07-13-2015 05:16 PM
687 12345 ...
tools
  1. thekraven's Avatar
    Grab the vm fix from the slimrom and use those keypad changes. Swap or manually change. Make the six Virgin changes in the build.prop. Change any Ls670 to VM670. There's eri.xml changes too, but I don't want to mess with just yet. The frameworks change often.
    Another thing, I haven't seen any virgin stuff added to the smsdispatcher from cyanogen, so mms probably won't work.
    exProphecy likes this.
    01-02-2013 11:16 PM
  2. Shinkenred's Avatar
    Seems pretty awesome so far...loving that new clock on the lock screen!! (Though I *really* wish there were a way to make that a flashable zip...it looks infinitely better than the crappy lock screen clock of ICS & JB4.1...) I'll wait until the "Developer Options" and standard CM "Performance" settings are in before I make it my new daily...of course, I could just use a picture that has plenty of blue involved for a wallpaper, too. Looking forward to seeing what other awesome things you do with this ROM, thekraven!!
    01-04-2013 05:29 PM
  3. thekraven's Avatar
    The developer settings are hidden in cm10.1. Google the unlock method. ;-)
    Shinkenred likes this.
    01-04-2013 05:32 PM
  4. kcls's Avatar
    Does this ROM automatically move apps to the ext4 partition if there is one? Because I use my Optimus V for testing my play store stuff now which means there's a bunch of apps I need to install.
    Sent from my Paranoid Nexus 4 using Tapatalk
    01-05-2013 02:54 PM
  5. Shinkenred's Avatar
    Awesome info. Pretty clever of them!!
    Sent from my Purple LG-LS670 running CM10...for now.
    01-07-2013 05:00 PM
  6. thekraven's Avatar
    New build up
    Changelog for build A23
    • camera works
    • youtube onscreen controls fixed
    01-08-2013 11:02 AM
  7. ny355145's Avatar
    Looks great, does mms work with virgin?
    01-08-2013 01:33 PM
  8. exProphecy's Avatar
    does this have performance options? I think the last build I tried didn't yet
    01-08-2013 03:13 PM
  9. thekraven's Avatar
    They are there, but hidden, you need some special snes unlock codes
    01-08-2013 03:19 PM
  10. jasonevil's Avatar
    UP UP DOWN DOWN LEFT RIGHT LEFT RIGHT B A START
    lol
    Axe, Shinkenred and dmc5110 like this.
    01-08-2013 10:57 PM
  11. Compeek's Avatar
    First of all, thekraven, you are the best! I can't believe the Optimus S/V is still getting the most recent Android updates because of people like you. I was discouraged that BobZhome and TDM both seemed to have stopped working on their ICS/JB ROMs for the Optimus V, but then I found your Cold as Ice ICS one and have been using it for a month or so, and now I see that this one is already coming along well!
    Anyway I installed this ROM on my Optimus V today with the Virgin Mobile fix and the provided Google Apps package, but Wifi won't work, and Bluetooth doesn't seem to want to work, either. The Wifi slider in Settings is grayed out, and clicking on Wifi makes it say it's turning on, but nothing happens.
    MMS also doesn't work, but that's already known and expected.
    I already went back to CAI for now because I need my phone to work, but I'm looking forward to trying this one again once it's more ironed out.
    01-09-2013 04:58 AM
  12. plantucha's Avatar
    Confirming. WiFi and Bluetooth doesn't work on Virgin.
    01-09-2013 05:10 AM
  13. thekraven's Avatar
    See if wifi works without the virgin patch. Or try reflashing CAI kernel test 38, test 23, or test 21.
    01-09-2013 05:29 AM
  14. jonny5449's Avatar
    OMG THANKS FOR THIS!!!!
    Sent from my LG-LS670 using Tapatalk 2
    01-09-2013 07:49 AM
  15. lerxst_x's Avatar
    Thanks for the ROM...seems like GPS is not working.
    Sent from my LG-LS670 using Android Central Forums
    01-09-2013 04:25 PM
  16. plantucha's Avatar
    All tested. Wifi is still broken. First flashed ROM without Virgin +dalvik wipe , next 21 then , 23, 38. Back Virgin patch. In any case is Wifi slider in settings is grey and it forever says "turning wifi on".
    01-09-2013 07:00 PM
  17. thekraven's Avatar
    Did you do a full wipe of system, data, dalvik, and cache before the first flash? And which recovery? Don't restore wifi setting from titanium backup.
    Try manually deleting with a root file explorer the file /data/misc/wifi/wpa_supplicant.conf then reboot.
    I probably uploaded the wrong build. I'll double check.
    I think i found it, it's something in the ramdisk. I'll try to get a patch going later tonight. On a clean install wifi is borked, but if you dirty flash over build 17 wifi will work.
    01-09-2013 07:17 PM
  18. jonny5449's Avatar
    Loved feel but couldn't use
    Wi fi didn't work
    Kinda lagged too much for my taste
    01-09-2013 08:02 PM
  19. thekraven's Avatar
    The wifi problems have something to do with the wifi region code settings they just added to cm10.1. It's stuck on Europe, i'll try to fix the default.
    01-10-2013 01:42 AM
  20. jonny5449's Avatar
    OK and lag I suppose is because ur using ported code or something like that
    01-10-2013 05:42 AM
  21. thekraven's Avatar
    Temp fix for wifi on the newer builds... First flash build 17 or 23. Then let it boot. Setup wifi. Then reboot to recovery. Wipe cache and system, then install build 24 and gapps.
    flapjack.fiasco likes this.
    01-10-2013 06:05 AM
  22. thekraven's Avatar
    Found the wifi problem. The init.d scripts for sdext. Remove the 05mountsd and 40a2sd from the zip and do a clean install. You can add the scripts back later if you choose.
    01-10-2013 06:35 PM
  23. lerxst_x's Avatar
    Anybody have GPS working?
    01-10-2013 10:38 PM
  24. plantucha's Avatar
    No. Gps doesn't work. Also speed is 50% of ics. But it is alpha build. It will get better eventually.
    jonny5449 likes this.
    01-11-2013 12:17 AM
  25. Shinkenred's Avatar
    Radio works? Strange...not that it matters for me, but it indicates the baseband as "Unknown" instead of showing the specific radio. But since camera works now, ooooh...can't wait to reload my nand (of A17) and flash the new version!!
    01-11-2013 05:52 PM
687 12345 ...
  1. [ROM][CM10][JB] Euroskank JellyBro
    By tcapote in forum Verizon Galaxy Nexus Rooting, ROM's, and Hack's
    Last Post: 06-13-2013, 05:53 PM
  2. Thinking about Flashing to the CM10 JB Rom... 2 questions first
    By Azwizzard in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 10-15-2012, 01:21 PM
  3. [ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
    By Dark_Knight2 in forum Epic 4G Touch Archived ROM's and Hacks
    Last Post: 08-25-2012, 12:10 PM
  4. [ROM][AOSP][CM10][JB][7/25]Unofficial Official Cyanogenmod
    By SeigaGen in forum Verizon Galaxy Nexus Rooting, ROM's, and Hack's
    Last Post: 08-04-2012, 03:58 PM
  5. Desire ROM ported to the N1 (Alpha 10 now Live)
    By edoublediz in forum Google Nexus One Rooting, ROMs, and Hacks
    Last Post: 03-10-2010, 08:32 PM
