[How-to] Revert to LS670V9, after installing OTA LS670VC/VD, using KP500 (Diag mode)
sfhub
2,384
741
You completely skipped the Preface, where you were given a choice to root with stock ZVD or install a custom rom. You chose the custom ROM route.
Yes, it does.
Preface: Determining if you need to revert to LS670ZV9 and/or update to LS670ZVD.
Before you can update from V9/VC to VD, you need to make sure some important steps are followed or else you will have to start all over again. Please follow the steps below.
1) On your LG Optimus S, navigate to Settings->About phone and check the SW Version.
2) If the SW Version is LS670ZV9, you must be rooted to follow these steps.
3) If the SW Version is LS670ZVC, you must be rooted to follow these steps.
If you have LS670ZVC and are NOT rooted, you need to revert to LS670ZV9 first!
4) If the SW Version is LS670ZVD and you DO NOT have a custom recovery kernel, skip to Part 2. If you are unsure which recovery kernel you have, follow Part 1.
5) Install either Xionia Clockwork Recovery or drellisdee's Custom Recovery. Do NOT ask questions about recovery kernel installation in this thread.
6) Using the LG Mobile Support tool, update your device to LS670ZVD. Do NOT ask questions about the LG tool in this thread.
7) If you have Xionia Clockwork Recovery, continue to Part 3 or Part 5.
8) If you have drellisdee's Custom Recovery, continue to Part 4 or Part 6.
9) If you have the stock recovery kernel, you didn't follow the directions and should be slapped.
Table of Contents:
Preface: Determining if you need to revert to ZV9 and/or update to ZVD (EVERYBODY MUST READ THIS!!!)
Part 1: Determining the correct root procedure
Part 2: If you installed LS670ZVD and didn't have a custom recovery kernel
Part 3: If you wish to simply update to the VD radio and run a custom ROM (Xionia Clockwork Recovery)
Part 4: If you wish to simply update to the VD radio and run a custom ROM (drellisdee's Custom Recovery)
Part 5: If you wish to run the stock VD software but also have root access (Xionia Clockwork Recovery)
Part 6: If you wish to run the stock VD software but also have root access (drellisdee's Custom Recovery)
Part 7: Rooting using FlashRootVD-signed.zip (Xionia Clockwork Recovery)
Part 8:
Rooting using FlashRootVD-signed.zip (drellisdee's Custom Recovery)
Part 9:
Extra Notes
Reactions: drewwalton19216801
OCybress
3
Is there any reason why when i flashed the recovery to xionia_cwma_12518.6 and rebooted it when to it just fine. then force flashed VD "phone came with VD installed" back to it i get the normal Recovery and it wont go past the sprint logo screen now .. iv tried reverting back to V9 even VC and it still wont boot into android... yes i read and followed all instructions carefully. i cant get the damned thing to boot..
sfhub
2,384
741
If you can get it to boot into recovery but not Android, then there is likely something corrupted with your /system.
As to how it happened, anyone's guess. With any flashing, something unexpected can happen.
If you only have stock recovery, your only option is to try the unbrick thread
http://forum.androidcentral.com/lg-...s/59781-un-brick-method-some-forms-brick.html
If you have custom recovery, you can try reinstalling custom ROMs and/or restoring nandroid backups.
OCybress
3
Ya iv'e tried the unbrick method there alot but it dosnt seem to get the job done iv flashed all the fw's in e-mode and its still does the same thing. think ima have to call sprint and get a new one.. damn.
ztag100
120
12
Has any one Tested this?
Has anyone with the new display drivers, succesfully rooted? If so, can you please post a link to the thread that gave you directions on how to root?
