Page 11 of 12 FirstFirst ... 89101112 LastLast
Results 251 to 275 of 291
Like Tree5Likes
  1. #251
    TriWolf's Avatar
    Posts
    ROM
    gROM
    Default Re: [How-To] Unroot your phone and return to stock
    Quote Originally Posted by ichihollow View Post
    It results in a factory issued phone just keep in mind the "newer" optimus s phones have different LCD panels so the earliest they can go back is vc.
    and the update from there right. i just want to get this so when and if and its a big if when they release gingerbread for the LG Optimus S
    Death Before Dishonor
  2. #252
    ichihollow's Avatar
    Posts
    ROM
    CM 7 v9 radio
    Quote Originally Posted by TriWolf View Post
    i would just wait for them to release it before going through all of this. kp500 will allow you to choose which firmware you install if you choose the vd on then it will be at the most current release.
  3. #253
    hlxanthus's Avatar
    Posts
    ROM
    RasbeanJelly/DanteRom v4
    Default
    your best bet is a force flash with kp500 or kdz
    Sorry if this seems redundent, but will this also remove the custom recovery? I am having major data issues and may be taking phone in for service so will need to be at true factory state. If so are there any posts out there that walkthru the kdz method of unrooting?
    Sent from my Optimus S
  4. #254
    tirith's Avatar
    Resident Linux Fiend
    Posts
    ROM
    Stock Touchwiz LJC 4.1.1
    all the links in the OP seem to be dead, dont know if its just me....
  5. #255
    NerdyNugget's Avatar
    Posts
    ROM
    Stock JB
    Quote Originally Posted by tirith View Post
    They are dead to me as well
  6. #256
    tirith's Avatar
    Posts
    ROM
    there is a "simplified unroot and stock" that does work... i just dont feel like posting a link.
  7. #257
    kenharkey7's Avatar
    Posts
    ROM
    G-T-R Reloaded 7.8
    Awesome thank you, i end up messing with my toys a bit too much sometimes lol. This could be quite useful.
  8. #258
    incarceration's Avatar
    Posts
    Global Posts
    74 Global Posts
    ROM
    Synergy ROM r436
    Where?
    Where is info on KDZ?
  9. #259
    igtheacttka's Avatar
    Posts
    ROM
    KRAVEN
    Wow... thank god! This saved me from a brick! Thanks
  10. #260
    where are the files at that shows you how to root when i click on them they dont pull up
  11. #261
    Can someone provide a guide for zvd users
  12. #262
    Posts
    Global Posts
    74 Global Posts
    ROM
    Synergy ROM r436
    Quote Originally Posted by igtheacttka View Post
    Where'd you get all the files necessary?
  13. #263
    ichihollow's Avatar
    Posts
    ROM
    CM 7 v9 radio
    can a mod please lock this thread?!
    The links do not work please use one of the following tools:
    LG update tool
    KDZ
    KP500
    all above tools will force flash your phone to a warranty approved firmware, and instructions can be found here.
  14. #264
    I cant get GNM’s v1.1.0 Recovery Kernel, link is broken. Does anyone know where to get it. Or can someone email it to me. PLEASE. Thank yOu
  15. #265
    ichihollow's Avatar
    Posts
    ROM
    CM 7 v9 radio
    Quote Originally Posted by androidman 2011 View Post
    Please use xemacs recovery, it really saves everyone a lot of time in the long run. More options t9o.
  16. #266
    intheb0x's Avatar
    Posts
    Global Posts
    949 Global Posts
    ROM
    Only Jelly Bean or ICS!
    To be honest,
    this post is old and confusing.
    without pulling my hair out and slamming the phone against the wall i figured it out.
    use the simple unroot method here [How-To] Simplified UNROOT and return to STOCK, download the recovery and other img, put it on your SD, adb in and flash those, then u have to force flash the phone into VD or whatever u want using this here [How-to] Revert to LS670V9, after installing OTA LS670VC/VD, using KP500 (Diag mode)
    then after its all done, go into the settings, privacy and factory reset the phone.
    then its finally done!
    If you think i helped you, please click the Thanks button on the right
    Thanked by:
  17. #267
    the recovery page is unavailable for me to download it!
  18. #268
    Something must have messed up for me, I follow every step exactly and after rebooting I can no longer get into bootloader mode and it wont boot into android, help!! It's just a black screen!
  19. #269
    bricked my phone..mark this post
  20. #270
    Quote Originally Posted by largemaple View Post
    Follow this tutorial but use this firmware instead of the one they link to:
    Working Firmware Link:
    http://forums.androidcentral.com/lg-...-using-kdz.htm
    It worked for my phone also gets you back to offical bootloader and firm.
  21. #271
    Jessicalt1's Avatar
    Lover of all things Andi
    Posts
    Global Posts
    418 Global Posts
    ROM
    MikRunny v1.01
    Great guide, thanks!
    Just another crazy Andi lover
    Have you been helped? "Thank" the person who helped you!! Don't be stingy!
  22. #272
    I tried to download the links, it says the files are not there.
  23. #273
    [How-To] Rooting LS670ZVH
    Installed ZVH by mistake? Use simple update.zip to revert to ZVD / Froyo
  24. #274
    Default Failed at Going stock and Unrooting.
    Ultimate Fail. I did everything, but I must have failed at something. I think I'm bricked, but its a weird brick, so I thought that I would share it with you. I didn't get any errors while flashing the recovery image using the command prompt, and the sound of old sprint boot logo cricketing made me feel safe, until I saw that I saw nothing. The screen was black. I waiting in merciless horror only to watch as my optimus boot looped back to the LG screen and into the blank bootscreen. I took out the battery and tried putting it into recover. It looked like it was going to work, seeing as it made no sprint logo screen noise... and I waited. No recovery. No bootloop. Just a black recovery. Interestingly enough though, if I were to hit the menu button or the home key twice, the phone reboots. Hitting any other key does nothing. Also while I am in "recovery" the device is recognized in adb, but that is where ALL hope seems to end.
    C:\Program Files (x86)\Android\android-sdk\platform-tools>adb shell
    - exec '/system/bin/sh' failed: No such file or directory (2) -
    Obviously I screwed up, but could someone tell me where? Thanks! (I'm ordering a new optimus off ebay Thursday and just replacing the guts.) Hope this can be identified, laughed at, and never done again.
  25. #275
    You didn't screw up. You have a newer model Optimus that comes with a new LCD component. The older V9 recovery does not have the LCD drivers to control your display. Everything will work, you can press buttons, clear cache, etc., just you will have no visual feedback. You can't start adb shell because /system isn't mounted.
    I suggest you follow this thread (skip step 2 since you already have stock recovery)
    Thanked by:
