Results 1 to 3 of 3
    Default HELP!!!!!! OTA Update Rooted Optimus
    I installed the OTA update for gingerbread on my rooted LG Optimus S i forgot to unroot is there anything i can do to help me its stuck at LG screen please i dont have money to replace a phone. Any help is greatly appreciated. Please let me know if i Perma-bricked my phone
  2. #2
    Catfish's Avatar
    Posts
    ROM
    CM7 Nightly
    Default Re: HELP!!!!!! OTA Update Rooted Optimus
    I'm sure you haven't perma bricked your phone, but I would suggest you post your problem in the
    http://forums.androidcentral.com/lg-...ng-roms-hacks/
  3. #3
    reboot into recovery and run restore.....then you have to install the stock v9 recovery and then you can install the update and re-root but you are probably stuck with the stock recovery. I did the same thing, tried the update and got stuck. ran the recovery and now i have 2.3.3 and its rooted and all good. check http://forums.androidcentral.com/lg-...-ls670zvh.html
