1. grayem's Avatar
    I want a clock that is not part of Androids clock. My old "feature" phone had a clock I could set the exact time of day even if it was wrong, not just based on location or atomic time.
    My wife is a military pilot and goes places that have no network of any kind to sync to. She looked at me like I was nuts when I started to show her clocksync. She can describe very complicated avionics systems - hydraulics - electronics - hi freq radios, etc. but for some reason she hates fooling with these things.
    All she needs is a clock that she can manually set the time when she is overseas. It does not need to be synced
    What is available, I have searched, but there are floods of clock widgets clogging up the market. Searching is pretty much worthless.
    Any ideas?
    07-28-2012 05:49 PM
  2. Kuplex's Avatar
    Can you not just change the phone setting to not sync? That's how mine is set. If I set it wrong, it stays wrong. Or do you need another clock while leaving the system clock alone?
    07-28-2012 06:33 PM
  3. Zhara's Avatar
    This. You can go to 'Date & Time' in settings and uncheck 'automatic date & time' and 'automatic time zone' and put in whatever you want, which will change the lock screen and status bar clocks.
    I'm not sure if a widget would go by that or if they do their own thing though...never tried it.
    07-28-2012 07:08 PM
  4. grayem's Avatar
    This does allow you to unsync, but you cannot correct the time on the clock. If the battery is removed the clock gets messed up and there is no way to fix it without syncing it. If you are in Kyrgestan
    without Wi-Fi your normally useful phone becomes a battery holder.
    Ideally google would just make it easier to set your own clock an leave the date correct withing.
    07-29-2012 12:04 AM
  5. William Apel's Avatar
    Yeah I think it would work if you change the phone setting to not sync. One of my friends was looking for the same. I will ask him and let you know what he has done. Between, great to know that your wife has good knowledge about hydraulic systems and electronics.
    02-22-2014 12:16 AM
