09-14-2012 07:36 PM
291 1234 ...
tools
  1. steviee7's Avatar
    im already unrooted and i just want to take off the custom recovery... how can i do that
    01-14-2011 04:34 PM
  2. steviee7's Avatar
    To upgrade to V9:
    Due to the kernel being from V9, the phone thinks the firmware is up to date, so you will NOT be prompted for the OTA update. However, since I have a copy of it, you can manually install it. Heres how:
    1) Plug phone into PC
    2) Enable USB Mass Storage
    3) Download the V8 to V9 update and place it in the root of the USB Device/SDCard as "update.zip" (renaming it is important!)
    4) run the following from cmd prompt: "adb reboot recovery"
    5) You are now at LG's dark-blue recovery screen (should only be 4 options, if not STOP HERE)
    6) Select the option with "update.zip"
    7) follow instructions on screen (VERY IMPORTANT)
    You now have V9 Radio/Baseband and V9 stock update. You can delete the update.zip from your SDCard when you are back into Android.
    i followed all instructions and now im back to stock... but when i try to install the update.zip it says "
    -- Install from sdcard...
    Finding update package...
    Opening update package...
    Verifying update package...
    E:Failed to open /sdcard/update.zip (no such file or directory)
    E:signature Verification failed
    Installation aborted.
    but i named it update.zip and placed it on the root of my sdcard... can someone help me?
    01-14-2011 06:10 PM
  3. lobody94's Avatar
    That's where I got with mine when I gave up and decided to flash my original backup instead of the one in this thread. Shoot me a pm and i can give you a copy of my clean backup that is working for me. It is the v9
    01-14-2011 07:37 PM
  4. shyamsrd's Avatar
    I am on stock rom and installed custom recovery. I need to get rid of custom recovery (I did tried nand restore from custom recovery but custom recovery is still there) . can some one give the instructions or do I need to follow from 1st post? thanks in advance
    01-15-2011 11:12 PM
  5. shyamsrd's Avatar
    I downloaded the v9 stock recovery.img from OPs web site [God bless Zefie] and did a
    #flash_image recovery recovery.img. Now I have a original config.
    Now the question is how to take a nand back up or create update.zip of what I have with out custom recovery. Just in case I need in future to get back to original setup?
    01-16-2011 02:41 AM
  6. cr33p's Avatar
    I too am stuck at the exact same spot Appears to be back to stock though, phone isn't activated so I cant see if it wants to run an update or not.
    01-16-2011 07:10 PM
  7. spd-racer's Avatar
    I have made a nandroid dump of the complete V8 stock system, including kernel, rom, recovery.. everything except the evil devil RADIO. Restoring to V8 will allow you to accept the Sprint V9 update and update your radio PROPERLY.
    It will also allow you to bring your phone in for repair, or just remove any hacks you did so you can sell the phone, ect.
    This is 99.9% STOCK. This returns your phone to the state it was when you opened the box.
    Thank you for this fix, I was stuck in the custom recovery reboot loop with this recovery. So I just followed the steps from there and it fixed my phone.
    Thanks,
    01-16-2011 10:03 PM
  8. TheTolsonator's Avatar
    13) Go down to "USB-MS Toggle"
    14) Select "USB-MS Toggle SDCard"
    15) Download my Stock V8 Nandroid Dump
    16) Unzip it into the root of the USB Device/SDCard
    17) Safely remove the USB device using your PC OS.
    18) Press menu to disable USB-MS Toggle.
    19) Press back.
    20) Select "Backup/Restore".
    21) Select "Nand restore".
    22) Select "mem=477M".
    23) Select "BCDMRS12-20101122-1915"
    24) Press menu to confirm.
    25) When the process is complete, DO NOT REBOOT. Nandroid does NOT flash recovery by default, to protect from losing your custom recovery. In this case we WANT to lose it, otherwise we won't be stock, and OTA updates will not work. Therefore we must...
