not chose any options it just resets all and I lose everything ! any help would be great guys
  2. #2
    hlxanthus's Avatar
    Posts
    ROM
    RasbeanJelly/DanteRom v4
    Default Re: Please help,stuck in recovery !
    What recovery are you using?
    Sent from my Full Android on Crespo4G using Tapatalk 2
  3. #3
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Paranoid Android / CM7
    Just wipe and restore the last nandroid backup you made.
    If you are inclined to spend a lot of money and want a pretty trophy with which to pass the next few years of your life that talks to you in a condescending voice, can't navigate to save its life, expects full control over all you do, demands $13 for a $3 purchase, allegedly has a single recessed button, needs an expensive computer and a credit card to do anything, hates your music and has purses designed just for it...
    Get married to someone you hate... or get an iPhone.
    New to LG's premium Android phone? Check out the Optimus S Welcome Guide.
    Used ROM Mangler on your Optimus S and having problems? Try this.
    what I mean is when the phone comes back on it starts the recovery phase,but I cant pick no options then it just starts up but its back to factory. nadroid ?
  5. #5
    bkttk2's Avatar
    Posts
    ROM
    Stock
    Nandroid aka backup hopefully done before new rom install.
    Is it a constant boot loop? Are you able to select any options in recovery?
    Sent from my LG-VM670
    nope no options...just restarts and I have no back up, I was playing around with ginger break next thing I knew it was rooted..then my brother did a factory reset...hope u guys can help,thank u very much
  7. #7
    bkttk2's Avatar
    Posts
    ROM
    Stock
    Since it sounds like you have an Opt V, try the stickies in the Opt v forum. Here us a link to hopefully help get you started. Good Luck!!
    [GUIDE] Unbrick/Upgrade Optimus V [EASY] [KDZ]
  8. Thread Author  Thread Author    #8
    THANK YOU..anyone have any ideas please let me know
  9. #9
    Sounds like you have the stock recovery still
    You need to get a custom recovery installed
    Im pretty sure there is a guide to use the update from zip option
    I‘ll look for a link
    When you are in recover the volume buttons move your cursor and camera selects
  10. #10
    Actually watch the video and follow the directions
    [GUIDE] Unbrick ANY Soft Bricked Optimus V/Return to ZV5 Stock
  1. HELP! Stuck in Recovery & home screen is unresponsive
    By 627gigi in forum Sprint Epic 4G
    Last Post: 06-27-2012, 10:58 PM
  2. PLEASE HELP! Stuck in CWM Bootloop
    By IDontHack in forum LG Optimus S
    Last Post: 05-05-2012, 07:27 AM
  3. help please! stuck in recovery!
    By xnadira in forum Droid Charge Rooting, ROMs, and Hacks
    Last Post: 11-23-2011, 02:31 PM
  4. Please help! im stuck in recovery mode.
    By cusco in forum Verizon Droid Incredible
    Last Post: 09-24-2010, 04:01 PM
  5. Stuck in recovery - please help
    By levjoy in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 08-30-2010, 09:25 AM
