Page 11 of 22 FirstFirst ... 891011121314 ... LastLast
Results 251 to 275 of 532
Like Tree2Likes
  1. #251
    bullman2410's Avatar
    Posts
    ROM
    ThunderROM 1.8.3; CM7
    Default
    rcr0413 are you rooted already on V9? If so you shouldn't have to use KP500 to upgrade to VD, atleast I didn't. All you have to do is is us LG Updater tool to upgrade.
    If I recall steps are as follows, but there are different threads in here that talk about it.
    1)Nand back up your current settings in your custom recovery.
    2)Place whatever custom ROM you want on the root of your SD card
    3)Use LG Upgrader tool to upgrade from V9 to VD. Once upgrade is complete phone completely reboots. Once is rebooted power phone off.
    4) Power into your custom recovery with the volume down, home, and power button combo. Make another nandroid backup. Flash whatever VD custom rom (ThundeRom, Nrom, etc.) you want to run in your custom recovery. Reboot from there and you should be good to go.
    Those steps worked for me, but again I'd search the threads because its explained elsewhere.
  2. Thread Author  Thread Author    #252
    Default
    Both your errors have to do with a problem with the cab file or filesystem. It could either be:
    1) cannot find file
    a) not in the same directory as KP500
    b) renamed improperly (even if it looks ok under windows explorer)
    2) file problem
    a) corrupted cab file
    b) incomplete cab file
    3) file system problem
    a) permission problem
    b) out of space problem
    c) create directory problem
    Eventually you'll figure it out and in hindsight it'll be obvious what was wrong, but until then it'll seem like everything was done correctly. I don't say that for all errors, but with this particular one, that has been my experience.
    I suggest going back through the instructions, paying special attention to steps (e) through (i)
    [How-To] Rooting LS670ZVH
    Installed ZVH by mistake? Use simple update.zip to revert to ZVD / Froyo
  3. #253
    Posts
    ROM
    Default
    Thanks for the advice. Ill start everything over next time I have her phone and run check sum as well. My cab file could have gotten corrupted, who really knows yet.
    Sent from my NookColor using Tapatalk
  4. #254
    Dorion-Grey's Avatar
    Posts
    ROM
    Drew's CM7 build
    Default
    Quote Originally Posted by bullman2410 View Post
    i ran fsum it matches what the instuctions say, if the .cab is corrupt this would not match correct? oh and this is my log:
    [BOX="error log"]16:58:39 : [C:\LGMobileUpgrade] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    16:58:39 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
    16:58:39 : Start Date : 2011-04-17 16:58:39
    16:58:39 : -------- Buyer Test mode ---------
    16:58:39 : [C:\ProgramData\LGMOBILEAX\Phone] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    16:58:39 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
    16:58:39 : *****CheckOS Start********
    16:58:39 : Microsoft_Windows_Vista Home Edition_
    16:58:39 : *****CheckPCSyncPrograms Start*****
    16:58:39 : PCSyncPrograms Not Found
    16:58:39 : SetEmerModeAT()
    16:58:39 : _IsConnectedPhone Call
    16:58:45 : _IsConnectedPhone(1)
    16:58:45 : 0 - NotConnected.
    16:58:45 : 1 - Normal connect success
    16:58:45 : 2 - Emergency connect success
    16:59:06 : Checking the connection with the cell phone...
