1. og_president's Avatar
    I tried using it on CM7, Bbut it seems not to work. Do any of you run it on CM7?
    Swyped from my LS670 using Tapatalk
    04-07-2011 10:43 AM
  2. ltrz's Avatar
    What exactly are you having trouble with...does it keep FC. Or you can use it but don't see any battery improvement? ..... I'm on cm7 (most current) and no issue with using juice
    04-07-2011 04:04 PM
  3. tirith's Avatar
    I'll install it now, since i have juicedefender and ultimate juice in "my apps" - I'll let you know if it works for me...
    (using zefie's scott pilgrim cm7 nightly build)
    EDIT: Downloaded, says mobile network data *might not* work on gingerbread build, but I havent tweaked the settings and actually tried it yet
    Looks different than the old screen - when did they update it? I go to "customize" and get errors.... and no choices on what to enable or disable....
    EDIT EDIT: I have it up and running now. Seems to be working
    EDIT EDIT EDIT: Phone rebooted for no reason..... (was looking at "Status" tab and went to go into "Controls" tab, and LG Splash menu came up - seems to be in endless reboot cycle....)
    04-07-2011 04:36 PM
  4. ws1088's Avatar
    you should signup for their beta to get the latest build for gingerbread.
    04-07-2011 05:51 PM
  5. tirith's Avatar
    They have the beta right there listed in the market.
    04-07-2011 06:04 PM
  6. ws1088's Avatar
    they have beta of beta consider it nightly build of the to be release of a newer beta.
    I tried the latest "nightly" and it works well with CM7
    04-07-2011 06:50 PM
  7. tirith's Avatar
    Juicedefender with Ultimate Juice worked well for me, for about 5 minutes... then phone crashed, went into reboot loop...
    managed to get lucky and hurridly uninstalled juicedefender (and all related apks) from my phone... I might try the beta and hopefully get no problems.
    thats just my exp though..
    04-07-2011 06:54 PM
  8. og_president's Avatar
    It would never turn the data off, but now that I am runnimg the "nightly"; it works
    Thanks everyone
    Swyped from my Gingerbread'ed Optimus S
    04-10-2011 12:07 PM
