Page 7 of 22 FirstFirst ... 45678910 ... LastLast
Results 151 to 175 of 532
Like Tree2Likes
  1. #151
    cmyasika1's Avatar
    Posts
    ROM
    ThunderRom V1.5/[OC Kerne
    Default
    now when I started again its hanging at 95%. What do I do?
  2. Thread Author  Thread Author    #152
    Default
    Did your phone reboot yet? Post the log.
    Don't reboot the phone if the process is hung and you see the updating screen on the phone.
    Better to restart the flash process. When it can't see your phone, unplug/plug your phone in and hit restart. It should go into emergency mode.
    [How-To] Rooting LS670ZVH
    Installed ZVH by mistake? Use simple update.zip to revert to ZVD / Froyo
  3. #153
    cmyasika1's Avatar
    Posts
    ROM
    Default
    Quote Originally Posted by sfhub View Post
    yes it did.
    21:51:58 : [C:\LGMobileUpgrade] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    21:51:58 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
    21:51:58 : Start Date : 2011-03-21 21:51:58
    21:51:58 : -------- Buyer Test mode ---------
    21:51:58 : [C:\ProgramData\LGMOBILEAX\Phone] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    21:51:58 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
    21:51:58 : *****CheckOS Start********
    21:51:58 : Microsoft_Windows_Vista Home Edition_
    21:51:58 : *****CheckPCSyncPrograms Start*****
    21:51:58 : PCSyncPrograms Not Found
    21:51:58 : SetEmerModeAT()
    21:51:58 : _IsConnectedPhone Call
    21:52:04 : _IsConnectedPhone(1)
    21:52:04 : 0 - NotConnected.
    21:52:04 : 1 - Normal connect success
    21:52:04 : 2 - Emergency connect success
    21:52:26 : Checking the connection with the cell phone...
    21:52:26 : dwWaitResetTime(40000 ms)
    21:52:27 : Phone Mode(1)
    21:52:27 : *****GetPhoneType Start*****
    21:52:29 : Phone Type : CDMA
    21:52:29 : *****Start GetPreviousStep*****
    21:52:29 : _GetPreviousStep(dwStep:0x4)
    21:52:29 : *****GetPhoneModel Start*****
    21:52:31 : *****GetPhoneBinaryVersion Start*****
    21:52:31 : Phone Bin Version : LS670ZVD_12
    21:52:31 : *****Get ESN / IMEI / MEID Start*****
    21:52:34 : ESN/IMEI/MEID : A0000028502193
    21:52:34 : *****GetPhoneNumber Start*****
    21:52:37 : Phone Number : A0000028502193
    21:52:37 : ÀÎÁõ °Ë»ç ÆÄ¶ó¸ÞŸ - ESN_IMEI : A0000028502193, Model :
    21:52:40 : _GetAuthMark : wAuthMark(18598)
    21:52:40 : Wait 3Sec
    21:52:46 : _SetAuthMark Ok : wAuthMark(18598), PhoneMode(1)
    21:52:46 : *****Start _GetBatteryLevel*****
    21:52:48 : Battery(5)
    21:52:53 : ResetPhone...
    21:52:53 : Checking the connection with the cell phone...
    21:52:53 : dwWaitResetTime(40000 ms)
    21:53:23 : _IsConnectedPhone Call
    21:53:29 : _IsConnectedPhone(1)
    21:53:29 : 0 - NotConnected.
    21:53:29 : 1 - Normal connect success
    21:53:29 : 2 - Emergency connect success
    21:53:29 : Phone Mode(1)
    21:53:29 : m_dwBootWaitTime(35630)
    21:53:29 : Checking the connection with the cell phone...
    21:53:29 : dwWaitResetTime(30000 ms)
    21:53:59 : _IsConnectedPhone Call
    21:54:04 : _IsConnectedPhone(1)
    21:54:04 : 0 - NotConnected.
    21:54:04 : 1 - Normal connect success
    21:54:04 : 2 - Emergency connect success
    21:54:04 : Phone Mode(1)
    21:54:04 : Call _ModeOffline()
  4. Thread Author  Thread Author    #154
    Default
    Quote Originally Posted by cmyasika1 View Post
    yes it did.
    So your phone is booted into Android right now? Look at the software version in settings->about phone.
    If it says ZV9 you are probably ok.
    However, your log file doesn't look like it wrote to the phone at all. In that case, I'd just start the process again.
    If your phone isn't booted into Android and instead is in the Software Downloading screen, then do not restart the phone, only restart the flashing software.
    You can press ctrl-c in the KP500 command prompt to get it to stop.
  5. #155
    Default HELP! Just updated phone to LS670ZVD and I only have a MAC.
    So I have been thinking about rooting my optimus S, because the low storage space warning is getting EXTREMELY annoying and I find myself having to constantly remove apps I want just to get rid of it.
    Anyway, I've never read anything about rooting and then I come on here today because I can't put up with having that message one more time. And I see I apparently am screwed because I did the update the other day, not having read about the fact it would make my phone unrootable. I found directions showing that you can go backwards and the KP500, but my problem is I use a MAC and don't have bootcamp or anything that will run windows programs, so I'm really not sure how or even if it's possible to get my phone back to the previous version so that I can root my phone and also get my hotspot working.
    Any thoughts or help would be greatly appreciated. Thanks
  6. #156
    Default
    Download VirtualBox and install a copy of Windows on it.
    Windows will run for 30 days without being activated, so you should have plenty of time to fix your phone.
  7. #157
    Default
    Microsoft Windows XP [Version 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\Robert>cd c:\kp500-utils-en-v0.4.2
    C:\KP500-Utils-EN-v0.4.2>ren LS670ZV9_20.S9_20.P60671.cab LS670ZV9.cab
    C:\KP500-Utils-EN-v0.4.2>dir
    Volume in drive C has no label.
    Volume Serial Number is 18FB-9E40
    Directory of C:\KP500-Utils-EN-v0.4.2
    03/23/2011 10:05 PM <DIR> .
    03/23/2011 10:05 PM <DIR> ..
    03/03/2007 09:02 PM 344,064 fsum.exe
    11/14/2008 01:56 PM 155,648 Inf_WebDnld.dll
    08/18/2009 03:49 PM 424,960 KP500-Utils-EN.exe
    08/03/2009 01:15 PM 86,016 LGMobileDL.dll
    08/03/2009 01:15 PM 450,560 LGMUpgradeDL.dll
    03/23/2011 10:04 PM 99,220,700 LS670ZV9.cab
    02/11/2007 03:37 PM 22,133 ReadMe.txt
    7 File(s) 100,704,081 bytes
    2 Dir(s) 27,968,184,320 bytes free
    C:\KP500-Utils-EN-v0.4.2>KP500-Utils-EN.exe
    | ! LG-Utils V0.4.2 ! |
    | KP500 |
    | By Blackhorn for |
    | NO WARANTY |
    | USE AT YOUR OWN RISK |
    Menu
    A - Send ROOT partition on mobile phone
    B - BACKUP ROOT partition on mobile phone
    C - Send CUST partition on mobile phone
    D - Backup CUST partition on mobile phone
    E - Send USER partition on mobile phone
    F - Backup USER partition on mobile phone
    G - Extract CUST partition from .DFAT
    H - Extract files from a WDB file
    I - Extract files from a KDZ file
    J - Flash with assistant (file .cab)
    M - Extended /!\
    N - Send STATIC_EEP partition on mobile phone
    O - Backup STATIC_EEP partition on mobile phone
    P - Unlock /!\
    Q - Exit
    Choice: j
    Phone Model (Ex: KP500): ls670
    File (.CAB) including the firmware (Ex: C:\V10G_04.cab): ls670zv9.cab
    Version(SW version) (Ex: V10G_04): ls670zv9_20
    Send the arguments...
    Loading...
    Log from the updater below
    21:56:04 : [C:\LGMobileUpgrade] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    21:56:04 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
    21:56:04 : Start Date : 2011-03-23 21:56:04
    21:56:04 : -------- Buyer Test mode ---------
    21:56:04 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    21:56:04 : RemoveDirectory1 Error(2):C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone
    21:56:04 : *****CheckOS Start********
    21:56:04 : Microsoft_Windows_XP_Home Edition_
    21:56:04 : *****CheckPCSyncPrograms Start*****
    21:56:04 : PCSyncPrograms Not Found
    21:56:04 : SetEmerModeAT()
    21:56:04 : _IsConnectedPhone Call
    21:56:04 : _IsConnectedPhone(0)
    21:56:04 : 0 - NotConnected.