THANKS FOR CURING MY IGNORANCE :D
joe zack
Active member
Mar 26, 2011
26
lg optimus v9
after rooting and i install the tunderrom -v1.8.3 everything was working except getting airplane mode on and off somrtimes so decided to reset the phone ##786# rtn what ever now my phone is stuck on
android system recovery
didnot try to many option yet waiting for asistance thank you in advance
drewwalton19216801
2,476
2,803
Wait you tried doing a reset with a custom recovery installed? One word: bricked. Not permanently though. I believe using KP500 in emergency mode is the solution here.
EDIT: KP500 is the long way. Use the unroot thread as described in the stickied brick warning.
jparaja
11
Phone will not boot after ZV9
Hi, I reverted to ZV9 from ZVD but, I have no dislpay after running mobile support tool. What can i do to correct this problem?
sfhub
2,384
741
Read the RED warning #2 in the first post. It gives you instructions for reverting with the new LCD. Other than that, the instructions for rooting are the same.
sfhub
2,384
741
I think the airplane mode on/off is done on purpose to reset some cell standby usage info.
##786# will brick your phone when you have custom recovery unless you are using Xionia CWMA (or stock) recovery.
Follow the unbrick thread.
Basically what drew said.
joe zack
Active member
Mar 26, 2011
26
thank you drewwalton19216801 will try to put in emergency and flash it with kp500 let you know for more details thank you in advance
joe zack
Active member
Mar 26, 2011
26
drewwalton19216801..........i tried kp500 this is the log.........but same situation stuck on android system recovery any sugestions thak you
23:22:09 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
23:22:09 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
23:22:09 : Start Date : 2011-04-14 23:22:09
23:22:09 : -------- Buyer Test mode ---------
23:22:09 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\BIN] ???丮 ???? ?õ?
23:22:09 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone] ???丮 ???? ?õ?
23:22:09 : *****CheckOS Start********
23:22:09 : Microsoft_Windows_XP_Professional_
23:22:09 : *****CheckPCSyncPrograms Start*****
23:22:10 : PCSyncPrograms Not Found
23:22:10 : SetEmerModeAT()
23:22:10 : _IsConnectedPhone Call
23:22:15 : _IsConnectedPhone(1)
23:22:15 : 0 - NotConnected.
23:22:15 : 1 - Normal connect success
23:22:15 : 2 - Emergency connect success
23:22:26 : Checking the connection with the cell phone...
23:22:26 : dwWaitResetTime(40000 ms)
23:22:27 : Phone Mode(1)
23:22:27 : *****GetPhoneType Start*****
23:22:30 : Phone Type : CDMA
23:22:30 : *****Start GetPreviousStep*****
23:22:30 : _GetPreviousStep(dwStep:0xffff)
23:22:30 : _SetPhoneNumber retval=1
23:22:30 : *****GetPhoneModel Start*****
23:22:32 : *****GetPhoneBinaryVersion Start*****
23:22:32 : Phone Bin Version : LS670ZV9_20
23:22:32 : *****Get ESN / IMEI / MEID Start*****
23:22:35 : ESN/IMEI/MEID : A0000028A78DC2
23:22:35 : *****GetPhoneNumber Start*****
23:22:37 : Phone Number : A0000028A78DC2
23:22:38 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : A0000028A78DC2, Model :
23:22:38 : *******CheckBinVersion***************
23:22:38 : New Bin Version(LS670ZV9_20), Current Ver(LS670ZV9_20)
23:22:38 : ?ֽ? ?????̹Ƿ? ???׷??̵带 ?? ?ʿ䰡 ????.
23:22:41 : _GetAuthMark : wAuthMark(23752)
23:22:41 : Wait 3Sec
23:22:46 : _SetAuthMark Ok : wAuthMark(23752), PhoneMode(1)
23:22:46 : *****Start _GetBatteryLevel*****
23:22:49 : Battery(5)
23:22:51 : ResetPhone...
23:22:51 : Checking the connection with the cell phone...
23:22:51 : dwWaitResetTime(40000 ms)
23:23:21 : _IsConnectedPhone Call
23:23:26 : _IsConnectedPhone(1)
23:23:26 : 0 - NotConnected.
