1. minhle619's Avatar
    does anyone know how to root a lg optimus s on a mac?
    06-08-2011 05:38 PM
  2. mrinehart93's Avatar
    Just download Z4Root. It's available in the Amazon App Store or the Android Market.
    06-08-2011 05:59 PM
  3. O.a.T.'s Avatar
    I believe z4root no longer works on zvc and later versions. Also, I think the gingersnap capability is being updated to work on the mac. You don't know anyone with a PC?
    06-08-2011 06:24 PM
  4. Hoverbot's Avatar
    A PC isn't needed for rooting, or applying a custom recovery.
    I always have the developer tools installed so it may or may not be needed but you just have to download the android sdk, extract, and double click on android inside the tools folder, and then install the sdk tools. Then the unrooting instructions are followed pretty much the same.
    If needed I can probably write it up.
    I would be really unhappy if I ended up with a phone that I couldn't mess around with under OS X.
    06-09-2011 07:36 AM
  5. the_maplebar's Avatar
    I followed the Gingerbreak guide on linux. Should be similar for the Mac. All of the steps for rooting are from the ADB (Android SDK).
    The part that will be different for Mac/Linux is the initial setup before you start rooting.
    • You have to get the Android SDK setup (Windows .exe is included in the zip)
    • You have to get the SDK installed and working from the command line
    • You have to make sure the ADB finds your phone when it's connected
    After those 3 steps are completed on any OS, just follow the guide with the ADB shell commands
    06-09-2011 10:09 AM
  6. ritzcrax's Avatar
    Hoverbot
    a write up would be great!
    06-09-2011 12:11 PM
