1. dman861's Avatar
    Figured I should start separate thread to not clog up the Kit Kat thread. I'm trying to install the OS2SD version of the Kit Kat rom but I'm having problems mounting my SD card. I soft bricked once (I've realize how I could have easily fixed the problem, explained later...) eventually was able to restore to 100% stock. Installed Gingerbreak, and am now rooted on 2.2 with the OS2SD CWM recovery installed. I've noticed that when my SD card is formatted as one large FAT32 partition, my card mounts in OS and recovery no problem. When I partition it (using MiniTool Partition Wizard) into 3 Ext4 partitions of at least 256 MB (I partitioned them as 2Gb, 512Mb, & 512Mb), both Android and recovery can't mount the SD card. Android must be able to see the SD card because it notifies me when i eject it, but does nothing when i click it back in. Recovery is pretty much the same, when no SD card there isn't option to mount it, when SD card is in there is option to mount but it is unable to mount.
    tl;dr: No Ext4 partition = SD card mounts, With Ext4 partition = SD card can't mount.
    01-04-2014 02:57 PM
  2. bigsupersquid's Avatar
    you have to have the first partition vfat(fat32)
    that's what Android sees as sd card.
    you didn't mention the vfat with the ext's
    dman861 likes this.
    01-04-2014 03:23 PM
  3. dman861's Avatar
    The way I had my card set up with MiniTools would be like this
    |---------------------------29Gb Fat32----------------------------| |----2Gb Ext4----| |-512Mb Ext4-| |-512Mb Ext4-|
    Fat32 is set as primary, the Ext4's set as logicals.
    01-04-2014 03:29 PM
  4. bigsupersquid's Avatar
    no logical drives
    primary only
    dman861 likes this.
    01-04-2014 04:16 PM
  5. dman861's Avatar
    Just a status update. I reformatted my card as you said, same sizes as i wrote about only now all partitions are set as primary. Android boots and can see my card, and normal CWM can see it also! Now my problem is getting OS2SD version CWM to boot. In regular CWM, I flash OS2SD CWM .zip --> it says successful --> reboot into recovery --> LG logo displays --> black screen --> red CWM logo displays for about 3 seconds then black screen --> LG logo --> Android boots. I tried extracting the recovery.img and installing with Flash Image GUI, it says successful but still unable to successfully boot into OS2SD recovery. Any ideas?
    01-04-2014 05:38 PM
  1. What is SNS in App Manager?
    By aseke in forum Samsung Galaxy Note 2
    Last Post: 01-10-2017, 11:19 PM
  2. is it possible to revert back to 4.1.2?
    By badkitties in forum Verizon Galaxy Note 2
    Last Post: 01-07-2014, 05:53 PM
  3. Which is best kernel to use on this rom? GS3?
    By kabuchi in forum Samsung Galaxy SIII I9300
    Last Post: 01-06-2014, 03:42 PM
  4. Is there a safe way to change fonts in Cyanogenmod?
    By tat21985 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 01-05-2014, 10:17 PM
  5. adjust size of partition and keep data
    By linuxalien in forum LG Optimus Series
    Last Post: 01-04-2014, 02:46 PM