23:23:26 : 1 - Normal connect success
23:23:26 : 2 - Emergency connect success
23:23:26 : Phone Mode(1)
23:23:26 : m_dwBootWaitTime(35560)
23:23:26 : Checking the connection with the cell phone...
23:23:26 : dwWaitResetTime(30000 ms)
23:23:56 : _IsConnectedPhone Call
23:24:02 : _IsConnectedPhone(1)
23:24:02 : 0 - NotConnected.
23:24:02 : 1 - Normal connect success
23:24:02 : 2 - Emergency connect success
23:24:02 : Phone Mode(1)
23:24:02 : Call _ModeOffline()
23:24:03 : *****CheckPCSyncPrograms Start*****
23:24:03 : PCSyncPrograms Not Found
23:24:04 : CLGMobileHttp Class ?Ҹ????.
23:24:04 : CLGMobileHttp Class ?Ҹ?...
23:24:04 : ****************CheckAndDownload********************
23:24:04 : ******Extract Start LS670ZV9.cab*****
23:24:04 : Model Dll Dir(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\)
23:24:13 : Extracted C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670ZV9_20.S9_20.P60671.wdb\n
23:24:13 : WDB(or DZ) FullPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670ZV9_20.S9_20.P60671.wdb)
23:24:13 : Extracted C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670_W_0_0_2_0.dll\n
23:24:13 : Model dll FullPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670_W_0_0_2_0.dll)
23:24:13 : Extracted C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670ZV9_20.S9_20.P60671.wdh\n
23:24:13 : NNNNN WDB FullPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb)
23:24:13 : NNNNN Model dll FullPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670_W_0_0_2_0.dll)
23:24:13 : Extract End LS670ZV9.cab
23:24:15 : *****WorkModelDLL Start*****
23:24:18 : strPhoneBinaryPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb)
23:24:18 : strModuleDir(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\)
23:24:18 : strModelDLLPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670_W_0_0_2_0.dll)
23:24:18 : m_nPhoneMode(1)
23:24:18 : Phone mode 1 = Normal
23:24:18 : Phone mode 2 = Emergency
23:24:18 : Phone mode 4 = CSE
23:24:18 : _DetachDLL Call
23:24:18 : _DetachDLL Call End
23:24:18 : Call fn_StartUpgrade
23:24:18 : ### Start Upgrade - CDMA ###
23:24:18 : ********* CDMA Model.dll input Parameter *************
23:24:18 : MODEL_EVENT : 32769
23:24:18 : PhoneBinaryPath : C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb
23:24:18 : ModuleDir : C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\
23:24:18 : BootWaitTime : 53340
23:24:18 : UsbHighSpeed : FALSE
23:24:18 : PhoneMode : 1
23:24:18 : NewPhoneBinVersion : LS670ZV9_20
23:24:18 : ClearSI : FALSE
23:24:18 : AuthMark : 23752
23:24:18 : ********* CDMA Model.dll input Parameter End*************
23:24:19 : wParam : 20, lParam = 570
23:24:19 : MODEL DLL Event : (20, 570)
23:24:21 : Model Dll Msg Not Found(20, 570)
23:25:12 : wParam : 4, lParam = 0
23:25:12 : MODEL DLL Event : (4, 0)
23:25:27 : wParam : 5, lParam = 1
23:25:27 : MODEL DLL Event : (5, 1)
23:25:29 : wParam : 5, lParam = 0
23:25:36 : wParam : 5, lParam = 1
23:25:41 : wParam : 5, lParam = 2
23:25:46 : wParam : 5, lParam = 3