    26) adb shell
    27) mount /sdcard (if this throws an error about "device or resource busy", just ignore it)
    28) cd /sdcard/nandroid/mem=477M/BCDMRS12-20101122-1915
    29) flash_image recovery recovery.img
    30) reboot
    Following the directions to what I would think is to a "T" so to speak...Ive unzip'd the nandroid backup you provided into the root, I see where it went, right next to mine, and when I go to run it, the nandroid restore would fail after a few dots loaded, saying something about nandroid.mobile.
    Any ideas?
    ***UPDATE***
    Just rebooted into recovery again, and now I'm assuming its the LG recovery. A lot of the options have disappeared and I'm confused >_<
    ***UPDATE AGAIN***
    Yeah, so I'm afraid I'm a bit of an *****...When I renamed the file to update.zip, I forgot that I had known file extensions turned off, and I named it update.zip.zip. Retrying.
    ***FINAL UPDATE***
    Hey, sorry for spamming the thread, but I figured it out. I must have gotten a bad download or copy to the phone. I redownloaded it, sent it to the SD card and re-flashed the recovery onto it. I think I'm getting the handle of the Android ecosystem. I'm a big webOS guy sorry
    01-17-2011 11:57 AM
  9. cr33p's Avatar
    Anyone else having an issue applying the v9 radio update? getting an error about update.zip not found?
    Soo to all that may have ran into the same issue, simply rename the file to "update" not update.zip , its already a zip file duh soo yeah im all set now, awesome.
    Thanks
    01-17-2011 05:06 PM
  10. sfhub's Avatar
    In case this helps anyone.
    The optimus I have came with v9 stock.
    I just wanted to get rid of Sprint ID so the phone wouldn't be stuck on the stupid gray activation screen (requiring the use of voice rec workaround to navigate menus and apps), then keep the stock rom and give it to someone less technical to use.
    rooted with rageagainstthecage
    installed custom recovery partition to create a nandroid backup
    installed titanium backup apk
    in titanium backup, removed sprint id
    Everything was working great, phone booted into a usable state w/o need for extra voice rec shenanigans. I was about the do a ##786 reset then realized that I had installed the custom recovery partition to do the nandroid backup. In hindsight I didn't really need to do that other than to make backups, but it was already done. Didn't want my friend to inadvertently do a reset (or be told by CS to do a reset) and be left with a phone stuck in recovery mode.
    Seemed circuitous to go back to v8 just to upgrade to v9. I decided to just flash the v9 recovery.img. I also wanted to verify the recovery.img was indeed the v9 (OP said it was, but never hurts to verify). Took a backup recovery.img I had and ran checksums against the one in the first post. Yup, exactly the same.
    I proceeded to flash the recovery.img and reboot.
    Then did a ##786 reset.
    formatting DATA
    formatting CACHE
    factory reset
    reboot
    Phone booted into Android home menu w/o the dreaded Sprint ID configuration. The phone was nice and usable with wifi even without activation. Standard resets through android methods like privacy and ##786 worked fine.
    This is on a never activated Optimus S that came with v9 stock.
    Anyway, all this is already implied in the instructions of the first post. Just wanted to share my version of how I used these instructions in case it helps someone else.
    I'm guessing, in theory, if you were happy with your version of ThunderRom and weren't going to flash new ones anytime soon, you could also just flash the v9 recovery.img and restore the ##786 and Privacy reset functionality, though I didn't test this. That would make it safe to hand over to someone less technical.
    01-18-2011 10:01 PM
  11. sammyesb's Avatar
    could someone please tell me how to get to su? I deleted my phone data now when i load up the phone I can only get to the thunderrom adroid recovery screen.
    I can connect to usb, move the files, type ADB in the command prompt.
    as soon as I put in all the commands i type SU and get the error /sbin/sh: su: not found
    can someone please help me?
    I sold the phone on eBay and now i have to send it but i need to fix it first
    Thanks!
    01-24-2011 06:04 PM
  12. sammyesb's Avatar
    I guess I should explain better since I'm was a bit frantic earlier lol.
    So I went into privacy (using Thunderom 1.3) and did a data factory reset. I had no idea it would brick my phone or mess anything up since it was not disabled in the rom.