    16:59:06 : dwWaitResetTime(40000 ms)
    16:59:07 : Phone Mode(1)
    16:59:07 : *****GetPhoneType Start*****
    16:59:10 : Phone Type : CDMA
    16:59:10 : *****Start GetPreviousStep*****
    16:59:10 : _GetPreviousStep(dwStep:0xffff)
    16:59:10 : _SetPhoneNumber retval=1
    16:59:10 : *****GetPhoneModel Start*****
    16:59:12 : *****GetPhoneBinaryVersion Start*****
    16:59:12 : Phone Bin Version : LS670ZVD_12
    16:59:12 : *****Get ESN / IMEI / MEID Start*****
    16:59:15 : ESN/IMEI/MEID : A0000028DFE667
    16:59:15 : *****GetPhoneNumber Start*****
    16:59:17 : Phone Number : A0000028DFE667
    16:59:17 : ÀÎÁõ °Ë»ç ÆÄ¶ó¸ÞŸ - ESN_IMEI : A0000028DFE667, Model :
    16:59:17 : *******CheckBinVersion***************
    16:59:17 : New Bin Version(LS670ZV9_20), Current Ver(LS670ZVD_12)
    16:59:17 : ÃֽйöÀüÀ̹ǷΠ¾÷±×·¹À̵带 ÇÒ Çʿ䰡 ¾øÀ½.
    16:59:20 : _GetAuthMark : wAuthMark(2739)
    16:59:20 : Wait 3Sec
    16:59:26 : _SetAuthMark Ok : wAuthMark(2739), PhoneMode(1)
    16:59:26 : *****Start _GetBatteryLevel*****
    16:59:28 : Battery(5)
    16:59:29 : ResetPhone...
    16:59:29 : Checking the connection with the cell phone...
    16:59:29 : dwWaitResetTime(40000 ms)
    16:59:59 : _IsConnectedPhone Call
    17:00:05 : _IsConnectedPhone(1)
    17:00:05 : 0 - NotConnected.
    17:00:05 : 1 - Normal connect success
    17:00:05 : 2 - Emergency connect success
    17:00:05 : Phone Mode(1)
    17:00:05 : m_dwBootWaitTime(35600)
    17:00:05 : Checking the connection with the cell phone...
    17:00:05 : dwWaitResetTime(30000 ms)
    17:00:35 : _IsConnectedPhone Call
    17:00:40 : _IsConnectedPhone(1)
    17:00:40 : 0 - NotConnected.
    17:00:40 : 1 - Normal connect success
    17:00:40 : 2 - Emergency connect success
    17:00:40 : Phone Mode(1)
    17:00:40 : Call _ModeOffline()
    17:00:41 : *****CheckPCSyncPrograms Start*****
    17:00:42 : PCSyncPrograms Not Found
    17:00:43 : CLGMobileHttp Class ¼Ò¸ê½ÃÀÛ.
    17:00:43 : CLGMobileHttp Class ¼Ò¸ê...
    17:00:43 : ****************CheckAndDownload********************
    17:00:43 : ******Extract Start C:\LS670ZV9.cab*****
    17:00:43 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
    17:00:43 : ExtractInfo Error(0)
    17:00:43 : Extract cab file error.
    17:00:43 : [C:\ProgramData\LGMOBILEAX\Phone] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    17:00:43 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
    17:00:43 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
    17:00:43 : Page_Error ºÎºÐÀÔ´Ï´Ù
    17:00:43 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
    [/BOX]
    It did everything like it was supposed to till that point so now the phone has no service but it also did not revert to V9 ??
  5. Thread Author  Thread Author    #255
    Default
    Quote Originally Posted by Dorion-Grey View Post
    If your checksum matches, then the cab file is correct. Move on to the other areas I listed.
    It could be a permission problem as well. Are you running as administrator or some lower privileged account?
    Could you perform the second half of step (h) and post the output?
  6. Thread Author  Thread Author    #256
    Default
    While you are at it, perform the second half of step (h) and post the output.
  7. #257
    Posts
    ROM
    Drew's CM7 build
    Default
    Quote Originally Posted by sfhub View Post
    Lol not sure how to address the other areas you listed im kind of noobishly dumb, but as for permissions im on an administartors profile, step (h) output? the dir?
    [BOX="(h) dir"]C:\KP500-Utils-EN-v0.4.2>dir
    Volume in drive C has no label.
    Volume Serial Number is E24B-9178
    Directory of C:\KP500-Utils-EN-v0.4.2
    04/17/2011 06:46 PM <DIR> .
    04/17/2011 06:46 PM <DIR> ..
    03/03/2007 09:02 PM 344,064 fsum.exe
    02/11/2007 03:37 PM 22,133 fsum_ReadMe.txt
    11/14/2008 01:56 PM 155,648 Inf_WebDnld.dll
    08/18/2009 03:49 PM 424,960 KP500-Utils-EN.exe
    08/03/2009 01:15 PM 86,016 LGMUpgradeDL.dll
    04/17/2011 01:50 AM 99,220,700 LS670ZV9.cab
    7 Files(s) 100,704,081 bytes
    2 Dir(s) 54,049,345,536 bytes free[/BOX]
    Also i Turned off power turned on power and service is back to normal
  8. #258
    sblood86's Avatar
    Posts
    ROM
    Quatrimus / CM10
    Default Trying to revert from a Win7 64bit machine
    Honestly I'm not sure if it's an OS issue or something else but I figured win7 was still pertinent. I'm having an issue which I am about to post all the logs for while I'm at it I had a second question.
    I apologize if this isn't really the right thread for this but:
    --Being of a linux background and having played around with several android ports I'm really wondering.
    --Is it not possible to flash the revert image using fastboot?(if so this would actually work in windows to but I would prefer to do everything from linux, I trust the computer more)
    Regardless of my above curiosity I decided to use the outlined method as it is documented to have worked.
    I have installed the LG tool aswell as the drivers for the optimus s. I've confirmed the phone is mounting properly in debug mode in usb by checking deviceman by seeing if ADB was present:
    ADB Interface
    -Android Platform Sooner Single ADB Interface
    I have also confirmed that the LG Android modem is registering
    Modems
    -LGE Android Platform USB Modem
    I confirmed the checksum on the cab file after download and even grabbed yall the dir tree from the KP500 dir:
    Volume Serial Number is D6BC-7CC7
    04/17/2011 04:18 PM <DIR> .
    04/17/2011 04:18 PM <DIR> ..
    04/17/2011 04:18 PM 344,064 fsum.exe
    04/17/2011 04:09 PM 155,648 Inf_WebDnld.dll
    04/17/2011 04:09 PM 424,960 KP500-Utils-EN.exe
    04/17/2011 04:09 PM 86,016 LGMobileDL.dll
    04/17/2011 04:09 PM 450,560 LGMUpgradeDL.dll
    04/17/2011 04:12 PM 99,220,700 LS670ZV9.cab
    6 File(s) 100,681,948 bytes
    2 Dir(s) 86,765,969,408 bytes free
    And well long story short when I actually attempt the flash this is the output I get:
    18:28:56 : [C:\LGMobileUpgrade] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    18:28:56 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
    18:28:56 : Start Date : 2011-04-17 18:28:56
    18:28:56 : -------- Buyer Test mode ---------
    18:28:56 : [C:\ProgramData\LGMOBILEAX\Phone] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    18:28:56 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
    18:28:56 : *****CheckOS Start********
    18:28:56 : Microsoft_Windows_XP_Home Edition_
    18:28:56 : *****CheckPCSyncPrograms Start*****
    18:28:57 : PCSyncPrograms Not Found
    18:28:57 : SetEmerModeAT()
    18:28:57 : _IsConnectedPhone Call
    18:29:12 : _IsConnectedPhone(0)
    18:29:12 : 0 - NotConnected.
    18:29:12 : 1 - Normal connect success
    18:29:12 : 2 - Emergency connect success
    18:29:37 : Checking the connection with the cell phone...
    18:29:37 : dwWaitResetTime(40000 ms)
    18:29:38 : _IsConnectedPhone Call
    18:31:51 : _IsConnectedPhone(1)
    18:31:51 : 0 - NotConnected.