    21:56:04 : 1 - Normal connect success
    21:56:04 : 2 - Emergency connect success
    21:56:07 : Checking the connection with the cell phone...
    21:56:07 : dwWaitResetTime(40000 ms)
    21:56:08 : _IsConnectedPhone Call
    21:56:08 : _IsConnectedPhone(0)
    21:56:08 : 0 - NotConnected.
    21:56:08 : 1 - Normal connect success
    21:56:08 : 2 - Emergency connect success
    21:56:09 : _IsConnectedPhone Call
    21:56:09 : _IsConnectedPhone(0)
    21:56:09 : 0 - NotConnected.
    21:56:09 : 1 - Normal connect success
    21:56:09 : 2 - Emergency connect success
    21:56:10 : _IsConnectedPhone Call
    21:56:10 : _IsConnectedPhone(0)
    21:56:10 : 0 - NotConnected.
    21:56:10 : 1 - Normal connect success
    21:56:10 : 2 - Emergency connect success
    21:56:10 : [009,400,102,102,102]The USB cable and your cellphone are not connected.\nPlease connect your phone and wait for connecting \nthe USB port for a while and press the [009,700,147,062,092]'Restart'[009,400,102,102,102] button.
    21:56:40 : _IsConnectedPhone Call
    21:56:40 : _IsConnectedPhone(0)
    21:56:40 : 0 - NotConnected.
    21:56:40 : 1 - Normal connect success
    21:56:40 : 2 - Emergency connect success
    21:56:40 : [009,400,102,102,102]The USB cable and your cellphone are not connected.\nPlease connect your phone and wait for connecting \nthe USB port for a while and press the [009,700,147,062,092]'Restart'[009,400,102,102,102] button.
    21:56:43 : _IsConnectedPhone Call
    21:56:43 : _IsConnectedPhone(0)
    21:56:43 : 0 - NotConnected.
    21:56:43 : 1 - Normal connect success
    21:56:43 : 2 - Emergency connect success
    21:56:43 : [009,400,102,102,102]The USB cable and your cellphone are not connected.\nPlease connect your phone and wait for connecting \nthe USB port for a while and press the [009,700,147,062,092]'Restart'[009,400,102,102,102] button.
    21:59:54 : Check Cancel button active..
    21:59:54 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
    21:59:54 : Page_Error ºÎºÐÀÔ´Ï´Ù
    21:59:54 : [011,700,147,062,092]LG Mobile Phone Software Update was canceled\n\n[009,400,102,102,102]To quit LG Mobile Phone Software Update, please press the [009,700,147,062,092]Exit[009,400,102,102,102] button below.
    21:59:54 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
    *I am able to get to the lg update step but no matter what I do it refuses to read the phone. It is connected it just won't read it for some reason. I already had my phone flashed but I accidently reset it to factory settings so I'm trying to reflash it and it just isn't cooperating. Any help would be GREATLY appreciated.*
  8. Thread Author  Thread Author    #158
    Default
    Did you make sure USB debugging is enabled?
    Does the phone or PC make any sounds when you plug in the phone?
    Under start menu->run
    devmgmt.msc
    Do you see anything listed under Modems that looks like Android USB modem?
  9. #159
    Thumbs up sfhub - THANK YOU!!!
    Thank you for taking the time to share this with us. I lost my Hot Spot with the VD upate (last time I trust sprintusers.com to warn me about an update). I clicked the Thank You in your signature, but thought I would post one as well. Your time and energy are very much appreciated.
  10. #160
    Default
    devmgmt.msc
    Yes it beeps at me when it's unplugged and plugged in. And yes USB debugging is enabled. And yes LGE android platform usb modem is under modems.
  11. Thread Author  Thread Author    #161
    Default
    Quote Originally Posted by chunkywaffle View Post
    The only time I had problems like you describe is when I started clearing out registry entries for LG USB devices. I didn't take the time to figure out what was broken as I had recently installed the LG software and just system restored to an earlier date.
    I'm sure after one knows the cause it wouldn't be that difficult to fix, but perhaps the quickest way to get it working would be to try a different PC. If you don't want to do that, you could try deinstalling the software/drivers and reinstalling. I'll assume you've already rebooted the PC.
