[ROM] JB 4.1.2 SlimRom for LS670 3.1 Build3
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Hey was in school today and my phone vibrated like crazy for 1-2 minutes with no notification. Bug maybe?
Sent from my LG-LS670 using Tapatalk 2
fortyquid
Active member
May 17, 2011
27
Anybody else having data issues? I'm still trying to determine exactly what causes it to drop out, but when it does, I have to reboot?it won't come back by toggling. Also, turning on the speakerphone mutes the mic.
flapjack.fiasco
776
102
Yeah, I'm with you there. I assumed it was the same issue Bobz JB ROM was having, where it cuts out during deep sleep and won't come back without a reboot. But I can't say for certain what's causing it, I just know it's happening.
HaiTek
10
I can confirm this as well, I've tried going into airplane mode and back, but it seems to only way is to reboot the phone. Also as a side note, the mobile data toggle on the notification drawer power widget doesn't appear to do anything.
thewraith420
1,987
223
63
Hmm I'm not on this rom now but I didn't have data problems when I was.. Jonny you on zvd or j?
Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ firmware
thewraith420
1,987
223
63
Not Jonny???
You said you weren't having data problems either so I just wanted to know what baseband you are on. Could be there's something in the zvj libs fixing the data problems if your on zvj also.....
gingerc76
107
Exactly, strange how I have 51 apps on cai and no memory issues there but when I flashed this rom, by the time I had the 19th app it said low memory :confused:
Sent from my LG-LS670 using Xparent Purple Tapatalk 2
fortyquid
Active member
May 17, 2011
27
I'm having a2sd I issues as well. I think mine have to do with my partition. Either the phone doesn't like my sd card, or the ROM doesn't like my partition (or both). I'm about to run a nand and repartition.
thewraith420
1,987
223
63
Don't forget to backup your sdcard a nand won't get that just ext
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Zvd kind sir
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Kraven u should change ur title to say build 4
Also quick question.... is it aosp source based?
flapjack.fiasco
776
102
So much for that theory. :)
This is just an observation, with no real testing behind it, but it seems like I can keep the data connection up as long as I keep wifi off. After wifi has been on for a few, if it's then turned off, I have to restart to reestablish the data connection.
kemberley1