    18:31:51 : 1 - Normal connect success
    18:31:51 : 2 - Emergency connect success
    18:31:51 : Phone Mode(1)
    18:31:51 : *****GetPhoneType Start*****
    18:31:51 : [011,700,147,062,092]Updating is not possible any longer due to a fatal error.\n\n[009,400,102,102,102]Disconnect from and connect the cable into your phone again and remove \nand install the battery and press the [009,700,102,102,102]'Restart'[009,400,102,102,102] button. This will resume the \nupgrade.\n\n\n\n\n\n\n\n\n\n\n\n\nPress the [009,700,102,102,102]Quit[009,400,102,102,102] button to stop the update. (_CheckPhoneType() Error)
    18:31:51 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
    18:31:51 : Page_Error ºÎºÐÀÔ´Ï´Ù
    18:31:51 : ¿©±â´Â Retry ºÎºÐÀÔ´Ï´Ù
    18:31:51 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
    As you can tell I have it running in compat mode for XP, I've tried SPs2 and 3.
    I have tried reseating the usb cable before hitting restart aswell as simply attempting to restart, everytime I get the same outcome.
    Thanks All.
  9. Thread Author  Thread Author    #259
    Default
    If you look at the directory listing I provided in step (h), you are missing the following file:
    08/03/2009 01:15 PM 86,016 LGMobileDL.dll
    Please unpack the KP500 zip file to obtain this file and try again.
    Also, it would be difficult for the revert process to have permanently caused the service problem you described as it has not done any writes to your phone, only reads. If it had gotten to the write stage, then it would be possible, though still not likely.
    Step (h) from first post
    The output of the above "dir" command should look like this:
    (make sure you have at least these 5 files, one file is named LS670ZV9.cab and the file size is 99,220,700)
    (if your directory does not look like this, STOP here, figure out why)
    Volume in drive C is
    02/18/2011 12:48 PM <DIR> .
    02/18/2011 12:48 PM <DIR> ..
    08/03/2009 01:15 PM 450,560 LGMUpgradeDL.dll
    02/11/2011 02:10 PM 99,220,700 LS670ZV9.cab
    5 File(s) 100,337,884 bytes
  10. #260
    Posts
    ROM
    Drew's CM7 build
    Default
    everyone is getting this message what does it mean?
  11. Thread Author  Thread Author    #261
    Default
    Quote Originally Posted by sblood86 View Post
    There is no fastboot support on the phone-side. It was removed by LG. If you find this not to be the case or find a way to add it back, let us know, so we can update the instructions to be much simpler.
    Based on your log, I would say you should try pressing restart a few times to see if it works upon retry. Sometimes it doesn't work on first try but does on retries.
    If that doesn't work, I would say look at a problem with your drivers despite what you have verified so far. See if LG Mobile Updater tool works on its own to read from your phone outside of using it through KP500. If not, try installing the drivers LG Mobile Updater provides on the first screen it gives you. It is just some text that says USB driver and it may not be immediately obvious it is a clickable link to install drivers.
  12. Thread Author  Thread Author    #262
    Default
    It is a generic error LG software puts out for any error. It basically means some error happened and doesn't tell you anything useful. It doesn't tell you that everyone is getting the same error, just that the ones posting an error are getting an error, but we already know that.
    Have you replaced the missing file I posted earlier?
    http://forum.androidcentral.com/lg-o...tml#post832893
  13. #263
    sblood86's Avatar
    Posts
    ROM
    Quatrimus / CM10
    Default drivers failing
    Hey man thanks for answering that and the quick reply.
    Seems you called it:
    I tried running the LG tool alone to see if it could read the phone and it fails to mount it.
    So I uninstalled the LG tool and the drivers and tried re-downloading them all.
    Same issue unfortunately. So I removed all the drivers and the lg software again, this time taking the time to remove all the registry entries as well as the other drivers associated with the phone. Powercycled both the PC and phone with the phone unplugged.