  12. Thread Author  Thread Author    #162
    Default
    Quote Originally Posted by Cat88Extreme View Post
    Glad you got your phone back to the configuration you wanted.
  13. #163
    Default
    After set O
    I keep getting a LG ??? S/W Upgrade error that reads
    C:documents and settings\all users\application Data\LGMobilEAX\image\header_bg.gif was not found
    Any idea what i am doing wrong
  14. #164
    Default
    Quote Originally Posted by randy74 View Post
    After set O
    I had this problem. KP500 expects image and language files in C:documents and settings\all users\application Data\LGMobilEAX\. However, it does not place them there - you need to install the LG Updater program first - that install process puts them there. Then when you run KP500, it can use those files.
    My company blocked the install of the LG Mobile Updater, so when I tried to use KP500 instead, I got the same errors you see. I ended up finding the files online and could manually place them where KP500 expects them. My only problem was that I could only find a foreign lang.opt file to put in the Language folder, so I had to use Google Translate during my install to find out what I was being told to do. Hopefully you can figure out an easier solution.
  15. #165
    Default
    Mine kept doing this until I check my Devices and Printers and noticed the phone was showing up with an error. I had windows attempt to solve the problem and it said I didn't have the driver needed installed for my device. I then realized I hadn't added the driver when I installed and started the LG Updater. Make sure you open the updator and install the driver for our phone.
  16. Thread Author  Thread Author    #166
    Default
    After set O
    Did you install LG Mobile Update Tool?
    EDIT: Sorry, I'm too slow. Someone already answered your question.
  17. #167
    Default
    thanks for the help guys that was part of the problem but I was still getting that error but it would at least start after I did what you said so I ended up deleting everything and starting from scratch and I apparently did something wrong because it worked like a dream after I started all over ..... thanks again for your help guys
    Randy
  18. #168
    Default
    hello anybody have any info on reverting to v9 using a mac
    thx
  19. #169
    Default
    Quote Originally Posted by crey1961 View Post
    thx
    Can't be done without using Windows, at least in a virtual machine and even then it's hit and miss. Best bet is to borrow a friend's Windows machine for a half hour.
  20. #170
    Default
    I used the instructions at the beginning of this thread, and was able to revert to V9- thanks so much!
    Also, to get rid of the update notification, I waited for the pop up that said "Update Now, Update Later, and More Info." I clicked "More Info", then shut off the phone, pulled the battery, replaced it, and turned it back on. Did this last night, and the notification hasn't come back- yay! I have my hotpsot back, and the notification is gone.
    Thanked by:
    pauak
  21. #171
    josh.burns44's Avatar
    Posts
    ROM
    reborn/ testing burn rom
    Default
    what do you mean "place in same file as (e)" for the v9 cab?
  22. Thread Author  Thread Author    #172
    Default
    Quote Originally Posted by josh.burns44 View Post
    It didn't say "same file as (e)", it said "same folder as (e)", meaning place the cab file in:
  23. #173
    Default
    I can't get this to work, I've tried at a dozen times. Here's the log, the phone resets itself without any warning at the 64% mark and then errors out at the end.
    12:11:40 : [C:\LGMobileUpgrade] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    12:11:40 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
    12:11:40 : Start Date : 2011-03-27 12:11:40
    12:11:40 : -------- Buyer Test mode ---------
    12:11:40 : [C:\ProgramData\LGMOBILEAX\Phone] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    12:11:40 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
    12:11:40 : *****CheckOS Start********
    12:11:40 : Microsoft_Windows_Vista Home Edition_
    12:11:40 : *****CheckPCSyncPrograms Start*****
    12:11:40 : PCSyncPrograms Not Found
    12:11:40 : SetEmerModeAT()
    12:11:40 : _IsConnectedPhone Call
    12:11:46 : _IsConnectedPhone(1)
    12:11:46 : 0 - NotConnected.
    12:11:46 : 1 - Normal connect success
    12:11:46 : 2 - Emergency connect success
    12:11:47 : ***** Port => 3
    12:11:47 : Checking the connection with the cell phone...
