[ROM]CM10.1/PAC-rom jb 4.2.2 The JBC alpha build
plantucha
Active member
Feb 10, 2011
41
Re: [ROM][WIP] CM10.1 jb 4.2.1 The JBC alpha build
See if wifi works without the virgin patch. Or try reflashing CAI kernel test 38, test 23, or test 21.
All tested. Wifi is still broken. First flashed ROM without Virgin +dalvik wipe , next 21 then , 23, 38. Back Virgin patch. In any case is Wifi slider in settings is grey and it forever says "turning wifi on".
thekraven
1,407
1,148
Did you do a full wipe of system, data, dalvik, and cache before the first flash? And which recovery? Don't restore wifi setting from titanium backup.
Try manually deleting with a root file explorer the file /data/misc/wifi/wpa_supplicant.conf then reboot.
I probably uploaded the wrong build. I'll double check.
I think i found it, it's something in the ramdisk. I'll try to get a patch going later tonight. On a clean install wifi is borked, but if you dirty flash over build 17 wifi will work.
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Loved feel but couldn't use
Wi fi didn't work
Kinda lagged too much for my taste
Sent from my LG-LS670 using Tapatalk 2
thekraven
1,407
1,148
The wifi problems have something to do with the wifi region code settings they just added to cm10.1. It's stuck on Europe, i'll try to fix the default.
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
OK and lag I suppose is because ur using ported code or something like that
thekraven
1,407
1,148
Temp fix for wifi on the newer builds... First flash build 17 or 23. Then let it boot. Setup wifi. Then reboot to recovery. Wipe cache and system, then install build 24 and gapps.
thekraven
1,407
1,148
Found the wifi problem. The init.d scripts for sdext. Remove the 05mountsd and 40a2sd from the zip and do a clean install. You can add the scripts back later if you choose.
plantucha
Active member
Feb 10, 2011
41
Anybody have GPS working?
Sent from my LG-LS670 using Android Central Forums
No. Gps doesn't work. Also speed is 50% of ics. But it is alpha build. It will get better eventually.
Shinkenred
322
19
18
Radio works? Strange...not that it matters for me, but it indicates the baseband as "Unknown" instead of showing the specific radio. But since camera works now, ooooh...can't wait to reload my nand (of A17) and flash the new version!!
thekraven
1,407
1,148
The baseband reading will be fixed in the next build. I forgot to add that back in.
GPS support for our phone isn't in JB 4.2.1, but I see a few patches that should fix it from androidarmv6 gerrit.
Promethium97z
12
Great build and good work! The lag improved after I forced gpu rendering and changed clocked settings in development. Changing the default launcher may help the lag. The apps run well, it's just the trechbuctet launcher.
thekraven
1,407
1,148
Added a GPS fix in the OP. Test it out with wifi off/on. On mine it located me on navigation and made a route, but still had "locating GPS" at the bottom. It will need TTS files for voice, so that part won't be working yet. If the navigation icon is gone, reinstall Maps
chedder66
Active member
Feb 23, 2011
29
Thanks, seems to be working just fine.
lerxst_x
Active member
Dec 6, 2010
28
It was interfering with WiFi, you can DL mounts2sd or something like it from the market'
Sent from my Huawei MediaPad using Android Central Forums
alimalimbaev
9
Thanks thekraven, A25 release seems to be better one as it works faster and great, I noted battery drain but I downloaded Easy battery saver, and now it's OK! It would be great if there was some some fix for headset mic. Anyway it's good job!!!
Compeek
Active member
Apr 28, 2011
29
19
It would definitely be great to have a headset mic fix eventually if possible so the Square reader will work (and, you know, headset mics themselves). :)
phone user
