sabauman
Active member
nope its not working. i just flashed the thunderROM 1.5 and same thing just goes to the Android system recovery... i still have the existing nand i first backed up in the sdcard/nandroid if that helps.
also i read on the other thread about unrooting your phone. i got up to the point where i had to do flash_image recovery recovery.img (but for the nand backup i have, there is no recovery.img).
thanks
I had to replace the nand with the version the instructions provided. That worked for me. that has the recovery.img in it.
