Page 25 of 28 FirstFirst ... 22232425262728 LastLast
Results 601 to 625 of 687
Like Tree198Likes
  1. #601
    inceyet's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MIUIgb
    Default Re: [ROM]CM10.1/PAC-rom jb 4.2.2 The JBC alpha build
    Sorry for off subject but i need the device driver for lg optimus v device driver ...greatly appreciated ....again sorry for off subject thnx
    Sent from my LG-VM670 using AC Forums mobile app
  2. #602
    brotherswing's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Xperion
    http://www.mediafire.com/?k32ry12777pvg9a
    Here you go!
    inceyet likes this.
  3. #603
    Kevin DeBauch's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by thekraven View Post
    When I flash these two files, it causes my phone to freeze at the LG screen when booting. It does not get any further. I am not sure which file is causing the problem, but was hoping someone may have had a similar issue and could help me figure this out! I flashed PAC_JB_4.2.2-v22.0.1_20130414-042136, then the Newer JB 4.2 gapps from KonstaT, then the Virgin.fix4.3.0kernel.jbc-CM10.1 and finally the gpsfix3.theJBC. If I flash just the ROM and Gapps, everything works alright, though it does seem to be a little unstable!
    Thanks for any help, I have read a fair bit of the posts in this thread, but must admit I have trouble following some of it.
  4. #604
    fortyquid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Anybody else having trouble with the Maps update from last month? When I updated to 7.x Maps became unusable. Uninstalled. Sideloaded 6.9. Anybody successfully using 7.x on this ROM?
  5. #605
    ppossumm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I went from PAC to the new kravenCM10.1(7/15) and very happy with the switch. No random reboots, faster, smoother and reliable enough for the daily driver(so far). I just could not find a winning combo to stick with the PAC.
    EDIT: I switched back to PAC with clean install and life is better-- The battery drain on JBC is ridiculous. Ignore the rest of the post
    Two lil' issues:
    Virgin Fix has my home key and menu key switched. I would like the home key to be 'home' and the menu key to be 'menu'
    I was going to play around and try a new PRL but the QPST will not recognize the phone on COM on Device Manager>USB Controllers. I switched to my backup of PAC to make PRL changes but, still, this ROM is not recognized as LG or Android, just 'USB mass storage device'.
  6. #606
    kcire_eae's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hello I'm from mexico, I do not speak English and I liked the rom to android 4.2.2 but when I install the bluetooth works.
    ie when I turn it off no longer, or never turned on, and if it does I can not find devices.
    another thing is that my LS670 fuan activated and programmed in unefon (mexico) but I can not enter settings # # 778 # in any rom, not even on the stock rom, in this one I enter # # 3282 # # # 33284 # but not # # 778 #.
    the problem is that even in pac-rom I can get to these settings, try it with QPST but only says that we perform but when I restart everything is equal.
    well I hope ye meet, and hopefully very good job and exit one new version (rom)
  7. #607
    atrain2324's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    BobZ CM10
    Unhappy Re: [ROM]CM10.1/PAC-rom jb 4.2.2 The JBC alpha build
    Finally took the plunge with the 3.0.8 kernel and the new version of JBC.
    My thoughts:
    Smoother. Rebooted itself once, maybe its because it was shoved in my pocket and it was warm outside. RAM management seems to be much much better. hopefully leading to less force closes over time. Snappier with Crossbreeder than on previous builds. Also boots faster, PAC and previous builds took its sweet time.
    However, the battery bug is bothersome, but manageable. Have to put it to sleep and wake it up to get the accurate reading. Battery drain though is much more noticeable...on previous builds, unless I was doing some serious Spotify, I was hovering around 4-7% an hour with Friendcaster syncing every 15 minutes, my Falcon Pro (Twitter) syncing one account every 20 mins, Gmail on real-time sync on three accounts, Weatherbug Elite polling every hour and running Google Now...brightness set to 30% and sleep after 30 seconds.. With serious Spotifying, around 10-12% an hour tops.
    Now on the new build, I am around 8-12% an hour and I could literally be doing nothing, except allowing that background sync. Guess I have to carry at least two spare batteries on me at most times?
    UPDATE: This ROM is smooth, more fluid and reboots less on the 3.0.8 kernel...but the battery drain is way too much for me at this point...and with me going out of town soon, this phone would not last a car drive from Chicago to the northern suburbs of Detroit on one battery at all. Or maybe even two. I will keep an eye on the 3.0.8 thread on the OptiV root forum in the meantime for updates and improvement on the battery drain. Sorry!
    bigsupersquid likes this.
