[ROM] JB 4.1.2 SlimRom for LS670 3.1 Build3
thewraith420
1,987
223
63
Re: [ROM] JB 4.1.2 SlimRom for LS670 3.1
Made a quick one in the OP. Just change the carrier via settings.
Thanks. possible bug report I use adw ex launcher. Every time i reboot I tell it to use adw ex as default launcher but it asks every time regardless
Sent from my LG-LS670 using Tapatalk 2
Axe
200
3
I tried to use clockr and no settings would stick, (compared to the BobZhome CM10)
thewraith420
1,987
223
63
This rom is in VERY early stages so this is really just an observation
The rom is running great no fc or reboot issues so far and clock lag doesn't seem to be an issue either. Acording to this screen shot its even sleeping correctly however the battery life is not so great.
thekraven
1,407
1,148
http://img.tapatalk.com/d/12/12/31/y5a8urut.jpg
You can try these build prop tweaks from the CAI build.prop and the 99youtube fix from the init.d folder. And if you use bluetooth, idk if it works or not yet, but there's a bluesleep fix on permissions in the cai thread somewhere. And for the launcher issue, try to fix permissions in recovery, command line, or in Settings. Or move the launcher to internal memory or remove hololauncher completely
Code:
#From CAI
persist.mvpdm.ProxyServerAddr=68.28.31.1
persist.mvpdm.ProxyServerIp=80
debug.performance.tuning=1
video.accelerate.hw=1
# Increase battery and longer standby time with deeper sleep
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
# More accurate touch
movfilter=40
move hyst=0
# Faster transfer rate for net connections
net.tcp.buffersize.default=4096,87380,256960,4096, 16384,256960
net.tcp.buffersize.wifi=4096,87380,256960,4096,163 84,256960
# store launcher in memory - so that when you switch back to home it loads faster
ro.HOME_APP_ADJ=1
# improve image and video quality (when taking pics and vids from cam and showing them in gallery)
ro.media.enc.jpeg.quality=100
ro.media.dec.jpeg.memcap=8000000
ro.media.enc.hprof.vid.bps=8000000
#Improve Scrolling Build.prop Tweak
ro.max.fling_velocity=4000
# Disable strict mode flash on display
persist.sys.strictmode.visual=false
#Disable_ADB_Notification_Icon
persist.adb.notify=0
dalvik.vm.execution-mode=int:jit
windowsmgr.max_events_per_sec=150
ro.config.vc_call_vol_steps=15
# V6 SuperCharger settings
ro.ril.hsxpa=3
ro.ril.gprsclass=12
ro.ril.hep=1
ro.ril.enable.dtm=1
ro.ril.hsdpa.category=28
ro.ril.enable.a53=1
ro.ril.enable.3g.prefix=1
ro.ril.htcmaskw1.bitmask=4294967295
ro.ril.htcmaskw1=14449
ro.ril.hsupa.category=9
ro.media.enc.file.format       = 3gp,mp4
ro.media.enc.vid.codec         = m4v,h263
ro.media.enc.vid.h263.width    = 176,640
ro.media.enc.vid.h263.height   = 144,480
ro.media.enc.vid.h263.bps      = 64000,1600000
ro.media.enc.vid.h263.fps      = 1,30
ro.media.enc.vid.m4v.width     = 176,640
ro.media.enc.vid.m4v.height    = 144,480
ro.media.enc.vid.m4v.bps       = 64000,1600000
ro.media.enc.vid.m4v.fps       = 1,30
ro.media.dec.aud.wma.enabled=1
ro.media.dec.vid.wmv.enabled=1
_alexkta
289
Wait so if we put the 999youtube file in the int.d folder of bobzhomes cm9 it will fix YouTube?
Sent from my LG-VM670 using Xparent Cyan Tapatalk 2
thekraven
1,407
1,148
I just tried the free Clockr and everything is sticking, even after a reboot. Fresh install of the app or restore?
fortyquid
Active member
May 17, 2011
27
You're the man, Kraven. Love the ROM. New daily.
Noob inquiry: are those tweaks flashable somewhere?
exProphecy
97
3
I'm not seeing my music in my music app or pictures from my sd in gallery. Any idea why?
dunno if it has anything to do with this but i installed cronmod a2sd++ and running on optimus V
EDIT : oh there's a build 2. I'll see if that fixes it
exProphecy
97
3
Nope it does not. Music and pics don't show in gallery or music app from my SD card
exProphecy
97
3
It's the music app. I'll include Apollo in the next build. Gallery pics are showing for me
Thankies! Very good ROM for an early build! Good enough as a daily already :)
Any chance sd-ext script can be included? Maybe the script I'm using is causing issues with gallery for me
EDIT: Just tried Apollo and music on my SD still doesn't show.. must be my sd-ext script
thekraven
1,407
1,148
I used the cron a2sd+ script and it worked for me. It shouldn't have any effect on sdcard pics and music.
Here's a flashable zip for Apollo. You can delete the Music.apk in the system/app folder or leave it.
Edit: Apollo was freezing up on me when i turned on the equalizer, so keep that off for now. or try Omich player on the Play store.
  • Apollo.SLimRom.build2.zip
exProphecy
97
3
I'll just wait for your next build :) thanks man
Axe
200
3
Fresh install, but might've been a fluke. Didn't try a reboot, but mclock seemed to work. A few more questions:
Is the time lag non-correctable?
What do you recommend to only get the power button to wake the phone? (Edit system files versus cm10-like custom settings?)
With the voice search removed, am I correct to presume the voice input for an alternate keyboard would also be disabled?
Chelrie