    Now whenever i reboot, remove the battery, or turn off the phone, I am stuck on the Android System Recovery Screen. This is the Thunderom version, not the LG default version.
    I wouldnt mind installing 1.6, but when I do it still takes me to the Recovery Screen instead of booting android. I make sure to do a data, davik, and cache wipe before I install 1.6. I also have 1.3 zip and after installing i cant get into Android.
    So following the steps on here I am unable to type su on the command prompt because even though my phone can connect with the USB, I cannot get inside android so the SU app wont work.
    I have old nand backups but they wont seem to work when i restore them.. What shall I do?
    Thank you for any help you guys can provide me!
    01-24-2011 06:19 PM
  13. cmajeski71's Avatar
    SO glad I found this guide! but Im having some problems on steps 5 and 6. am I supposed to unzip the recovery kernel and flash_img to my sd card or into the sdk manager tools? Ive tried putting them in both places, and then my next question was when I put in "adb push recovery-RA-GNM-thunderc-s-1.1.0.img /sdcard/" it tells me adb: not found, Ive tried it about 20 times to no avail.
    cc0n01 likes this.
    01-24-2011 06:57 PM
  14. harabai's Avatar
    thank you, these instructions are the bees's knees
    01-28-2011 05:51 PM
  15. joakyno's Avatar
    I got everything sorry for bothering you guys. I learn from mistakes
    01-31-2011 06:54 PM
  16. hytek369's Avatar
    Is there a way to return to factory default (system wipe/restore) without rooting?
    Basically, I bought a used phone and I want the other guy's stuff cleared out.
    02-01-2011 11:44 PM
  17. prittyboy203's Avatar
    Just hold the volume down and power button at the same time and you'll get a little android Guy with a triangle just hit factory reset and you'll be all cleared up
    Sent from my PC36100 using Tapatalk
    02-02-2011 06:38 PM
  18. hytek369's Avatar
    Thank you
    02-02-2011 09:35 PM
  19. jasthomas's Avatar
    i just did the nandorid restore but im confused do i restart the phone?????? and then after that i have no idea what to do!!! my phone needds to go in for repairs and i need this done asap!!!! i seriously need step by step!!! my htc hero was way easier than this phone!!! :/ that thing had a ruu!!!! i wish this phone did too!!!
    02-07-2011 03:10 PM
  20. crashbowman's Avatar
    I am currently on V9 running LegoRom. Could I do this?
    1) Nandroid backup my current LegoRom
    2) Do this method to return to stock V8
    3) Do the update to V9
    4) Do the update to VC
    5) Re Root/Flash Recovery
    6) Restore Nandroid of my Lego Rom
    7) Have my old Lego Rom with the new radio
    02-09-2011 05:50 PM
  21. NicksOptimus's Avatar
    Please. Can one of you Android gurus make a video for the rest of us? Also, while installing custom recovery, we did a nandroid backup so what is that used for?
    Can we simply not use the custom recover to reload the original factory image and then remove the custom recovery?
    02-09-2011 06:06 PM
  22. uberjam545's Avatar
    couldn't you just wipe everything, restore a nand backup that you made before switching to a custom rom flash the default kernal, remove the custom recovery and then just use z4root to unroot your phone?
    02-09-2011 06:20 PM
  23. IRBanite's Avatar
    I'm trying to return to stock as well. Did you find an answer for this? I was wondering the same thing. -thanks
    02-10-2011 04:58 PM
  24. htc.user's Avatar
    me too, i don't understand how i managed to root this phone in the first place because i when i followed the mac post, the adb push command worked. i have both mac and pc (both virtual and tangible), and i receive the adb: not found. please help when anyone gets a chance. the phone still works great. just want to return to stock to update to vc.
    02-10-2011 05:15 PM
  25. kingdavidbaker's Avatar
    ADB has to be run directly from the directory where it was installed which on a pc is generally c:/android/platform-tools. If you add that directory to the windows "path" environment variable then you don't have to cd to that directory in order to run adb...otherwise you must be in that directory or the command will not function.
    02-10-2011 08:39 PM
291 1234 ...