  8. #608
    bigsupersquid's Avatar
    o_O
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    bigsuperROM_os2sd
    battery bugs me too.
    I get pretty decent battery life as long as the 3g, wifi, and BT are off, though. over a day, mostly just light use of sms.
  9. #609
    atrain2324's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    BobZ CM10
    Quote Originally Posted by bigsupersquid View Post
    That's pretty much a non-starter for me with that...music journalist...if I am not behind my desk scoping the scoop, then I gotta be on my phone checking emails and social media...
  10. #610
    o_O
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    bigsuperROM_os2sd
    Quote Originally Posted by atrain2324 View Post
    I get longer life without gapps installed (that background sync bites) but that probably wouldn't suit your needs either. I'm not sure when I'll have time now to keep trying to fix it, working seven days a week really chews up one's free time when added to even online classes. I'd sure like to have at least the readouts working properly, not to mention having it detect the charger type correctly.
  11. #611
    atrain2324's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    BobZ CM10
    Understandable! Your particular kernel, I actually had Voice Search working on the 2.6 build (using the old one)...but on this one, it FCs, making the Utter! Beta useless...
  12. #612
    freddt2790's Avatar
    Posts
    Global Posts
    2 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    what radio im on slim right now zvd
  13. #613
    Eduardo Galvan's Avatar
    Posts
    Global Posts
    74 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Okay. I know it's late. I've reflashed this ROM again. (Paranoid Android & The JBC) Here's my pro/con list for this beta. (I won't be critical, don't worry.)
    Pros
    4.2.2, of course!
    Working 3G on BOTH ZVD/ VM's ZVJ
    You can install most JellyBean apps now.
    Instagram & YouTube video work perfectly! (You can record Instagram video too, just l a g g i l y.
    BigSuperSquid's kernel. It provides the MOST stability out of any I've flashed. Clocks fine @ 84x/86x on my OV.
    Do I need say more?
    Cons
    Battery drains fast, keep an extra battery, OR buy an extended battery. (I've assumed most of you already have.)
    Charger is NOT recognized on boot, due to kernel issues, so no updated charge status for you. (Just leave it plugged in, and it charges.)
    Since Jelly Bean is SO big, that you don't have a lot of room to work with. (Link2SD was my solution.)
    Expect some random reboots 'cause dis shat be crazy, dawg! (Seriously, what did you expect? A 2.2 phone running 4.2, smoothly?
    This is the end of my cons/pro list. I wasn't trying to be critical AT ALL, but I just listed a list.
    Shinkenred likes this.
  14. #614
    upconvert's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cold as Ice
    You can trade some of that clock speed for stability. I used to run at 600/749, and it was rock solid, and still pretty quick.
    thewraith420 likes this.
  15. #615
    Posts
    Global Posts
    74 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by upconvert;3051201[B
    ]You can trade some of that clock speed for stability. I used to run at 600/749, and it was rock solid, and still pretty quick.[/B]
    Yeah, I've tried those speeds. Right up until Instagram didn't like those clock speeds. Instagram froze the phone and rebooted. Each time I tried opening Instagram again, it would freeze and crash.
  16. #616
    Darkangels6sic6's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So far a very nice rom indeed. However listing in the description that it is a ZVD based ROM could've saved me some troubles. So used a nandroid to go back, found the patch, flashed it. Had cell phone again...but now I am facing the charger issue. I do think it charges in Recovery....but if the phone is dead that does me no good. I'm trying to get it enough charge to get into recovery and change roms. "What really sucks is I have a Venice, Optimus Dynamic, and this Iwireless Optimus S....Almost all smae sized/identical batteries.....But Only the Venice and Dynamic barely fit eachother. Why go through the trouble of making them all just the slightest bit different? At that rate they could've saved themselves mountains of money keeping them the same and making it drastically more simple for us."
    I like this one a lot, but it's not my phone. So I need to switch to ZVD or DanteROM. Until I can get back in recovery it only boots with charger plugged in and shuts right back down. Standard button combo for recovery then becomes useless.
    "edit" Ally battery fits, but will pop out without being held in place and reads as no battery.....
    "edit" Ally didn't charge the Optimus S battery either. Also cannot get ADB to interact either. So I cannot get their phone to turn back on at all....Yes my charger works. Yes the Phone charges. Yes the battery still has good health.
  17. #617
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well after letting the phone go through a reboot cycle it got stuck on the bootabination for a while. I figured it was charging so I left it there. Sure enough it finally charged some. Flashed to Dante. Hopefully after some future work this ROM IS Even better and charges zvj.
