Page 5 of 19 FirstFirst ... 2345678 ... LastLast
Results 101 to 125 of 469
Like Tree113Likes
  1. #101
    Default Re: [ROM][WIP] CM10.1 jb 4.2.1 The JBC alpha build
    Sorry !(*.*)!
    A25 review: audio fix.zips helps music a bit on YouTube. ROM emulators sounds still distorts,& glitches animation. Browser& streaming MMOs blackout during gameplay,(still trying figure out what's wrong)(could it be something in the build.prop)
    Removing some system apps(but the necessary) & tweaking the CPU, speeds up the system' o say 18-25%..
    Removed stock browser add dolphin mini(saves space& functions) I see no longer any animation glitches when the keyboard retracks.
    ★★really loving this ROM kraven sir ★★
    Can't wait till its a polished gem
    Lg optimus v cm10.1 a25 by the kraven 4.2
    Lg optimus v cm10 by bobzhome4.
    Coby kyros mid7033-4 stock 4.0
  2. Thread Author  Thread Author    #102
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    It might be the lack of vsync, project butter and triple buffering.
    Try changing in the build.prop.
    dalvik.vm.execution-mode=int:jit
    to
    dalvik.vm.execution-mode=int:fast
  3. #103
    Can project butter be put into the rom?
    Also, will there be a A27 in the future?
  4. #104
    drezliok's Avatar
    Posts
    ROM
    I.H.O. Mirage CM7.2
    Link2SD seems to work just fine.
  5. #105
    exProphecy's Avatar
    Posts
    Global Posts
    96 Global Posts
    ROM
    Cold.As.Ice CM9/Kernel 21
    Flashing CronmodA2SD++ works perfectly by flashing right after fresh install
    Thanked by:
  6. #106
    drezliok's Avatar
    Posts
    ROM
    I.H.O. Mirage CM7.2
    Quote Originally Posted by exProphecy View Post
    I will have to try that. But I will wait for a rom update before reflashing.
    Sent from my Transformer TF101
  7. #107
    drezliok's Avatar
    Posts
    ROM
    I.H.O. Mirage CM7.2
    Virgin patch didn't work for me. I dirty flashed from a fresh flash of a25 to a26 for the wifi work around.
    Attached Thumbnails Attached Thumbnails [ROM]CM10.1/PAC-rom jb 4.2.2  The JBC alpha build-uploadfromtaptalk1359901070463.jpg
  8. #108
    bigsupersquid's Avatar
    o_O
    Posts
    ROM
    PAC ROM+Raspbian wheezy
    Quote Originally Posted by drezliok View Post
    same for me, I just hadn't mentioned it.
    MMS bounce and bounce, they keep trying to come thru but just get the 999 number and VM system doesn't show any message received.
    thekraven likes this.
  9. #109
    atrain2324's Avatar
    Posts
    ROM
    BobZ CM10
    Never had a problem with MMS, just a pain that I have to use the native SMS app since Chomp refuses to send MMS.
    But I dunno if its a bug or it's just me. Occasionally I do offline charging to recharge back to 100% (it's fine if I accidentally reboot my device and forget to take it off the charger...)...and every single time I have, it would boot fine, but messes up the entire ROM where things start force-closing, I lose 3G and worse off, I have to reformat my SD-EXT via my computer before I go restore my Nandroid (which I'm down to doing once every two days in case it happens) because if I don't, it won't restore SD-ext.
  10. #110
    Masterjakeway's Avatar
    Posts
    ROM
    kravens alpha15f CM9
    Finally flashed this today! Will be great once it's polished!
    1. Bluetooth
    -scan didn't actually work.
    -once turned on, wouldn't turn off
    2. Browser bookmark import
    3. transparent status bar?
    4. Center clock in status bar?
    those are my wishes, lol!
    Oh, btw, my install was:
    wipe everything
    Flash a25
    Boot and connect wifi
    Wipe cache and dalvik
    flash a26
    Flash gps fix
    Flash cronmoda2sd++
    flash gapps
    Boot!
  11. #111
    Quote Originally Posted by Masterjakeway View Post
    see post 6
  12. #112
    Posts
    ROM
    I saw that. most important is the Bluetooth. It's what kept me off of CAI for the first few builds a well
  13. #113
    Shinkenred's Avatar
    Posts
    ROM
    CM10-BobZhome
    (REPOSTED)
    ...strange. I dirty flashed A25 over A17...seems to work fine, except trying to restore my apps with TB isn't as smooth as I thought. I just need to reclaim some space in my internal memory - I have about 20 apps that WON'T install, and 17 of them are because of space issues. Dirty flashing A26 over A25 COMPLETELY borked my entire setup despite being a dirty flash. Must've been pretty bad: going into recovery, the device wouldn't restore my A25 nand OR my recent A17 nand!! Both give "Error while restoring sd-ext!" message. Trying to restore my old CM10 nand, which worked. I didn't bother with my first A17 nand; the whole mess with running out of space and nothing seeming to go to my SD-EXT despite flashing A2SD++ keeps me from wanting to try restoring that and dirty flashing straight to A26 again. And it sucks, because this ROM seems to be AWESOME. (Perhaps I just need to get my paws on a bigger & faster memory card?)
