what i have done so far:
1) I have root permissions
2) I have a rom on my sd card
3) I have a recovery image
but when i boot into recovery there is no option for install rom
so I reboot into recovery and the only options shown to me
the options it gives me are:
1. reboot system now
2. apply sdcard.update.zip (this does nothing when i try it says nothing is found on the card although it obviously is)
3. wipe data/factory reset
4. wipe cache partition
i suspect im using the wrong recovery image
because in the videos i watched the user had alot more options then 4
could some1 plz point me in the direction of a more useful recovery image
