06-23-2014 10:18 PM
89 1234
tools
  1. BoshWadeJames's Avatar
    my lg optimus v only goes to the clockworkmod recovery screem is it brickt?
    06-18-2011 02:51 AM
  2. scrosler's Avatar
    Wow, this worked perfect for me! The only change to the instructions given by OP were to use Emergency mode instead of Diag mode. Everything else was spot on. But this is strange, when it started back up it had all my settings. It wasn't like it was brand new. It still had all my apps (minus SuperUser), wallpapers, etc. I thought it would restore all that to factory default. I went to settings and did a Privacy reset and now I am back to 100% stock.
    Great write up!
    06-18-2011 01:09 PM
  3. lilaznbeatupbag's Avatar
    This is my log:
    05:20:36 : Launching SW update
    05:20:36 : Unpacking KDZ
    05:20:39 : KDZ file extraced
    05:20:39 : Extract file error
    05:20:41 : ===FINISHED===
    Please help
    Also, it did say "Not Responding" on my first attempt, but it didn't say downloading on my screen. After subsequent attempts, it did not say "Not Responding."
    06-29-2011 05:22 AM
  4. anthonyebony1's Avatar
    Were you able to figure out how to unbrick your optimus v? I'm in the same boat. I tried flashing to the Sprint VC rom and my phone would not boot just hangs at the spring logo (i know, stupid, probably shouldn't of done that =)). Now I'm trying to restore to the Virgin Mobile stock rom, but I get the same fatal error in the LG update tool.
    Did you figure out how to unbrick? Do you know how to get the Optimus V into emergency mode (i can't get the buttons in the OP to work)? Any tips would be much appreciated!
    Thanks!
    recovery mode : volume- and home and power button... emergency mode is : volume- and camera(bottom side button) and search button(magnifine glass) then insert usb... no power button.. usb turns on by its self
    thekraven likes this.
    07-20-2011 06:14 PM
  5. bwoodz21's Avatar
    ok so im new to rooting. i was able to finally to do it with the help of most of you guys so thanks. now da bad news i didnt kno not to factory reset my phone. so i was stuck on clockworkmod recovery. i was there for two days. now where i am i downloaded and used Xionia CWMA 12518.4 VM and booted from my sd card. now i turned it on it tries and load it reboots then stays on the lg boot screen. i have the optimus s and i dont kno even if i was posed to use that reboot. and if it does work would anyone kno how long the boot process would take, or did i screw that phone up royaly
    07-29-2011 04:45 PM
  6. ZuTuNuPu's Avatar
    Hello, and I am having a problem. I rooted my phone (LG Optimus V) a while back, and had no problems. But until recently i was having problems with the apps starting to just force close, so i decided to go to the phone settings and click on factory reset. Then when it was booting fastboot came up, so I didnt think anything of it and removed my battery and replaced it (like i have done before) but now no matter what i try to do the phone goes into fastboot mode.
    Here is what fast boot says:
    Fastboot mode started
    gpio_i2c: invalid khz: 0
    bl: i2c write error
    udc_start()
    -- suspend --
    -- suspend --
    -- reset --
    -- portchange --
    -- reset --
    -- portchange --
    fastboot: processing commands
    -- suspend --
    -- suspend --
    -- reset --
    EP1/out FAIL nfo=40 pg0=ea000
    -- suspend --
    usb_read() transaction failed
    -- reset --
    -- portchange --
    -- suspend --
    fastboot: oops!
    And i tried all the tuts that this site has on unbricking and such, but to no success. I would forever be in debt to whoever can help me with this phone.
    07-30-2011 10:59 PM
  7. macworldwizardz's Avatar
    Hey Guys, I NEED IMMEDIATE HELP! My phone is bricked and I just tried to run the exe file, booted into recovery, etc. The program says that there is a file extract error. PLEASE HELP!
    08-14-2011 12:28 PM
  8. Pythaules's Avatar
    Introduction:
    All of you have probably heard of zefie's post "[How-To] Unroot your phone and return to stock" which can be found in the stickys. Other than unrooting and returning to stock, it's a great way to unbrick your phone. Okay, but let's say that this didn't work out right for some reason. Perhaps you have a segmentation in your cache, system, or userdata partition due to a flashing or updating malfunction. Perhaps you don't have Nandroid Recovery. Well, no fear because there is a way to still unbrick your phone from stock recovery as I've discovered in relentless phone bricking. I've never tried this method in which there was no recovery but I believe it would work.
