Page 28 of 28 FirstFirst ... 25262728
Results 676 to 687 of 687
Like Tree198Likes
  1. #676
    bigsupersquid's Avatar
    o_O
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    bigsuperROM_os2sd
    Default Re: [ROM]CM10.1/PAC-rom jb 4.2.2 The JBC alpha build
    I know this thread is stale but I just looked up something relevant to install on my wife's phone.
    pac4.3
    it's buried over in the cm-10-2-4-3-rom-3-0x-kernel thread.
  2. #677
    exProphecy's Avatar
    Posts
    Global Posts
    98 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cold.As.Ice CM9/Kernel 21
    My Epic 4G Touch died so I'm using this old guy again. What are you folks using for sd-ext mounting? I tried Cronmod the newest one but it wouldn't install correctly.. Anyone have experience with Mounts2SD?
  3. #678
    brotherswing's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Xperion
    I do, it's worked brilliantly on every Rom/handset combo I've tried it with (four different phones with about a dozen Roms ranging from GB to KK.) I have no problem giving it an enthusiastic recommendation.
    bigsupersquid likes this.
  4. #679
    Logan Lesley's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yes i've tried everything you just said
  5. #680
    TrikkJames's Avatar
    Posts
    Global Posts
    143 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Okay, I'm having a really hard time finding all the files necessary to install this.
    Someone please send me the *proper* links... Links I click here seem to be no longer working.
    *PAC-ROM or JBC, latest with compatible virgin fix, latest
    *Gapps
    *Edit*: No longer needed, disregard this post.
  6. #681
    CaptainPackers's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    can someone help me out here? this is a bit of a noob question. I've been having trouble getting my phone to boot any of the newer roms, ics or above. I just saw the comment by thekraven "older 2.6 kernels won't boot with this." I am running Harmonia 2.0 with a Kernel version 2.6.32.9-062112 mirage@aurora. now don't laugh, here comes the really noob question. Are you ready? Are you sitting down? ok here goes... isn't the kernel replaced when you flash a new rom? or am I going to have to flash a new kernel before I flash a new rom. I've never messed with kernels before. Landrew! Guide us!
  7. #682
    thewraith420's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Changes Daily
    What are you wiping when you do a clean install? To me it sounds like your leaving something out. List your steps please.
    Sent from my XT907 using Tapatalk
  8. #683
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by thewraith420 View Post
    My steps:
    1. wipe data/factory reset
    2. wipe dalvik
    3. format /boot
    4. format /system
    5. reboot
    others (/cache, /data, /sd-ext) are formatted during the factory reset so I haven't be reformatting them again, although I think I did try that once.
    I've seen all kinds of things in other posts, like
    • phone must be plugged into AC adapter (tried it)
    • /sdcard should be reformatted and should be ext4 (afraid to try it)
    • recovery must be the right one for the rom (afraid to change it)
    • fix permissions should be run after flashing rom and gapps (tried it)
    • no 2sd scripts of any kind should be run
    I'm using link2sd with my current Harmonia rom. could that be causing trouble?
    does my recovery version matter?
  9. #684
    o_O
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    bigsuperROM_os2sd
    The recovery does matter.
    I suggest:
    Restore your working Harmonia
    since you're nervous,
    reboot it a couple of times to make absolutely sure it's stable.
    Then you can safely change the recovery. One or the other, recovery or ROM, needs to be stable at all times. You can't mess with both at once unless you're willing to go to the trouble of unbricking it. As long as one of the two is working you can fix the other.
    The recoveries handle permissions and other things differently.
    CaptainPackers likes this.
  10. #685
    o_O
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    bigsuperROM_os2sd
    Oh, and after you change recoveries, back up your existing ROM install with the new recovery.
    brotherswing likes this.
  11. #686
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Xperion
    Quote Originally Posted by bigsupersquid View Post
    Absolutely!
    New and improved!
  12. #687
    troyguitarman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [ROM][WIP] CM10.1 jb 4.2.2 The JBC alpha build
    Can anyone host this file? PAC_JB_4.2.2-v22.0.1_20130414-042136
    123letung123 likes this.
  1. [ROM][CM10][JB] Euroskank JellyBro
    By tcapote in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 06-13-2013, 05:53 PM
  2. Thinking about Flashing to the CM10 JB Rom... 2 questions first
    By Azwizzard in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 10-15-2012, 01:21 PM
  3. [ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
    By Dark_Knight2 in forum Epic 4G Touch Archived ROMs and Hacks
    Last Post: 08-25-2012, 12:10 PM
  4. [ROM][AOSP][CM10][JB][7/25]Unofficial Official Cyanogenmod
    By SeigaGen in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 08-04-2012, 03:58 PM
  5. Desire ROM ported to the N1 (Alpha 10 now Live)
    By edoublediz in forum Google Nexus One Rooting, ROMs, and Hacks
    Last Post: 03-10-2010, 08:32 PM
