04-04-2012 11:18 PM
38 12
tools
  1. atylene's Avatar
    i have bricked my sprint lg marquee trying to falsh custom fonts with rom manager. it is stuck on boot screen and wont do crap. finally got message after repeatedly pushing home button that says cant mount sd card HELP
    03-23-2012 04:43 AM
  2. Buddlespit's Avatar
    You may have more luck here: http://forums.androidcentral.com/sprint-lg-marquee/
    03-23-2012 05:44 AM
  3. traxxasBandit's Avatar
    Whoop whooooooooooooo! (: I fixed it! Thank you to everybody for your help. If anyone needs it I would be sure to return the favor!
    03-27-2012 11:50 PM
  4. hlxanthus's Avatar
    Dude, if you could do a write up of what all you did. There isn't a good definitive rom manager snafu guide.
    We are always glad to help, but we do get tired of trying to help rom mangler bricks and lord knows there are alot of them.
    If you don't want to do a true guide, no prob. Give us a list of what exactly was wrong, what worked and what did not. Myself or someone else can turn it into a help guide. That rom manager sticky is of very little help to fix the problem.
    03-28-2012 09:11 AM
  5. traxxasBandit's Avatar
    I think it would be a great idea to make a guide . Just..... where should i start??
    03-28-2012 09:22 PM
  6. traxxasBandit's Avatar
    Awwwwww Snap! bricked the phone again LOL. But this time i wanted to see what the "LG style factory reset" would do lol badddd idea. my phone went all crazy and sh**. now i have the android recovery and it just does a fastboot. And when i turn it on its the setup wizard but i press the android guy and nothing happpens.
    03-30-2012 01:20 PM
  7. hlxanthus's Avatar
    Wow, I must say I am impressed. You did BOTH of the biggest Optimus s no-no's lol !!!
    Just pull you battery, boot to recovery and perform a wipe date/factory reset from recovery. That should fix you.
    03-30-2012 03:33 PM
  8. traxxasBandit's Avatar
    Well, ladies and gentlemen i have succesfully bricked my optimus s every thinkable way.....BUT iv found a way to unbrick it every time! . I will soon do a guide or something on how to unbrick a optimus s. It might take a while though, as thier are many ways to brick it, but i have the unbrick method for every one! Tested and up to date.
    03-31-2012 03:42 PM
  9. hlxanthus's Avatar
    Sweet! Congrats
    03-31-2012 03:58 PM
  10. traxxasBandit's Avatar
    LOLOLOLOLOLOLOLOL!!!!!!! i tried to force flash ZV9 HA! REALLY REALLY BAAAADDD IDEA
    03-31-2012 04:45 PM
  11. hlxanthus's Avatar
    ummm.. . ... Okay
    03-31-2012 10:54 PM
  12. traxxasBandit's Avatar
    ummm.. . ... Okay
    Yah haha nevermind. Lol my phones back to normal. Except swype beta wont work >
    04-01-2012 02:29 AM
  13. gollum18's Avatar
    Since no one mentioned both ways you bricked your opti s have been stickied on the rooting, roms , and hacks sections of the forum just for future reference you might want to look at them. So it doesn't happen again.
    04-04-2012 11:18 PM
38 12