    Step 1:
    Download LG mobile update software. Run the program and click "Install USB Driver". Pick which carrier have from the drop-down menu i.e. Sprint. Then double-click where it says "LGLS670". Follow the installation instructions. Ignore the archives that pop-up at the end. These are just back-ups of what has already been installed.
    Step 2:
    Download KDZ_FW_UPD, a fancy Russian software (now translated to English). Extract it and install msxml.msi. The program will hang/crash if you don't.
    Step 3:
    Download the original firmware for the Optimus S. For the curious, the authentication in the url (ASPRCQ) can be found here: http://csmg.lgmobile.com:9002/csmg/b...sp?model=LS670 and the name of the firmware file can be found here: http://csmg.lgmobile.com:9002/csmg/b...A00000284EEC0A (had to enter my serial number on some site to get to here).
    If you run into an extraction error when KDZ calls the LG Software Update tool then it's likely that there was an error in downloading or storing the file. To be sure that this is the case, compare with this MD5 checksum "54d830c33567fccbb550f879a2ede136". I recommend using MD5sums, a free command-line based checksum utility.
    If the checksum doesn't match, then download from one of these third-party sources:
    zefie
    2shared
    Step 4:
    Rename the extension of the cabinet file to "kdz" rather than "cab". If you don't see the extension: open a (any) folder, click organize, folder and search options, view tab, and uncheck the box that says "Hide extensions for known file types". Hit apply and ok.
    Step 5:
    Open KDZ_FW_UPD as administrator by choosing "Run as administrator" in the right-click menu. Once it's open, set the type to "CDMA" and the mode to "DIAG". The people over at XDA Developers will often tell you to set it to "3gqct" and "EMERGENCY MODE", ignore this as it will not work properly.
    Step 6:
    Click the open folder icon and select the kdz file which you downloaded. Plugin your phone, go into recovery mode (Hold Power+Volume Up+Home from Power Off), and click "Launch Software Update". It will say [Not Responding] for a moment, this is normal. Don't freak out. You should now have a red LG logo on your phone screen that says downloading. KDZ_FW_UPD will output a log file that looks like this:
    Code:
     [R&D Test Tools Log File]
    12:29:00 : Launching SW update
    12:29:00 : Unpacking KDZ
    12:29:01 : KDZ file extraced
    12:29:06 : Files were extracted.
    12:29:06 : LGMobileDL Load.
    12:29:06 : Port = -1
    12:29:06 : Connecting to phone
    12:29:15 : Check Phone mode = 1
    12:29:22 : Phone type check.......
    12:29:22 : LGMobileDL.DLL Loading....
    12:29:22 : _SetAuthMark Ok : wAuthMark(5205)
    12:29:22 : _DetachDLL Call
    12:29:22 : _DetachDLL Call End
    12:29:22 : Param : Path = C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb
    12:29:22 : Param : moduleDir =
    12:29:22 : Param : waitTime = 33000
    12:29:22 : Param : UsbHighSpeed = 0
    12:29:22 : Param : PhoneMode = 1
    12:29:22 : Param : BinVersion = LS670ZV9_20.S9_20.P60671