    12:11:47 : dwWaitResetTime(40000 ms)
    12:11:48 : Phone Mode(1)
    12:11:48 : *****GetPhoneType Start*****
    12:11:51 : Phone Type : CDMA
    12:11:51 : *****Start GetPreviousStep*****
    12:11:51 : _GetPreviousStep(dwStep:0xffff)
    12:11:51 : _SetPhoneNumber retval=1
    12:11:51 : *****GetPhoneModel Start*****
    12:11:54 : Phone Model : LG-LS670
    12:11:54 : *****GetPhoneBinaryVersion Start*****
    12:11:54 : Phone Bin Version : LS670ZVD_12
    12:11:54 : *****Get ESN / IMEI / MEID Start*****
    12:11:56 : ESN/IMEI/MEID : A0000028B2B170
    12:11:56 : *****GetPhoneNumber Start*****
    12:11:59 : Phone Number : A0000028B2B170
    12:12:00 : ÀÎÁõ °Ë»ç ÆÄ¶ó¸ÞŸ - ESN_IMEI : A0000028B2B170, Model : LG-LS670
    12:12:00 : *******CheckBinVersion***************
    12:12:00 : New Bin Version(LS670ZV9_20), Current Ver(LS670ZVD_12)
    12:12:00 : ÃֽйöÀüÀ̹ǷΠ¾÷±×·¹À̵带 ÇÒ Çʿ䰡 ¾øÀ½.
    12:12:02 : _GetAuthMark : wAuthMark(14313)
    12:12:02 : Wait 3Sec
    12:12:08 : _SetAuthMark Ok : wAuthMark(14313), PhoneMode(1)
    12:12:08 : *****Start _GetBatteryLevel*****
    12:12:10 : Battery(5)
    12:12:12 : ResetPhone...
    12:12:12 : Checking the connection with the cell phone...
    12:12:12 : dwWaitResetTime(40000 ms)
    12:12:42 : _IsConnectedPhone Call
    12:12:47 : _IsConnectedPhone(1)
    12:12:47 : 0 - NotConnected.
    12:12:47 : 1 - Normal connect success
    12:12:47 : 2 - Emergency connect success
    12:12:47 : Phone Mode(1)
    12:12:47 : m_dwBootWaitTime(35516)
    12:12:47 : Checking the connection with the cell phone...
    12:12:47 : dwWaitResetTime(30000 ms)
    12:13:17 : _IsConnectedPhone Call
    12:13:23 : _IsConnectedPhone(1)
    12:13:23 : 0 - NotConnected.
    12:13:23 : 1 - Normal connect success
    12:13:23 : 2 - Emergency connect success
    12:13:23 : Phone Mode(1)
    12:13:23 : Call _ModeOffline()
    12:13:24 : *****CheckPCSyncPrograms Start*****
    12:13:25 : PCSyncPrograms Not Found
    12:13:26 : CLGMobileHttp Class ¼Ò¸ê½ÃÀÛ.
    12:13:26 : CLGMobileHttp Class ¼Ò¸ê...
    12:13:26 : ****************CheckAndDownload********************
    12:13:26 : ******Extract Start LS670ZV9.cab*****
    12:13:26 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
    12:13:26 : ExtractInfo Error(0)
    12:13:26 : Extract cab file error.
    12:13:26 : [C:\ProgramData\LGMOBILEAX\Phone] µð·ºÅ丮 »èÁ¦ ½Ãµµ
    12:13:26 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
    12:13:26 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
    12:13:26 : Page_Error ºÎºÐÀÔ´Ï´Ù
    12:13:26 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
    Any ideas? I really need my WiFi Hotspot back for work
    Thanks,
    Michael
  24. #174
    drewwalton19216801's Avatar
    Posts
    ROM
    HydroROM
    Default
    Quote Originally Posted by rorymadstudios View Post
    Generally this error means you didn't rename the file correctly. Can you please post the output of
    dir C:\wherever\you\put\kp500
    Obviously change the path above to your particular path
    Thanked by:
  25. #175
    Default
    Quote Originally Posted by drewwalton19216801 View Post
    My path is
    c:\KP500-Utils-EN-v0.4.2
    Which is where the 5 files are located, I'm running the program in XP Compatibility mode on my Windows 7 machine.
    Should it not be that? (this is my first time trying to do anything like this with a cell phone/smart phone so you'll have to excuse some dumb questions, I'll probably ask a few of them LOL)
    Thanks,
    Michael