23:25:51 : wParam : 5, lParam = 4
23:25:56 : wParam : 5, lParam = 5
23:26:01 : wParam : 5, lParam = 6
23:26:06 : wParam : 5, lParam = 7
23:26:11 : wParam : 5, lParam = 8
23:26:16 : wParam : 5, lParam = 9
23:26:21 : wParam : 20, lParam = 651
23:26:21 : MODEL DLL Event : (20, 651)
23:26:22 : Model Dll Msg Not Found(20, 651)
23:26:22 : wParam : 5, lParam = 10
23:26:27 : wParam : 5, lParam = 11
23:26:32 : wParam : 5, lParam = 12
23:26:37 : wParam : 5, lParam = 13
23:26:42 : wParam : 5, lParam = 14
23:26:47 : wParam : 5, lParam = 15
23:26:52 : wParam : 5, lParam = 16
23:26:57 : wParam : 5, lParam = 17
23:27:02 : wParam : 5, lParam = 18
23:27:07 : wParam : 5, lParam = 19
23:27:13 : wParam : 5, lParam = 20
23:27:18 : wParam : 5, lParam = 21
23:27:23 : wParam : 5, lParam = 22
23:27:28 : wParam : 5, lParam = 23
23:27:33 : wParam : 5, lParam = 24
23:27:38 : wParam : 5, lParam = 25
23:27:43 : wParam : 5, lParam = 26
23:27:48 : wParam : 5, lParam = 27
23:27:53 : wParam : 5, lParam = 28
23:27:58 : wParam : 5, lParam = 29
23:28:03 : wParam : 20, lParam = 529
23:28:03 : MODEL DLL Event : (20, 529)
23:28:04 : Model Dll Msg Not Found(20, 529)
23:28:04 : wParam : 5, lParam = 30
23:28:09 : wParam : 5, lParam = 31
23:28:14 : wParam : 5, lParam = 32
23:28:19 : wParam : 5, lParam = 33
23:28:24 : wParam : 5, lParam = 34
23:28:29 : wParam : 5, lParam = 35
23:28:34 : wParam : 5, lParam = 36
23:28:39 : wParam : 5, lParam = 37
23:28:44 : wParam : 5, lParam = 38
23:28:49 : wParam : 5, lParam = 39
23:28:54 : wParam : 5, lParam = 40
23:28:59 : wParam : 5, lParam = 41
23:29:04 : wParam : 5, lParam = 42
23:29:09 : wParam : 5, lParam = 43
23:29:15 : wParam : 5, lParam = 44
23:29:20 : wParam : 5, lParam = 45
23:29:25 : wParam : 5, lParam = 46
23:29:30 : wParam : 5, lParam = 47
23:29:35 : wParam : 5, lParam = 48
23:29:40 : wParam : 5, lParam = 49
23:29:45 : wParam : 5, lParam = 50
23:29:45 : wParam : 20, lParam = 423
23:29:45 : MODEL DLL Event : (20, 423)
23:29:45 : Model Dll Msg Not Found(20, 423)
23:29:50 : wParam : 5, lParam = 51
23:29:56 : wParam : 5, lParam = 52
23:30:00 : wParam : 5, lParam = 53
23:30:05 : wParam : 5, lParam = 54
23:30:11 : wParam : 5, lParam = 55
23:30:16 : wParam : 5, lParam = 56
23:30:21 : wParam : 5, lParam = 57
23:30:26 : wParam : 5, lParam = 58
23:30:32 : wParam : 5, lParam = 59
23:30:37 : wParam : 5, lParam = 60
23:30:42 : wParam : 5, lParam = 61
23:30:47 : wParam : 5, lParam = 62
23:30:52 : wParam : 5, lParam = 63
23:30:57 : wParam : 5, lParam = 64
23:31:02 : wParam : 5, lParam = 65
23:31:07 : wParam : 5, lParam = 66
23:31:12 : wParam : 5, lParam = 67
23:31:17 : wParam : 5, lParam = 68
23:31:22 : wParam : 5, lParam = 69
23:31:27 : wParam : 20, lParam = 319
23:31:27 : MODEL DLL Event : (20, 319)
23:31:32 : Model Dll Msg Not Found(20, 319)
23:31:32 : wParam : 5, lParam = 70
23:31:37 : wParam : 5, lParam = 71
23:31:42 : wParam : 5, lParam = 72
23:31:47 : wParam : 5, lParam = 73
23:31:52 : wParam : 5, lParam = 74
23:31:57 : wParam : 5, lParam = 75