    12:29:22 : Param : AuthMark = 5205
    12:29:22 : Call fn_StartUpgrade
    12:29:23 : CDMA: wParam = 20, lParam = 570
    12:29:23 : Model Dll Msg Not Found(20, 570)
    12:29:37 : CDMA: wParam = 4, lParam = 0
    12:29:37 : Step : DLOAD Change
    12:29:49 : CDMA: wParam = 5, lParam = 1
    12:29:49 : Step : Main Binary Download to SDRAM
    12:29:49 : CDMA: wParam = 5, lParam = 0
    12:29:54 : CDMA: wParam = 5, lParam = 1
    12:29:58 : CDMA: wParam = 5, lParam = 2
    12:30:02 : CDMA: wParam = 5, lParam = 3
    12:30:07 : CDMA: wParam = 5, lParam = 4
    12:30:11 : CDMA: wParam = 5, lParam = 5
    12:30:15 : CDMA: wParam = 5, lParam = 6
    12:30:19 : CDMA: wParam = 5, lParam = 7
    12:30:24 : CDMA: wParam = 5, lParam = 8
    12:30:28 : CDMA: wParam = 5, lParam = 9
    12:30:32 : CDMA: wParam = 20, lParam = 552
    12:30:32 : Model Dll Msg Not Found(20, 552)
    12:30:32 : CDMA: wParam = 5, lParam = 10
    12:30:36 : CDMA: wParam = 5, lParam = 11
    12:30:40 : CDMA: wParam = 5, lParam = 12
    12:30:45 : CDMA: wParam = 5, lParam = 13
    12:30:49 : CDMA: wParam = 5, lParam = 14
    12:30:53 : CDMA: wParam = 5, lParam = 15
    12:30:57 : CDMA: wParam = 5, lParam = 16
    12:31:02 : CDMA: wParam = 5, lParam = 17
    12:31:06 : CDMA: wParam = 5, lParam = 18
    12:31:10 : CDMA: wParam = 5, lParam = 19
    12:31:14 : CDMA: wParam = 5, lParam = 20
    12:31:19 : CDMA: wParam = 5, lParam = 21
    12:31:23 : CDMA: wParam = 5, lParam = 22
    12:31:27 : CDMA: wParam = 5, lParam = 23
    12:31:31 : CDMA: wParam = 5, lParam = 24
    12:31:36 : CDMA: wParam = 5, lParam = 25
    12:31:40 : CDMA: wParam = 5, lParam = 26
    12:31:44 : CDMA: wParam = 5, lParam = 27
    12:31:48 : CDMA: wParam = 5, lParam = 28
    12:31:52 : CDMA: wParam = 5, lParam = 29
    12:31:57 : CDMA: wParam = 20, lParam = 461
    12:31:57 : Model Dll Msg Not Found(20, 461)
    12:31:57 : CDMA: wParam = 5, lParam = 30
    12:32:01 : CDMA: wParam = 5, lParam = 31
    12:32:05 : CDMA: wParam = 5, lParam = 32
    12:32:10 : CDMA: wParam = 5, lParam = 33
    12:32:14 : CDMA: wParam = 5, lParam = 34
    12:32:18 : CDMA: wParam = 5, lParam = 35
    12:32:22 : CDMA: wParam = 5, lParam = 36
    12:32:27 : CDMA: wParam = 5, lParam = 37
    12:32:31 : CDMA: wParam = 5, lParam = 38
    12:32:35 : CDMA: wParam = 5, lParam = 39
    12:32:39 : CDMA: wParam = 5, lParam = 40
    12:32:44 : CDMA: wParam = 5, lParam = 41
    12:32:48 : CDMA: wParam = 5, lParam = 42
    12:32:52 : CDMA: wParam = 5, lParam = 43
    12:32:57 : CDMA: wParam = 5, lParam = 44
    12:33:01 : CDMA: wParam = 5, lParam = 45
    12:33:05 : CDMA: wParam = 5, lParam = 46
    12:33:09 : CDMA: wParam = 5, lParam = 47
    12:33:14 : CDMA: wParam = 5, lParam = 48
    12:33:18 : CDMA: wParam = 5, lParam = 49
    12:33:22 : CDMA: wParam = 5, lParam = 50
    12:33:22 : CDMA: wParam = 20, lParam = 378
    12:33:22 : Model Dll Msg Not Found(20, 378)
    12:33:26 : CDMA: wParam = 5, lParam = 51
    12:33:30 : CDMA: wParam = 5, lParam = 52
    12:33:35 : CDMA: wParam = 5, lParam = 53
    12:33:39 : CDMA: wParam = 5, lParam = 54
    12:33:43 : CDMA: wParam = 5, lParam = 55
