Page 4 of 4 FirstFirst 1234
Results 76 to 84 of 84
Like Tree6Likes
  1. #76
    truwrxtacy's Avatar
    Posts
    Global Posts
    10 Global Posts
    Default Re: [HOW-TO] Unbrick your phone using KDZ
    hey guys, the OP's DL link for the software is bad. anyone got a saved copy of the software for the optimus somewhere?
  2. #77
    I managed to brick my Optimus T. I was trying to recover using the same methods (different files, of course) but I keep getting this response when I try to use the KDZ:
    [R&D Test Tools Log File]
    21:31:49 : Launching SW update
    21:31:49 : Unpacking KDZ
    21:31:51 : KDZ file extraced
    21:31:52 : Files were extracted.
    21:31:52 : LGMobileDL Load.
    21:31:52 : Port = -1
    21:31:52 : Connecting to phone
    21:31:52 : PHONE WAS NOT FOUND!
    21:31:54 : ===FINISHED===
    So my phone is stuck at the LG logo and won't enter recovery mode or anything else. It only turns on to the LG boot screen and nothing else. If I plug it in the same result. Have I broken this beyond repair?
  3. #78
    Help I Seem To Have Tried All The Possible Ways And I Seem To Get This Message Alot
    I Dont Know What To Do Im In A Boot ClockworkMod Recovery And It Sucks
    I Would Greatly Appreciate It If Someone Helps
    00:37:59 : Launching SW update
    00:37:59 : Unpacking KDZ
    00:38:37 : KDZ file extraced
    00:39:16 : Files were extracted.
    00:39:16 : LGMobileDL Load.
    00:39:18 : Port = 0
    00:39:20 : Connecting to phone
    00:39:30 : Check Phone mode = 2
    00:39:37 : Phone type check.......
    00:39:37 : LGMobileDL.DLL Loading....
    00:39:38 : _SetAuthMark Ok : wAuthMark(30913)
    00:39:38 : _DetachDLL Call
    00:39:38 : _DetachDLL Call End
    00:39:38 : Param : Path = C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\DZ_GT540AT-00-V20e-CIS-XXX-MAR-22-2011.dz
    00:39:38 : Param : moduleDir =
    00:39:38 : Param : waitTime = 33000
    00:39:38 : Param : UsbHighSpeed = 0
    00:39:38 : Param : PhoneMode = 2
    00:39:38 : Param : BinVersion = 20E_234-150-64
    00:39:38 : Param : AuthMark = 30913
    00:39:38 : Call fn_StartUpgrade
    00:41:57 : CDMA: wParam = 100, lParam = 502
    00:41:57 : Step : Upgrade Error2 - Error Code : 502
    00:41:57 : ResetStartInfo() Call
    00:41:57 : _DetachDLL Call
    00:41:57 : _DetachDLL Call End
    00:41:57 : FreeLibrary Call
    00:41:57 : FreeLibrary Call End
    00:41:57 : ResetStartInfo() Call End
    00:42:03 : ===FINISHED===
    00:42:12 : OnModelDllMsg(OnMsgFromModelDll-CDMA) delete m_pLGCyonUpdate
  4. #79
    Default
    Quote Originally Posted by Va1ha11a View Post
    look at the stickies
    Unfortunately that's the same answer I had...and
    SEARCH IS YOUR FRIEND.. GOOGLE IS YOUR FAIRY GODMOTHER.
    having shouted that...remember its all about relevance. Fewest terms with the most relevance.
    And read the stickies. Most all your answers can be found in there or linked to in there.
    Use the Force-Read the Rules-Check the Stickies-Search It-Search It Again...now ask...
  5. #80
    I got to:
    15:52:05 : CDMA: wParam = 7, lParam = 99
    15:52:09 : CDMA: wParam = 7, lParam = 100
    15:52:36 : CDMA: wParam = 20, lParam = 110
    15:52:36 : Model Dll Msg Not Found(20, 110)
    15:52:36 : CDMA: wParam = 8, lParam = 0
    15:52:36 : Step : Phone Reset(DLL Cmd)
    15:53:01 : CDMA: wParam = 100, lParam = 89
    15:53:01 : Step : Upgrade Error2 - Error Code : 89
    15:53:01 : ResetStartInfo() Call
    15:53:01 : _DetachDLL Call
    15:53:01 : _DetachDLL Call End
    15:53:01 : FreeLibrary Call
    15:53:03 : FreeLibrary Call End
    15:53:03 : ResetStartInfo() Call End
    15:53:03 : CDMA: wParam = 20, lParam = 0
    15:53:03 : Model Dll Msg Not Found(20, 0)
    15:53:03 : ===FINISHED===
    15:53:17 : OnModelDllMsg(OnMsgFromModelDll-CDMA) delete m_pLGCyonUpdate
    A dialog box pops pop, said 'wParam = 100, lParam = 89' and my phone started flashing non-stop, nothing else. Please help!!!
    On the Device Manager, I saw devices were installed after my phone was connected:
    1) Modem -> LGE Android Platform USB Modem
    2) Ports (COM & LPT) ->
    3) Universal Serial Bus controllers
    HELP! What did I do wrong?????
  6. #81
    Did all this, and my log looks identical to the one posted.
    But I'm still stuck at the flashing "Android" screen.
    Any help would be tremendously appreciated.
  7. #82
    thewraith420's Avatar
    Posts
    ROM
    Changes Daily
    Quote Originally Posted by M8R-4j1xp8 View Post
    If your getting to the flashing android logo I think your Ok. Try holding home-volume down - power to boot to recovery it should take you to stock recovery, wipe data/factory reset then reboot
    Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ baseband
  8. #83
    Hey, ive tried kdz.kp500,and lgnpst lgnpst says i have to many bad blocks ,kdz says i have an error towards the end ,kp500 flashes all and stops at 99% and then on my phone it only has an lg logo sooo im bricked ive tried all ls670 cabs and the zv5 cab and zv5 kdz sammyz said something about an lg optimus u firmware and that May be the only way to fix so yeah please help
  9. #84
    Quote Originally Posted by un1ocked View Post
    mine had too much bad blocks, cannot back alive
    mine said the same thing in LGNPST but what does it mean ??
