Under
menu->settings->applications->development->USB debugging
Thats the issue right there..
Im in a constant recovery loop and Im not able to access the main OS to change such settings..
I have tryed all my Nand flashes and even used a stock Nand flash thats found here for my Opti V:
STOCK OPTI V Nand BACKUP
& within "Mounts" on the recovery menu the only thing thats mounted seems to be the "/cache"...
Im rather new to this so bear with me if you could please..
In short though thats my main issue as the phone doesn't seem to have the debugging mode enabled..
Thought that setting would be set within the Nand backup witch I know the first backup I had done had the USB debugging mode on..
Any further help would be greatly appreciated..