    12:33:48 : CDMA: wParam = 5, lParam = 56
    12:33:52 : CDMA: wParam = 5, lParam = 57
    12:33:56 : CDMA: wParam = 5, lParam = 58
    12:34:01 : CDMA: wParam = 5, lParam = 59
    12:34:05 : CDMA: wParam = 5, lParam = 60
    12:34:09 : CDMA: wParam = 5, lParam = 61
    12:34:13 : CDMA: wParam = 5, lParam = 62
    12:34:18 : CDMA: wParam = 5, lParam = 63
    12:34:22 : CDMA: wParam = 5, lParam = 64
    12:34:26 : CDMA: wParam = 5, lParam = 65
    12:34:31 : CDMA: wParam = 5, lParam = 66
    12:34:35 : CDMA: wParam = 5, lParam = 67
    12:34:39 : CDMA: wParam = 5, lParam = 68
    12:34:44 : CDMA: wParam = 5, lParam = 69
    12:34:48 : CDMA: wParam = 20, lParam = 293
    12:34:48 : Model Dll Msg Not Found(20, 293)
    12:34:48 : CDMA: wParam = 5, lParam = 70
    12:34:52 : CDMA: wParam = 5, lParam = 71
    12:34:57 : CDMA: wParam = 5, lParam = 72
    12:35:01 : CDMA: wParam = 5, lParam = 73
    12:35:05 : CDMA: wParam = 5, lParam = 74
    12:35:10 : CDMA: wParam = 5, lParam = 75
    12:35:15 : CDMA: wParam = 5, lParam = 76
    12:35:20 : CDMA: wParam = 5, lParam = 77
    12:35:24 : CDMA: wParam = 5, lParam = 78
    12:35:28 : CDMA: wParam = 5, lParam = 79
    12:35:33 : CDMA: wParam = 5, lParam = 80
    12:35:38 : CDMA: wParam = 5, lParam = 81
    12:35:42 : CDMA: wParam = 5, lParam = 82
    12:35:46 : CDMA: wParam = 5, lParam = 83
    12:35:50 : CDMA: wParam = 5, lParam = 84
    12:35:54 : CDMA: wParam = 5, lParam = 85
    12:35:59 : CDMA: wParam = 5, lParam = 86
    12:36:03 : CDMA: wParam = 5, lParam = 87
    12:36:07 : CDMA: wParam = 5, lParam = 88
    12:36:11 : CDMA: wParam = 5, lParam = 89
    12:36:16 : CDMA: wParam = 5, lParam = 90
    12:36:20 : CDMA: wParam = 5, lParam = 91
    12:36:24 : CDMA: wParam = 5, lParam = 92
    12:36:28 : CDMA: wParam = 5, lParam = 93
    12:36:32 : CDMA: wParam = 5, lParam = 94
    12:36:37 : CDMA: wParam = 5, lParam = 95
    12:36:41 : CDMA: wParam = 5, lParam = 96
    12:36:45 : CDMA: wParam = 5, lParam = 97
    12:36:49 : CDMA: wParam = 5, lParam = 98
    12:36:54 : CDMA: wParam = 5, lParam = 99
    12:36:58 : CDMA: wParam = 5, lParam = 100
    12:36:58 : CDMA: wParam = 6, lParam = 0
    12:36:58 : Step : Main Binary Flash Erase
    12:37:25 : CDMA: wParam = 20, lParam = 110
    12:37:25 : Model Dll Msg Not Found(20, 110)
    12:37:25 : CDMA: wParam = 8, lParam = 0
    12:37:25 : Step : Phone Reset(DLL Cmd)
    12:38:02 : CDMA: wParam = 10, lParam = 1
    12:38:02 : Step : C Drive Write
    12:38:02 : CDMA: wParam = 10, lParam = 2
    12:38:02 : CDMA: wParam = 10, lParam = 4
    12:38:02 : CDMA: wParam = 10, lParam = 6
    12:38:02 : CDMA: wParam = 10, lParam = 8
    12:38:02 : CDMA: wParam = 10, lParam = 10
    12:38:02 : CDMA: wParam = 10, lParam = 12
    12:38:02 : CDMA: wParam = 10, lParam = 14
    12:38:02 : CDMA: wParam = 10, lParam = 16
    12:38:02 : CDMA: wParam = 10, lParam = 18
    12:38:03 : CDMA: wParam = 10, lParam = 20
    12:38:03 : CDMA: wParam = 10, lParam = 22
    12:38:03 : CDMA: wParam = 10, lParam = 24
    12:38:03 : CDMA: wParam = 10, lParam = 26
    12:38:03 : CDMA: wParam = 10, lParam = 28