    After boot up I proceeded to download the LG tool again and reinstall both it and the LS670 drivers.
    Connected the phone, it recognizes that it is plugged in and windows immediately installs a GOOGLE Mass storage driver for it as well as mounting it in deviceman as f: this is with the USB storage feature disabled.
    Proceeded to turn on debugging and windows attempts to install all the required drivers.
    I managed to catch the installation screen this time.
    It's trying to load the drivers for 7 devices:
    -LGE Android Platform Composite USB Device - Ready to use.
    -Unidentified Device - Installing driver software... (this does not complete or fail)
    -LGE Andoird Platform USB Serial Port (COM3) - Ready to use.
    -Unidentified Device - Installing driver software.... (same as above and following)
    -USB Mass Storage Device - Ready to use.
    -GOOGLE Mass storage device - Installing driver software...
    What I find particularly odd is that the google mass storage driver works before my turning on debugging mode.
    Obviously before I can make any other attempts I will have to uninstall the present drivers to force windows to search for them again, already tried other methods.
    Before I do that I wanted to see if I was doing something wrong.
    Thanks again.
    Last edited by sblood86; 04-17-2011 at 08:27 PM. Reason: corrected a typo that made no sense
  14. Thread Author  Thread Author    #264
    Default
    The optimus USB port is a multiplexed port. The mass storage is enabled when USB debugging is off and disabled when USB debugging is turned on (in the latter case, the USB device entry for the drive will still be there, but access to the device will fail)
    I believe you need to disable driver signature enforcement for win7 by hitting F8 to get to the advanced boot options. I don't know if I'm recalling correct, but it seemed you were mostly a linux guy but installed win7 just to do the reverting/rooting? If so and you are using some type of Virtual Machine, you might have less trouble just installing winxp, but people have gotten this to work on Win7, so it is doable.
    Oh, and I recall it was a little difficult to get all the USB registry entries removed to do full reinstalls. It might be simpler doing a system restore to a time before you installed any of this.
    Thanked by:
  15. #265
    sblood86's Avatar
    Posts
    ROM
    Quatrimus / CM10
    Default
    I'm going to answer some of those questions sort of backwards.
    I'm an advanced support tech for internet help desks, in other words; I work on out of scope issues that the IHD won't do. Because of that I'm required to know a little bit about most operating systems.
    My desktop is running Win 7 64 bit Home Premium which I use for work, it also has ubuntu and openSuSE installed in dualboots. The laptop has a similar config accept it has 7 32 bit, Ultimate.
    Seems I have made a discovery based on the driver signing.
    Home premium does not appear to have a way to disable enforced driver signing so to my knowledge you would either have to do a selective startup as you suggested earlier removing most functions, or move to the computer with 7 ultimate on it.
    Running the revert from my laptop while I type this on the desktop, cross your fingers
    Revert complete; I'm staring at the fabled blank screen for the new phones, time reread that forum as I forgot most of it already.
    Progress, Yay!!!
  16. Thread Author  Thread Author    #266
    Default
    If you have the energy and want to contribute back, try these drivers on your Win7 Home Premium box and see if they get things working. If they do, I'll update the instructions.
    http://forum.androidcentral.com/lg-o...tml#post786280
    I doubt this would be a priority target for malware but might as well scan it anyway.
  17. #267
    Posts
    ROM
    Drew's CM7 build
    Default
    Lol sry clerical error on my part just checked it i do have the file
    [BOX="dir"]Microsoft Windows [Version 6.1.7601]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C:\Users\Angel>cd \KP500-Utils-EN-v0.4.2
    7 File(s) 100,704,081 bytes
    2 Dir(s) 44,426,108,928 bytes free
    C:\KP500-Utils-EN-v0.4.2>[/BOX]
  18. Thread Author  Thread Author    #268
    Default
    I found your problem.
    Either you weren't in the C:\KP500-Utils-EN-v0.4.2 directory when you ran KP500 or you typed in C:\LS670ZV9.cab as the cab file name in step (n).