23:32:02 : wParam : 5, lParam = 76
23:32:08 : wParam : 5, lParam = 77
23:32:13 : wParam : 5, lParam = 78
23:32:18 : wParam : 5, lParam = 79
23:32:23 : wParam : 5, lParam = 80
23:32:28 : wParam : 5, lParam = 81
23:32:34 : wParam : 5, lParam = 82
23:32:38 : wParam : 5, lParam = 83
23:32:43 : wParam : 5, lParam = 84
23:32:48 : wParam : 5, lParam = 85
23:32:53 : wParam : 5, lParam = 86
23:32:58 : wParam : 5, lParam = 87
23:33:03 : wParam : 5, lParam = 88
23:33:08 : wParam : 5, lParam = 89
23:33:13 : wParam : 5, lParam = 90
23:33:18 : wParam : 5, lParam = 91
23:33:23 : wParam : 5, lParam = 92
23:33:28 : wParam : 5, lParam = 93
23:33:34 : wParam : 5, lParam = 94
23:33:39 : wParam : 5, lParam = 95
23:33:44 : wParam : 5, lParam = 96
23:33:49 : wParam : 5, lParam = 97
23:33:54 : wParam : 5, lParam = 98
23:33:59 : wParam : 5, lParam = 99
23:34:04 : wParam : 5, lParam = 100
23:34:04 : wParam : 6, lParam = 0
23:34:04 : MODEL DLL Event : (6, 0)
23:34:31 : wParam : 20, lParam = 110
23:34:31 : MODEL DLL Event : (20, 110)
23:34:32 : Model Dll Msg Not Found(20, 110)
23:34:32 : wParam : 8, lParam = 0
23:34:32 : MODEL DLL Event : (8, 0)
23:35:29 : wParam : 10, lParam = 1
23:35:29 : MODEL DLL Event : (10, 1)
23:35:30 : wParam : 10, lParam = 2
23:35:30 : wParam : 10, lParam = 4
23:35:30 : wParam : 10, lParam = 6
23:35:30 : wParam : 10, lParam = 8
23:35:30 : wParam : 10, lParam = 10
23:35:30 : wParam : 10, lParam = 12
23:35:30 : wParam : 10, lParam = 14
23:35:30 : wParam : 10, lParam = 16
23:35:30 : wParam : 10, lParam = 18
23:35:30 : wParam : 10, lParam = 20
23:35:30 : wParam : 10, lParam = 22
23:35:30 : wParam : 10, lParam = 24
23:35:30 : wParam : 10, lParam = 26
23:35:30 : wParam : 10, lParam = 28
23:35:30 : wParam : 10, lParam = 30
23:35:30 : wParam : 10, lParam = 32
23:35:31 : wParam : 10, lParam = 34
23:35:31 : wParam : 10, lParam = 36
23:35:31 : wParam : 10, lParam = 38
23:35:31 : wParam : 10, lParam = 40
23:35:31 : wParam : 10, lParam = 42
23:35:31 : wParam : 10, lParam = 44
23:35:31 : wParam : 10, lParam = 46
23:35:31 : wParam : 10, lParam = 48
23:35:31 : wParam : 10, lParam = 50
23:35:31 : wParam : 10, lParam = 52
23:35:32 : wParam : 10, lParam = 54
23:35:32 : wParam : 10, lParam = 56
23:35:32 : wParam : 10, lParam = 58
23:35:32 : wParam : 10, lParam = 60
23:35:32 : wParam : 10, lParam = 62
23:35:32 : wParam : 10, lParam = 64
23:35:32 : wParam : 10, lParam = 66
23:35:32 : wParam : 10, lParam = 68
23:35:32 : wParam : 10, lParam = 70
23:35:32 : wParam : 10, lParam = 72
23:35:33 : wParam : 10, lParam = 74
23:35:33 : wParam : 10, lParam = 76
23:35:33 : wParam : 10, lParam = 78
23:35:33 : wParam : 10, lParam = 80
23:35:33 : wParam : 10, lParam = 82
23:35:33 : wParam : 10, lParam = 84
23:35:33 : wParam : 10, lParam = 86
23:35:33 : wParam : 10, lParam = 88
23:35:33 : wParam : 10, lParam = 90
23:35:33 : wParam : 10, lParam = 92
23:35:34 : wParam : 10, lParam = 94
23:35:34 : wParam : 10, lParam = 96
23:35:34 : wParam : 10, lParam = 98
23:35:34 : wParam : 10, lParam = 100