    12:38:03 : CDMA: wParam = 10, lParam = 30
    12:38:03 : CDMA: wParam = 10, lParam = 32
    12:38:03 : CDMA: wParam = 10, lParam = 34
    12:38:03 : CDMA: wParam = 10, lParam = 36
    12:38:03 : CDMA: wParam = 10, lParam = 38
    12:38:04 : CDMA: wParam = 10, lParam = 40
    12:38:04 : CDMA: wParam = 10, lParam = 42
    12:38:04 : CDMA: wParam = 10, lParam = 44
    12:38:04 : CDMA: wParam = 10, lParam = 46
    12:38:04 : CDMA: wParam = 10, lParam = 48
    12:38:04 : CDMA: wParam = 10, lParam = 50
    12:38:04 : CDMA: wParam = 10, lParam = 52
    12:38:04 : CDMA: wParam = 10, lParam = 54
    12:38:04 : CDMA: wParam = 10, lParam = 56
    12:38:04 : CDMA: wParam = 10, lParam = 58
    12:38:05 : CDMA: wParam = 10, lParam = 60
    12:38:05 : CDMA: wParam = 10, lParam = 62
    12:38:05 : CDMA: wParam = 10, lParam = 64
    12:38:05 : CDMA: wParam = 10, lParam = 66
    12:38:05 : CDMA: wParam = 10, lParam = 68
    12:38:05 : CDMA: wParam = 10, lParam = 70
    12:38:05 : CDMA: wParam = 10, lParam = 72
    12:38:05 : CDMA: wParam = 10, lParam = 74
    12:38:05 : CDMA: wParam = 10, lParam = 76
    12:38:05 : CDMA: wParam = 10, lParam = 78
    12:38:06 : CDMA: wParam = 10, lParam = 80
    12:38:06 : CDMA: wParam = 10, lParam = 82
    12:38:06 : CDMA: wParam = 10, lParam = 84
    12:38:06 : CDMA: wParam = 10, lParam = 86
    12:38:06 : CDMA: wParam = 10, lParam = 88
    12:38:06 : CDMA: wParam = 10, lParam = 90
    12:38:06 : CDMA: wParam = 10, lParam = 92
    12:38:06 : CDMA: wParam = 10, lParam = 94
    12:38:06 : CDMA: wParam = 10, lParam = 96
    12:38:06 : CDMA: wParam = 10, lParam = 98
    12:38:07 : CDMA: wParam = 10, lParam = 100
    12:38:07 : CDMA: wParam = 20, lParam = 0
    12:38:07 : Model Dll Msg Not Found(20, 0)
    12:38:07 : CDMA: wParam = 12, lParam = 1
    12:38:07 : Step : UPDATE FINISHED!
    12:38:07 : ResetStartInfo() Call
    12:38:07 : _DetachDLL Call
    12:38:07 : _DetachDLL Call End
    12:38:07 : FreeLibrary Call
    12:38:09 : FreeLibrary Call End
    12:38:09 : ResetStartInfo() Call End
    12:38:09 : OnModelDllMsg(OnMsgFromModelDll-CDMA) delete m_pLGCyonUpdate
    12:38:09 : ===FINISHED===
    Stuck at LG logo screen:
    I haven't tried this while stuck at the black and white LG logo screen but you can try it. It's worth a shot. If it doesn't work then you're going to have to write the original firmware on the flash via quantum tunneling. No, but seriously: if you can't get it to work; go to Sprint and tell them that you were accepting an OTA update, your phone shut off in the middle of it, and now it won't boot up. Then Sprint will send it to LG and then they'll fix it via quantum tunneling. Sprint will just give you a new phone while they do all that fancy stuff. If Sprint can't help then consult LG.
    I have tried and tried to find the firmware for this phone, and still nothing. I was able to download the one from 2shared, but get an error when trying to open it that says it was unable to open. Is there another version out there somewhere that might work? I have looked everywhere, and been unable to find anything but that one.
