Use the info on this page: How To Build CyanogenMod Android for LG Optimus One ("p500") - CyanogenModI'm having problems figuring out how to download a repo ( I read to much info, in to many places, brain is now locked up). What repo are you using? Could you post code to download that repo? I see there is version 1.19 and 1.20
Maybe I'll try to build the latest Touch Screen ClockworkMod recovery (6) if that would help installing Kit Kat. I would then need the CyanogenMod repo I guess?
EDIT: I noticed that RAM and swap space are important, but how much hard drive space is really needed? I might need to upgrade the hard drive to something larger and get two 2GB RAM sticks (my system is expandable up to 4GB).
andyopie150@Dell-OptiPlex-GX620DT:~/android/system$ repo init -u git://github.com/androidarmv6/android.git -b cm-11.0
/home/andyopie150/bin/repo: line 1: syntax error near unexpected token `newline'
/home/andyopie150/bin/repo: line 1: `<!DOCTYPE html>'
By the way it's good to see you still coming back here now and then. I swear the fact that there are still people interested in this phone is just amazing
Check your repo script. It's supposed to be a python script so the first line should be #!/usr/bin/python or something. When you ran the curl command to download the script the server may have returned an error page due to overload or something.Thanks for info.
If you can get it into fastboot screen it can be saved. You can use the KP500 as well.
We already have a TWRP recovery: [RECOVERY] TWRP 2.3 / 2.2.2.1 TEAMWIN touch recovery - Page 2 - Android Forums at AndroidCentral.com
This is what I get when following the directions under "Initialize the CyanogenMod source repository"
Code:andyopie150@Dell-OptiPlex-GX620DT:~/android/system$ repo init -u git://github.com/androidarmv6/android.git -b cm-11.0 /home/andyopie150/bin/repo: line 1: syntax error near unexpected token `newline' /home/andyopie150/bin/repo: line 1: `<!DOCTYPE html>'
EDIT: Oops! Just checked, the TWRP download "cannot be found". I do have one if you need it. It will be the version I linked to.
Good thing I use my Windows XP Professional (don't use it hardly at all since my first Linux OS) for storage. I keep a bunch of old V stuff there just in case of this very problem.
Can p500 ROMs work for ls670 ?
Hey ya'll. If you are having some computer set up issues, you can use my computer with team viewer. I have 4 systems in my house. One is an old PC with tiny7 on it, the other is a Acer laptop (wife's) with a separate monitor, another is a Samsung netbook permanently hard wired (by accident/repair job gone wrong), and my last runs our "Smart TV".
You could remote control my netbook, and possibly my PC while I'm at work M-F from 7-4 every day. I've got hacked Windows 7 on all the computers, so I/you'd have to install various Linux systems if you need them.
Private message me, in particular Andieopie 150, Skin bark, the wraith, anino, or nitestalker. I trust/have seen enough of you guys around the web to let you in.
As a reminder, if you upload anything flashable, I'll test it on my S over weekends. I have the latest COT running 4.2 right now.
Installed Ubuntu 13.04.Check your repo script. It's supposed to be a python script so the first line should be #!/usr/bin/python or something. When you ran the curl command to download the script the server may have returned an error page due to overload or something.
from
curl [URL]https://dl-ssl.google.com/dl/googlesource/git-repo/repo[/URL]
to:
curl [URL]http://commondatastorage.googleapis.com/git-repo-downloads/repo[/URL] > ~/bin/repo
andyopie150@Dell-OptiPlex-GX620DT:~/android/kitkat$ repo init -u git://github.com/androidarmv6/android.git -b cm-11.0
bash: /home/andyopie150/bin/repo: Permission denied
mkdir ~/bin && curl http://commondatastorage.googleapis....downloads/repo > ~/bin/repo && chmod a+x ~/bin/repo
repo sync
sudo apt-get install lib32z1 lib32ncurses5 lib32bz2-1.0
sudo apt-get install libgtk2.0-0:i386 libpangox-1.0-0:i386 libpangoxft-1.0-0:i386 libidn11:i386 libglu1-mesa:i386
sudo apt-get install libc6:i386 libgcc1:i386 gcc-4.6-base:i386 libstdc++5:i386 libstdc++6:i386
<?xml version="1.0" encoding="UTF-8"?>
<manifest>
<project name="TheJBC/android_device_lge_thunderc" path="device/lge/thunderc" remote="github" revision="cm-10.2" />
<project name="TheJBC/android_device_lge_msm7x27-common" path="device/lge/msm7x27-common" remote="github" revision="cm-10.2" />
<project name="TheJBC/android_device_qcom_msm7x27" path="device/qcom/msm7x27" remote="github" revision="cm-10.2" />
<project name="bigsupersquid/android_kernel_lge_msm7x27-3.0.x" path="kernel/lge/msm7x27-3.0.x" remote="github" revision="squid" />
<project name="TheJBC/android_vendor_lge" path="vendor/lge" remote="github" revision="cm-10.2" />
<project name="mirror-androidarmv6/android_vendor_qcom_msm7x27" path="vendor/qcom/msm7x27" remote="github" revision="cm-10.2" />
</manifest>
Gotcha. You'll have to forgive me, I'm a totall newb at this, but I am a fast learner.When I said check the repo script I meant to open the file ~/bin/repo in a text editor and look at the contents so you could verify that it contained a python script and not a bunch of html code. If so, enter the directory that you're going to use as the base directory for cm-11.0 and enter the "repo init" command. It'll download some files and create a directory called .repo in your base directory. After that make a directory inside the .repo directory called local_manifests and create a file in it called roomservice.xml that contains this:
Code:<?xml version="1.0" encoding="UTF-8"?> <manifest> <project name="TheJBC/android_device_lge_thunderc" path="device/lge/thunderc" remote="github" revision="cm-10.2" /> <project name="TheJBC/android_device_lge_msm7x27-common" path="device/lge/msm7x27-common" remote="github" revision="cm-10.2" /> <project name="TheJBC/android_device_qcom_msm7x27" path="device/qcom/msm7x27" remote="github" revision="cm-10.2" /> <project name="bigsupersquid/android_kernel_lge_msm7x27-3.0.x" path="kernel/lge/msm7x27-3.0.x" remote="github" revision="squid" /> <project name="TheJBC/android_vendor_lge" path="vendor/lge" remote="github" revision="cm-10.2" /> <project name="mirror-androidarmv6/android_vendor_qcom_msm7x27" path="vendor/qcom/msm7x27" remote="github" revision="cm-10.2" /> </manifest>
Now you're ready to run "repo sync" and download cm-11.0.
#!/usr/bin/env python
That setup is okay. If you need more swap you can create a big file in Xubuntu and tell Linux to use it as swap in addition to your swap partition. Here's a link:One quick question.
I have two 80GB hard drives. On /dev/sda I have Windows and the swap partition. On /dev/sdb I have Xubuntu but no swap partition. Swapping files from Windows to Xubuntu and vice-a-versa works fine.
Do I need to change this setup, or can I just enlarge the swap partition?
