Was hoping to test out this rom and give feedback about it, but ended up bricking my phone instead. I had my V running the latest Mirage rom and was using the Cannible Open Touch Recovery. I made nandroid backup, installed regular CWM_6.0.4.6 in OP, sucessfully flashed regular Kit Kat rom and played around with it for a bit, then restored phone back to Mirage. Decided to try out the OS2SD Rom and that's where it went downhill.
So basically:
-Was running Mirage Rom using Cannibal Open Touch Recovery
-made nandroid backup
-flashed regular CWM_6.0.4.6 in OP
-successfully flashed and played around in regular Kit Kat rom
-Restored phone from nandroid backup to Mirage
-Decide to try OS2SD rom
-nandroid backup and move all contents from SD card to folder on PC
-Formatted my 32gig SD Card with large FAT32 partition, 2Gb EXT4 partition, 512Mb EXT4 partition, 512Mb EXT 4 partition.
-Downloaded all zip files for OS2SD rom, put in folder, put folder on empty sd card
-Try to flash OS2SD version of CWM_6.0.4.6
-Regular CWM says "can't mount /storage/sdcard0
-Me ---> ?????
-Tried copying all files back to sd card, boot.....freeze at android logo.
-CWM can't see SD card so can't flash anything, don't know how to use ADB
-Read Unbrick Guide KDZ, install those files,reboot into emergency mode, follow instructions, click lauch software update, error message, click agian, same thing
-Phone now can do nothing but display Emergency Mode