    08-15-2011 01:34 AM
  9. blackops1125's Avatar
    hello users im just trying to find out if is theres anything that i can do to unbrick my evo it doesnt turn on no ligth when its plug in to the charger im new at this so i rooted my evo and i was trying to flash the rom and thats when the tragedy happens first i did a back up then the system ask me to reboot so i did it and once start the reboot something went wrong that the screen went black and the next thing i did when i see the droid with the triangle was take the battery out put it back but now it doesnt do nothing
    Try looking in the Evo forums, this is for Optimus.
    sent from my CM7 gingerbread Optimus S
    Always happy to help, hit that thanks button if I did
    08-15-2011 04:43 AM
  10. ukwildcatsboston's Avatar
    Where can you get the KDZ file??
    10-04-2011 09:01 PM
  11. elyssanguyen1's Avatar
    HELP!!!!!!! I'm having a problem.... help!! im getting this, im trying but i have no idea what i am doing wrong... someone help please... i cant exchange or anything.... only other option is buying a new phone.
    10-29-2011 09:10 PM
  12. elyssanguyen1's Avatar
    Now i got it to go this far but not the whole way.... and now its stuck on the LG logo again.
    121jose likes this.
    10-29-2011 09:33 PM
  13. un1ocked's Avatar
    mine had too much bad blocks, cannot back alive
    11-28-2011 09:41 AM
  14. donboy71's Avatar
    I've got an Optimus V, what mode do I need to be in? and how do I boot in to that mode?
    12-02-2011 12:01 AM
  15. unknowntech4u's Avatar
    what's TEP??
    12-28-2011 07:56 AM
  16. eliment's Avatar
    i just keep getting file extract error on my kdz files...any one have any ideas how to get passed that..
    01-03-2012 12:25 AM
  17. packers pro's Avatar
    What is brick
    01-23-2012 01:17 PM
  18. hlxanthus's Avatar
    What is brick
    When your phone is fubar'd to the point where it no longer functions as a phone, and is now only good as a paper weight or a "brick"
    01-23-2012 01:46 PM
  19. tommyb13662's Avatar
    02:37:12 : Launching SW update
    02:37:12 : Unpacking KDZ
    02:37:13 : KDZ file extraced
    02:37:13 : Files were extracted.
    02:37:13 : LGMobileDL Load.
    02:37:13 : Port = -1
    02:37:13 : Connecting to phone
    02:37:21 : Check Phone mode = 2
    02:37:23 : Phone type check.......
    02:37:23 : LGMobileDL.DLL Loading....
    02:37:24 : _SetAuthMark Ok : wAuthMark(25378)
    02:37:24 : LoadLibrary Error(126)
    02:37:26 : ===FINISHED===
    I keep getting this error... from what i have read i keep getting a bad cab file thats corrupted some how. where can i get a good file? thank you all since i bought this phone bricked i am really hoping it was worth the monies.
    ldodda likes this.
    01-30-2012 01:39 AM
  20. ldodda's Avatar
    i don't know if any one has mentioned this so here goes
    if you are getting errors on the kdz files trying to extract and failing...
    try using UpTestEX_original.exe with windows enabler running
    load the cab file (not renamed) and hit the button it should make a legal and crypted kdz file that will work with the loader...
    now if anyone can tell me how to get a 100 percent download with ANYTHING i might be able to unbrick my optimus s
    i also have a new in box optimus s if i need to get anything off of it that will help me fix the one stuck at the lg logo
    jccjr1982 likes this.
    01-31-2012 11:55 PM
  21. tsunamio's Avatar
    why can't i open the link? it's blank...it's there a software I need to dowload to open the link?
    02-11-2012 06:16 PM
  22. XxGr33dxX's Avatar
    hey guys can you tru to help me my phones all screwy too i try puttin pd15img.zip on my phone but it loads and dosent do any thing the main problem is that if i plug it in it will start by its self and then shut off and it dosent stop doing that at all and when i try to factory reset it just shuts off and does the restsrt thing again
    03-13-2012 06:58 PM
  23. ALFPLAY's Avatar
    help my android recovery has a black screen and its bricked what can i do plese help meee!!!!
    03-20-2012 02:34 PM
  24. Va1ha11a's Avatar
    look at the stickies
    Ksjuggalo likes this.
    03-20-2012 03:41 PM
  25. zethman's Avatar
    I have an lg Optimus S Virgin Mobile which is getting hung up at the lg logo. Ive been trying to download the original firmware. but the links dont seem to work very well. I was wondering if anyone could hook me up with the correct files. im at a pretty big loss here.
    04-11-2012 07:41 PM
89 1234
