Page 3 of 28 FirstFirst 123456 ... LastLast
Results 51 to 75 of 687
Like Tree198Likes
  1. Thread Author  Thread Author    #51
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    Default Re: [ROM][WIP] CM10.1 jb 4.2.1 The JBC alpha build
    The baseband reading will be fixed in the next build. I forgot to add that back in.
    GPS support for our phone isn't in JB 4.2.1, but I see a few patches that should fix it from androidarmv6 gerrit.
  2. #52
    Promethium97z's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Great build and good work! The lag improved after I forced gpu rendering and changed clocked settings in development. Changing the default launcher may help the lag. The apps run well, it's just the trechbuctet launcher.
  3. Thread Author  Thread Author    #53
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    Added a GPS fix in the OP. Test it out with wifi off/on. On mine it located me on navigation and made a route, but still had "locating GPS" at the bottom. It will need TTS files for voice, so that part won't be working yet. If the navigation icon is gone, reinstall Maps
  4. #54
    chedder66's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by thekraven View Post
    Thanks, seems to be working just fine.
  5. #55
    ogbeboxx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Sdext doesn't work ? Apps doesn't go to it
  6. #56
    lerxst_x's Avatar
    Posts
    Global Posts
    29 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It was interfering with WiFi, you can DL mounts2sd or something like it from the market'
    Sent from my Huawei MediaPad using Android Central Forums
  7. #57
    ogbeboxx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It worked thanks
    Sent from my LG-LS670 using Tapatalk 2
  8. #58
    alimalimbaev's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks thekraven, A25 release seems to be better one as it works faster and great, I noted battery drain but I downloaded Easy battery saver, and now it's OK! It would be great if there was some some fix for headset mic. Anyway it's good job!!!
  9. #59
    Compeek's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quattrimus
    It would definitely be great to have a headset mic fix eventually if possible so the Square reader will work (and, you know, headset mics themselves).
  10. #60
    jonny5449's Avatar
    AC Citizen
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cm7/Cm9/Cm10
    With new alpha does it still lag?
  11. #61
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The lag is better, used Holo Launcher from slim rom, but you could still notice some lag. Kraven, could you please add photosphere?
  12. Thread Author  Thread Author    #62
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    Probably a no on photosphere. It's just the limits of our camera.
  13. #63
    sellers86's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CNA/CM9/Mirage
    Quote Originally Posted by jonny5449 View Post
    Stop whining about the lag. What do you expect, its 4.2.1 on a device that wasn't meant for anything more then 2.3.
    Sent from my HTC Evo 3D using Android Central Forums
    gingerc76 likes this.
  14. #64
    Compeek's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quattrimus
    Quote Originally Posted by sellers86 View Post
    He's hardly whining. Besides we've seen 4.0 and even 4.1 ROMs run with minimal lag on the Optimus S/V, so it's fair to assume that eventually a 4.2 ROM could be pretty snappy as well.
    thekraven, I'm really enjoying seeing your quick progress on this already! I can't wait until it's ironed out a bit more so I can use it daily. I appreciate all of the work you've done for this phone, even long before this ROM.
    notown, dmc5110 and jonny5449 like this.
  15. #65
    kcls's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    IHOCM7.2 || AOKP
    Quote Originally Posted by Promethium97z View Post
    Photosphere requires a gyroscope for it to work properly. Optimus S/V don't have one so it won't really ever work.
    Sent from my Paranoid Nexus 4 using Tapatalk
    flapjack.fiasco likes this.
  16. #66
    jonny5449's Avatar
    AC Citizen
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cm7/Cm9/Cm10
    I asked a simple question don't be rude wow friken people these days us more of a punk then u were before I left
    williek113 and notown like this.
  17. #67
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,029 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    You guys need to chill out. You both could have left each other's comments alone.
    Sent from my Nexus 7 using Tapatalk HD
  18. #68
    jonny5449's Avatar
    AC Citizen
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cm7/Cm9/Cm10
    Quote Originally Posted by cole2kb View Post
    Well I didn't have too he was inferring I was whining when all I did was ask a question
    Check and mate
  19. #69
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,029 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Check and mate
    Let it go.
    Va1ha11a likes this.
  20. #70
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Drew's CMX/Stock/Stock
    Just stopped back in this neck of the woods for the first time in ages, Love what I'm seeing! Kraven, what you're squeezing out of this phone is absurdly awesome. Your bugs list for 4.2.1 is about a quarter the size of the bugs for the 4.2.1 roms for the evo LTE (and your bugs are minor in comparison). Awesome job! I may have to open the drawer and get my optimus back out!
    jonny5449 likes this.
  21. #71
    bpa007tx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is awesome, I just have a question about bluetooth, I can't seem to pair my ear piece to the phone, I've read through the pages and haven't seen anything about it, does anyone know if this a bug?
  22. #72
    harsho1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    DanteRom
    getting a (status 7) installation aborted error... double checked md5 hash redownloaded. never had a problem flashing a rom before...
  23. #73
    lerxst_x's Avatar
    Posts
    Global Posts
    29 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah, I think Bluetooth may not be working.... it acts like it turns on, but then can't find any devices. Other than that, this is a great ROM.
  24. #74
    Henry Canton's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I keep getting installation aborted (status 7)
  25. Thread Author  Thread Author    #75
    thekraven's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    kraven cm7/CM9
    Quote Originally Posted by Henry Canton View Post
    Which recovery? Or check the md5 of the download if it's a corrupt download.
  1. [ROM][CM10][JB] Euroskank JellyBro
    By tcapote in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 06-13-2013, 05:53 PM
  2. Thinking about Flashing to the CM10 JB Rom... 2 questions first
    By Azwizzard in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 10-15-2012, 01:21 PM
  3. [ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
    By Dark_Knight2 in forum Epic 4G Touch Archived ROMs and Hacks
    Last Post: 08-25-2012, 12:10 PM
  4. [ROM][AOSP][CM10][JB][7/25]Unofficial Official Cyanogenmod
    By SeigaGen in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 08-04-2012, 03:58 PM
  5. Desire ROM ported to the N1 (Alpha 10 now Live)
    By edoublediz in forum Google Nexus One Rooting, ROMs, and Hacks
    Last Post: 03-10-2010, 08:32 PM