    Thanked by:
  14. #114
    Ov'er here... I followed Masterjakeway's steps and it ended up working, however not at first. In case anyone would like to know:
    Clean flash of 25, virgin fix, boot.. Had trouble here. It only booted once I unplugged my phone from my usb that was plugged into my laptop.
    Connect to WiFi
    Wipe cache and dalvik cache
    flash 26 (after this I made sure my sd-ext was mounted in cwm), gps fix, cronmoda2sd++, gapps, virgin fix. Again, wouldn't boot unless unplugged from usb. Once booted, overclocked to 480/748 with default governor. Been rock solid since. I have not tested turning off/on WiFi since as I don't feel like chancing it. Leaving range and coming back was flawless though.
    I do miss the fast charge mod from your cold as ice rom (or at least can't find the setting)... I don't get a notification or anything when usb is plugged in for mass storage/debugging even though the options are checked?
  15. #115
    thewraith420's Avatar
    Posts
    ROM
    Changes Daily
    Quote Originally Posted by detlion1643 View Post
    Connect to WiFi
    The fast charge mod is part of the kernel, there are apps that can turn it on if you like
    Tapatalk'n it from my VM670 running OM-Mandylion on LS670ZVJ firmware
  16. #116
    Running JB on Optimus S is cool, especially when the OS version string is newer than the JB on new high end devices like the quad core Samsung Galaxy Note 2.
    A26: seems to have problems with USB tethering option. OS returns error 'Unfortunately, Settings has stopped.' every time I try to enable it (only possible with USB cable connected to PC).
    (I installed A25 and then A26 over it as recommended by thekraven.)
    Upper drop-down menu sometimes cuts off the upper right corner icon (only shows 1/2 of it, although it does work). Sometimes the whole icon will show.
    Not confirmed on a particular device, but battery drain seems to be higher than on some Gingerbread/2.3 ROMs.
    Google Now voice search does not seem to be really working correctly. Might need more system resources than actually present. Had similar observation of an Evo Shift JB ROM. (Evo Shift is similar age, but has more powerful CPU.)
  17. #117
    Kraven
    Keyboard swype doesn't work.
  18. #118
    o_O
    Posts
    ROM
    might've had to redownload it through the installer from the Swype beta site to get it to work.
    Swype worked ok for me though, except for the standard lag and glitchiness that comes built-in.
    Quote Originally Posted by Promethium97z View Post
    Kraven
  19. #119
    I think he's talking about the built in keyboard
    Sent from my VM670 using Tapatalk 2
  20. #120
    Connect to WiFi
    I tried everything detlion1643 did and when i went to turn off 3g my wifi turned off and wouldnt turn back on
  21. #121
    TouchPal is a good keyboard with Swype and it's in the market
  22. Thread Author  Thread Author    #122
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    New build is uploaded.
  23. #123
    What is cronmoda2sd++ and where do you find it? Sorry, I did google it but didn't find it.
    [Edit]: got it .... chronmod (space) a2sd++ Works very well went from 13MB to 140MB free
  24. #124
    o_O
    Posts
    ROM
    ah.
    isn't that armv7 closed source hooey?
    Quote Originally Posted by _alexkta View Post
  25. #125
    eletendre84's Avatar
    #sarcasm
    Posts
    ROM
    kraven CM9 / LeWa Alpha 3
    Default Re: [ROM][WIP] CM10.1 jb 4.2.2 The JBC alpha build
    Can I flash a2sd++ on this after its alredy booted??
    Sent from my LG-LS670 using Android Central Forums
  1. [ROM][CM10][JB] Euroskank JellyBro
    By tcapote in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 05-21-2013, 09:46 PM
  2. Thinking about Flashing to the CM10 JB Rom... 2 questions first
    By Azwizzard in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 10-15-2012, 12:21 PM
  3. [ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
    By Dark_Knight2 in forum Epic 4G Touch Archived ROMs and Hacks
    Last Post: 08-25-2012, 11:10 AM
  4. [ROM][AOSP][CM10][JB][7/25]Unofficial Official Cyanogenmod
    By SeigaGen in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 08-04-2012, 02:58 PM
  5. Desire ROM ported to the N1 (Alpha 10 now Live)
    By edizzle in forum Google Nexus One Rooting, ROMs, and Hacks
    Last Post: 03-10-2010, 07:32 PM