  18. #618
    chucklay's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Okay, so would anyone be able to point me in the direction of the best ROM/Kernel/other things to flash out there? Also, a guide on how to install Kernel stuff would be awesome, if someone could point me in the right direction there. Also, In terms of the data drops/3G disconnects, what would be the best way to avoid those? I've heard some speculation that it's due to 2SD scripts, but I'm not sure. I've used the EXT wipe tool that someone posted earlier.
  19. #619
    atrain2324's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    BobZ CM10
    Quote Originally Posted by chucklay View Post
    1. If you don't mind the slightly annoying bug in which your battery pct level doesn't change while charging or discharging unless you let your phone go to sleep, turn your screen off and then on...I suggest the 4/14 build of PAC (somehwere in this thread) and the latest Test 80 of bigsupersquid's 3.0.8 kernel. The battery drain is about the same with the original 2.6 kernel that is packaged with the ROM. However, the memory management is far much better and no random reboots (I am on 768/600 Interactive)! Data drops typically will not happen with this kernel as opposed to the one pre-packaged (hell the 3.0.8 kernel hooks on faster after a drop or made/answered call), but where I live, Sprint is in its 3rd and final stage of Network Vision deployment...
    2. How to install the 3.0.8 kernel? It is in the Optimus V thread and comes with a pair of keyswaps in case you have the OptiS. But the short of it is:
    a. download the Test 80 kernel, put it in root of your SD card (sure you know how to transfer things from your computer to sd card, yes?). For PAC, there's a ramdisk patch for it otherwise you get bootloop, download that to and get it on your sd card.
    b. reboot into your recovery.
    c. it is: pre-flash wipe (system, data, cache), wipe dalvik as well too. then flash PAC 4.14 BUILD. Then flash Gapps. Then flash the Pac ramdisk patch. Then wipe cache and dalvik. Then flash the 3.0.8 TEST 80 kernel. Then boot.
    d. After a reboot or two, you can flash the FIXED cronmod int2ext script. Obijohn's will bootloop the whole setup. However, after flashing, you'll need to reboot twice. Once for the script to boot...and again to refresh the data connection. Seems to bork it on the first reboot after flashing. Second reboot fixes it.
    glenesis likes this.
  20. #620
    classpro's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm having a hard time following this long threat (tried reading all the way through, but a lot of different stuff is going on), and am wondering if someone can point me in the right direction. I'm using Quattramus ICS, and I'd really like to install a functional JB rom on my optimus v. Is there a thread for installing one of these roms on the OV, and which one of the various versions is most stable at this point? Thanks.
  21. #621
    _alexkta's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by classpro View Post
    The newest jbc build with the new kernel
    Sent from my LG-VM670 using Xparent Cyan Tapatalk 2
  22. #622
    jamoosh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi all, Firstly, I just wanted to say thanks to the developer of this rom. This is really nice. I searched through the forum thread, and couldn't find it--so sorry if this is a redundant post--is there a fix for the battery charge not displaying?
    I've flashed most recent rom and gapps.
  23. #623
    thewraith420's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Changes Daily
    Try out the prior build with the 2.6.35 kernel. It's a kernel bug in the 3.0 kernel that hasen't quite been worked out yet.
    Sent from my VM670 using Tapatalk 2
  24. #624
    jamoosh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for your response.
    Would that be the file (a28-cm-10.1-20130220-thekraven-LS670.zip)?
    I was having a hard time finding it on the first screen.
    Does it require any patches be applied?
    Quote Originally Posted by thewraith420 View Post
  25. #625
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Changes Daily
    I like the pac rom builds, before the 3.0 kernel came out it was more up to date then JBC. I'd suggest giving it a shot and there is a patch for us VM670 users
  1. [ROM][CM10][JB] Euroskank JellyBro
    By tcapote in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 06-13-2013, 05:53 PM
  2. Thinking about Flashing to the CM10 JB Rom... 2 questions first
    By Azwizzard in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 10-15-2012, 01:21 PM
  3. [ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
    By Dark_Knight2 in forum Epic 4G Touch Archived ROMs and Hacks
    Last Post: 08-25-2012, 12:10 PM
  4. [ROM][AOSP][CM10][JB][7/25]Unofficial Official Cyanogenmod
    By SeigaGen in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 08-04-2012, 03:58 PM
  5. Desire ROM ported to the N1 (Alpha 10 now Live)
    By edoublediz in forum Google Nexus One Rooting, ROMs, and Hacks
    Last Post: 03-10-2010, 08:32 PM