23:35:34 : wParam : 20, lParam = 0
23:35:34 : MODEL DLL Event : (20, 0)
23:35:35 : Model Dll Msg Not Found(20, 0)
23:35:35 : wParam : 12, lParam = 1
23:35:35 : MODEL DLL Event : (12, 1)
23:35:36 : CLGMobileHttp Class ?Ҹ????.
23:35:36 : CLGMobileHttp Class ?Ҹ?...
23:35:36 : CleanModelDll() : Free Model.dll
23:35:36 : _DetachDLL Call
23:35:36 : _DetachDLL Call End
23:35:36 : FreeLibrary Call
23:35:38 : FreeLibrary Call End
23:35:40 : Step : S/W Upgrade Complete!
Dorion-Grey
61
Help me please ???
I am trying to download the kp500 winzip keeps telling me not a proper archive if you downloaded this file please redowload..... im a noob this is frusterating me cause im proble doing something stupidly wrong.
sfhub
2,384
741
Many people have downloaded and not had any issue. I just downloaded and windows default zip handling opens it fine.
Must be something specific to your setup.
Try shift-click download and save to disk, then open up with windows default zip handling or with 7-zip (7-Zip)
sfhub
2,384
741
Do you have a custom recovery? Can you start an adb shell session?
Also, you didn't flash in emergency mode. You flashed in normal mode. So I wouldn't consider that a real attempt at emergency mode flashing. If you want to try it again, read the unbrick thread.
joe zack
Active member
Mar 26, 2011
26
i want to thank mr drewwalton19216801 ,sfhub and all the guys in the forum for helping now the phone is back to original sprint carrier working normaly...here what i did..1st i upgraded with lgupgrade forun choosing lgls670 model.............after that wipe and flash with pk-500 follow the instructions on the 1st page ,,,,,,,,,,,but thank you again all.......................
samreen
4
Force flash back to previous version... will this work ??
i simply want to know after the version upgrade i lost hotspot capability in my phone, so force flash back to previous version procedure that here "http://forum.androidcentral.com/lg-optimus-s/43409-how-wireless-tether-vd.html" will give me the ability to use hotspot again??? and do i need rooting or just force flash back will be good enough and at what stage should i stop from that page.... i'm sorry i'm kinda new to all this and don't want to mess up my phone thats why i'm seeking your help.. i really appreciate you help... thanks... Jen
sfhub
2,384
741
Follow the revert instructions in my signature. You can revert to V9 or VC, both support hotspot. If your unit came with VC then you must revert to VC or your screen will be blank. If your unit came with something earlier than VC, then you have the option of V9 or VC. V9's advantage is it is easier to root in the future. VCs advantage is it fixed the SD card mounting problem which affected some SD cards.
The revert instructions are geared to revert to V9. If you want to revert to VC, look in the reference section (of the revert thread) for the couple substitutions to flash VC instead.
Skip step (u) as it seems you have no need to root or install custom ROMs.