    The KP500 log should have said
    17:00:43 : ******Extract Start LS670ZV9.cab*****
  19. Thread Author  Thread Author    #269
    Default
    20:19:56 : ******Extract Start n*****
    You have either typed the wrong filename in step (n) or have a cut/paste error.
    This line in the log file should have said
    20:19:56 : ******Extract Start LS670ZV9.cab*****
    Since it was step (n) and your filename is "n" they are probably related.
  20. Thread Author  Thread Author    #270
    Default
    Quote Originally Posted by rcr0413 View Post
    21:47:32 : ******Extract Start C:\LS670ZVB.SD_12_12.P60675*****
    In step (n), are you sure you typed the correct filename?
    I only have these listed in my post and yours doesn't correspond to any of them. It looks like you took the filename before the renaming and had some typos, VB instead of VD and transposed "_12"s (as best as I can tell you were trying to flash VD based on the rest of the filename)
    n) cab file - LS670ZV9.cab
    Substitute these steps to Force Flash VD
    n) cab file - LS670ZVD.cab
    Substitute these steps to Force Flash VC
    n) cab file - LS670ZVC.cab
    Substitute these steps to Force Flash V8
    n) cab file - LS670ZV8.cab
  21. Thread Author  Thread Author    #271
    Default
    I think that takes care of the rash of file naming problems that cropped up all together recently. I edited the first post to point to these posts so people can check if they entered the correct filename in step (n)
  22. #272
    sblood86's Avatar
    Posts
    ROM
    Quatrimus / CM10
    Default
    Absolutely see if I can get some time tomorrow after work, will post results.
  23. #273
    Default
    "if the LG tool gets stuck at 35% checking the phone model, make sure you are booted into Android and not the Recovery partition."
    ? what recovery is this referring to. I have a stock s that came with vc and i am trying to down grade and then root (then hopefully custom rom)
  24. #274
    Posts
    ROM
    Drew's CM7 build
    Default
    ok but my first attempt looked like this:
    [BOX="first attempt"]16:42:22 : [C:\LGMobileUpgrade] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    16:42:22 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
    16:42:22 : Start Date : 2011-04-17 16:42:22
    16:42:22 : -------- Buyer Test mode ---------
    16:42:22 : [C:\ProgramData\LGMOBILEAX\Phone] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    16:42:22 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
    16:42:22 : *****CheckOS Start********
    16:42:22 : Microsoft_Windows_Vista Home Edition_
    16:42:22 : *****CheckPCSyncPrograms Start*****
    16:42:23 : PCSyncPrograms Not Found
    16:42:23 : SetEmerModeAT()
    16:42:23 : _IsConnectedPhone Call
    16:42:28 : _IsConnectedPhone(1)
    16:42:28 : 0 - NotConnected.
    16:42:28 : 1 - Normal connect success
    16:42:28 : 2 - Emergency connect success
    16:42:52 : Checking the connection with the cell phone...
    16:42:52 : dwWaitResetTime(40000 ms)
    16:42:53 : Phone Mode(1)
    16:42:53 : *****GetPhoneType Start*****
    16:42:55 : Phone Type : CDMA
    16:42:55 : *****Start GetPreviousStep*****
    16:42:55 : _GetPreviousStep(dwStep:0xffff)
    16:45:04 : _SetPhoneNumber retval=1
    16:45:04 : *****GetPhoneModel Start*****
    16:45:06 : *****GetPhoneBinaryVersion Start*****
    16:45:06 : Phone Bin Version : LS670ZVD_12
    16:45:06 : *****Get ESN / IMEI / MEID Start*****
    16:45:09 : ESN/IMEI/MEID : A0000028DFE667
    16:45:09 : *****GetPhoneNumber Start*****
    16:45:12 : Phone Number : A0000028DFE667
    16:45:12 : ÀÎÁõ °Ë»ç ÆÄ¶ó¸ÞŸ - ESN_IMEI : A0000028DFE667, Model :
    16:45:12 : *******CheckBinVersion***************
    16:45:12 : New Bin Version(LS670ZV9_20), Current Ver(LS670ZVD_12)
    16:45:12 : ÃֽйöÀüÀ̹ǷΠ¾÷±×·¹À̵带 ÇÒ Çʿ䰡 ¾øÀ½.
