- 01-17-2013, 06:24 PM #76
Re: [ROM][WIP] CM10.1 jb 4.2.1 The JBC alpha build
Could not Download google maps..
Error retieving information from server. [RPC:S-5:AEC-0]
edit:... nEevermind... cant download anything.
EDIT2: Fixed with a reinstall.
My new daily. So far does not have clock bug or deep sleep problem. can confirm GPS works with fixLast edited by me2151; 01-17-2013 at 08:40 PM.
- 01-18-2013, 12:21 PM #77
- 01-18-2013, 06:19 PM #78
Might give this another ol' college try this weekend. But some questions remain...
1. I know the CronMods (like A2SD++) break WIFI...let's say I wanna flash that...how do I disable wifi at the ROM level?
2. If I use Mount2SD (which I have tried in the brief moments I've tried this ROM), how do I get it configured similarly to A2SD+ or ++ (at least dalvik to ext if not both dalvik and data to ext)?
Otherwise...I guess I'll wait till the fixes are in place... - 01-18-2013, 07:12 PM
Thread Author #79
Those scripts only borks wifi on the first boot of a clean install. You can install it ok afterwards
- 01-18-2013, 07:33 PM #80
- 01-18-2013, 07:56 PM
Thread Author #81
Maybe try a2sd+
- 01-20-2013, 04:36 PM #82
- 01-20-2013, 05:32 PM
Thread Author #83
I haven't tested a clean in stall of A26, but in A25 a clean install will get you working wifi. . Try wiping data, system, sd-ext, dalvik, and cache Then flash A26+gapps. And see if wifi works. Then go back and flash the gps and virgin fix. The a2sd scripts are what make wifi not work, but you can add them after the initial reboot.
- 01-21-2013, 12:46 PM #84
- 01-21-2013, 01:13 PM #85
what's the system app that governs media storage/scanning on this ROM? can it be replaced with one from CM9? I still haven't figured out how to fix my music/pics not showing problem on JB..
- 01-21-2013, 01:29 PM #86
- 01-21-2013, 03:50 PM #87
I knew I missed a step! I'll give it another whirl. A26 works great btw, might have gotten better battery life than on BobZHome's 4.1.2 and outside of the first day and half...no reboots!
My only thing, might be a bug even if you take the kernel to 39 or 40...occasionally, the phone will not wake up when I press unlock or home and I have to reboot it via battery pull. Sometimes though it will if i repeatedly press Home 7 or 8 times in a row... - 01-21-2013, 04:26 PM
Thread Author #88
Here's some audio routing fixes from grigorig.
Wipe cache and flash in recovery. The 2nd file is if you want to flash back to the original Rom audio.Thanked by 2: - 01-21-2013, 08:55 PM #89
- 01-22-2013, 04:58 AM #90
- 01-22-2013, 10:34 AM #91
- 01-22-2013, 07:43 PM #92
Thought about that for probably 2 minutes and realized WIFI at work blows (after 9 am...there are so many students at the community college I work at that one time I did a SpeedTest and the wifi literally registered btwn 0.11-0.33 mbps down (our wireless is dual-channel N at 270 and 300 mbps hooked up to a gigabit connection that normally pulls 18-25 mbps) and Sprint registered between 1.11-1.35 mbps down) and the WIFI at my home office is marginally better than Sprint's (2.3-2.6 mbps)
I'll wait and see what's in store for A27 and dirty flash that. - 01-23-2013, 06:28 PM #93
Hey flashed a25. Other then the lag & occasional animation glitch in web broswering, The keyboard retreats. Everything is great.
Good job dev sir.
ALSO I THOUGHT THIS ROM & KERNEL HAD, USB OTG HOST MODE OR WHATEVER ITS CALLED. Sorry I'm a newb
Also you should add the development area in settings for GPU tweaking & animation tweaks. Maybe its just the a25, hmm? Guess I'll patch on my device.
Nice work again dev sir - 01-23-2013, 11:30 PM #94Guess whos coming back!
- 01-25-2013, 02:20 PM #95
Hey thanks again, everyone.d(n.n)b
A25 review for lg optimus v:
Browser shows animation glitches when keyboard retracks, but that's ok.
Tethering, WiFi or Bluetooth is screwy, in order to turn either back off, I must reenable airplane mode, (gotta toggle it on & off multiple times.(sorry I'm mobile writing, no computer) WiFi tether will go off but Bluetooth tether stays on, again gotta toggle ap mode.
- some games have black screens when playing(monster paradise, Iruna online)
- ROM emulators work, but the sounds distorts & occasionally messes with the animation.
Tweaking the animation & CPU/GPU seems to not help the problem.
Is there a way in fixing this. I ask cause I'm a forum moderator for most RPG games, & I always recommend ROMs & kernels for my hacker communityLast edited by Bri Prophetz; 01-25-2013 at 03:02 PM.
Lg optimus v cm10.1 a25 by the kraven 4.2
Lg optimus v cm10 by bobzhome4.
Coby kyros mid7033-4 stock 4.0 - 01-27-2013, 09:28 AM #96
I was liking CAI better'n any other rom I've tried on my V... until this.
this seems more responsive, especially the browser.
except that the browser is giving me trouble clicking links (often goes unresponsive except for zoom and scroll when I try, but eventually clicks thru,) browser doesn't want to select text for copy/paste at all, and swype (which usually glitches on any rom anyway, so probably app glitch) is making me peck-type right now or the cursor position moves up several lines when I swype words.
I'm liking this rom. and I bet Iceweasel doesn't have the same glitches as this mini-chrome anyway. must test.
thanks for all your superb work.
/edit/
after about 8 reboots, the browser is responding better to clicking links, and sometimes allows me to select text on a page.
Also, and this is a positive, my battery life so far is similar to or better than on CAI. Lasts over a day leaving off the mobile data connection, with light browser use through wifi and some messaging. I suspect that if I had the Gapps installed my battery life would be reduced by all the attempted syncing.Last edited by bigsupersquid; 01-28-2013 at 02:11 PM.
|..................................| - 01-27-2013, 09:20 PM #97
- 01-27-2013, 11:11 PM
Thread Author #98
Thanked by 4: - 01-28-2013, 09:51 PM #99
- 01-29-2013, 08:11 AM #100
[ROM][CM10][JB] Euroskank JellyBro
By tcapote in forum Verizon Galaxy Nexus Rooting, ROMs, and HacksReplies: 1554Last Post: 05-21-2013, 09:46 PM -
Thinking about Flashing to the CM10 JB Rom... 2 questions first
By Azwizzard in forum Epic 4G Touch Rooting, ROMs, and HacksReplies: 5Last Post: 10-15-2012, 12:21 PM -
[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
By Dark_Knight2 in forum Epic 4G Touch Archived ROMs and HacksReplies: 2447Last Post: 08-25-2012, 11:10 AM -
[ROM][AOSP][CM10][JB][7/25]Unofficial Official Cyanogenmod
By SeigaGen in forum Verizon Galaxy Nexus Rooting, ROMs, and HacksReplies: 14Last Post: 08-04-2012, 02:58 PM -
Desire ROM ported to the N1 (Alpha 10 now Live)
By edizzle in forum Google Nexus One Rooting, ROMs, and HacksReplies: 55Last Post: 03-10-2010, 07:32 PM
Reply