    16:45:14 : _GetAuthMark : wAuthMark(2739)
    16:45:14 : Wait 3Sec
    16:45:20 : _SetAuthMark Ok : wAuthMark(2739), PhoneMode(1)
    16:45:20 : *****Start _GetBatteryLevel*****
    16:45:22 : Battery(5)
    16:45:24 : ResetPhone...
    16:45:24 : Checking the connection with the cell phone...
    16:45:24 : dwWaitResetTime(40000 ms)
    16:45:54 : _IsConnectedPhone Call
    16:45:59 : _IsConnectedPhone(1)
    16:45:59 : 0 - NotConnected.
    16:45:59 : 1 - Normal connect success
    16:45:59 : 2 - Emergency connect success
    16:45:59 : Phone Mode(1)
    16:45:59 : m_dwBootWaitTime(35584)
    16:45:59 : Checking the connection with the cell phone...
    16:45:59 : dwWaitResetTime(30000 ms)
    16:46:29 : _IsConnectedPhone Call
    16:46:35 : _IsConnectedPhone(1)
    16:46:35 : 0 - NotConnected.
    16:46:35 : 1 - Normal connect success
    16:46:35 : 2 - Emergency connect success
    16:46:35 : Phone Mode(1)
    16:46:35 : Call _ModeOffline()
    16:46:36 : *****CheckPCSyncPrograms Start*****
    16:46:36 : PCSyncPrograms Not Found
    16:46:37 : CLGMobileHttp Class ¼Ò¸ê½ÃÀÛ.
    16:46:37 : CLGMobileHttp Class ¼Ò¸ê...
    16:46:37 : ****************CheckAndDownload********************
    16:46:37 : ******Extract Start LS670ZV9.cab*****
    16:46:37 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
    16:46:37 : Extract Error(0)
    16:46:37 : Extract cab file error.
    16:46:37 : [C:\ProgramData\LGMOBILEAX\Phone] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    16:46:37 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
    16:46:37 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
    16:46:37 : Page_Error ºÎºÐÀÔ´Ï´Ù
    16:46:37 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate[/BOX]
    so im still foncused it still is an extract cab error. im going to try redown loading the cab today and try again ... i mean it has to be an error on my part, right?, or the extract of said cab would not go all wonky. wish me luck.
  25. Thread Author  Thread Author    #275
    Default
    Don't take this in a mean tone.
    How would anyone know about your first attempt when you posted only one log prior to this and didn't indicate which attempt it was?
    By posting the first attempt log (rather than a new attempt), I'm assuming you didn't go back and try again after correcting the Nth attempt error I pointed out?
    Have you considered that your first attempt might have been some other type of error, say filename or wrong directory, which you corrected, then subsequently introduced a different step (n) filename entry error, in your Nth attempt, which masked your "fix" for your first attempt?
    My default answer is to say this is something on your side, either the running environment or user error, as this procedure has been run by many people with no issues (that weren't correctable), even someone running it yesterday (after fixing their driver problem). I also reran it yesterday as well, redownloading all the components and installing on a fresh machine. Before you ask, your log file indicates you do not have a driver problem as KP500 communicates properly with the phone prior to getting to the extract file stage.
    BTW you ran a checksum and say it matched (I haven't verified your output). If that is the case, there is no point in redownloading your cab file, it is fine. However if you feel you possibly could have another "clerical" error with the checksum and it might not actually have matched, then it is worth downloading the cab file again.
