Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Like Tree1Likes
  1. Thread Author  Thread Author    #26
    Starcanball's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Please help me! I need this done fast and in the morning at 6
    Quote Originally Posted by hlxanthus View Post
    Can you get into any kind of android right now?
    Sent from my Nexus S 4G using Tapatalk 2
    I can use my little brother's LG Viper if necessary
  2. Thread Author  Thread Author    #27
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Please anyone,
    Is there anything I can try. I'm desperate now. I will get a custom ROM, kernel, etc just to get my phone on and working. Last time I flashed a ROM iI had no connection whatsoever. No phone number, carrier, or signal was ever available. So I have to be careful with the ROM selection. Please? Any suggestions are welcome.
  3. #28
    koeylondon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    DanteROM(w/Hydro)/CAI CM9
    OK, since you have a working recovery for your device, you need to load a custom ROM. Try these in order:
    ZVJ ROM (Dante)
    ZVD (Quatt)
    One or the other will get signal and such. That will help determine your baseband. Note that you don't need to flash GApps on Dante, but you will need to do so on Quatt to get access to the Play store.
    Do that, and let us know what happens.
    Note: You can load them onto your SD card from Recovery under "Mounts." Simply press "Mount USB Storage" while your phone is plugged in and it SHOULD pop up as a drive.
    Starcanball likes this.
  4. Thread Author  Thread Author    #29
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by koeylondon View Post
    ZVJ ROM (Dante)
    ZVD (Quatt)
    DanteRom won't install on my phone. I got the LG Optimus S driver software installed but then when I went to install DanteRom from TWRP it said install successful even without the md5 file. I tried to wipe cache/dalvik (successful) and hit reboot after I hit the back menu and it loaded right back into TWRP. Is there anither recovery I could try? Maybe this one is not compatible with my phone? I cant install gapps on Quatt so i didnt attempt it.
  5. #30
    hlxanthus's Avatar
    Posts
    Global Posts
    1,793 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    RasbeanJelly/DanteRom v4
    You can try this http://db.tt/xnGZbJHs.
    It is xionia, just tucked it into a flashable version.
    Sent from my Full Android on Crespo4G using Tapatalk 2
  6. Thread Author  Thread Author    #31
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is what happens when I try to install it through TWRP
    (Status 2)
    Error flashing zip '/sdcard/Xion
    Updating partition details...
    Imstalling '/sdcard/Xionia_CWMA_1
    (Status 2)
    Failed
  7. #32
    koeylondon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Interesting. I wonder if you're stuck in a recovery boot loop. Try COT (NOTE: I couldn't find a forum post, and I hope Drew isn't mad. Remember: You are responsible for what you do to your device). and look under "advanced" for "fix recovery boot loop" and see if that helps. It's one of the best recoveries out there, and should work on your device.
  8. Thread Author  Thread Author    #33
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It still won't install. Nothing is installing properly on TWRP because it will say "successful" on install but then when I go to reboot it, it just goes right back into recovery, as did CWM. Are there certain settings or precautions/guidlines I should use/follow before trying to install it on TWRP?
  9. Thread Author  Thread Author    #34
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What is COT and how do I flash it through TWRP? I'm not sure but I think TWRP just made flashing a recovery/ROM worse and/or harder.
  10. #35
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,029 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    You have to flash a recovery through ADB.
  11. Thread Author  Thread Author    #36
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by cole2kb View Post
    I tried to install adb and it didnt work.
  12. Thread Author  Thread Author    #37
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Okay new question. I am about to go to Sprint to get my phone fixed. What should I say happened to my phone that made it boot back into a custom recovery after I reset it? I dont want them to think I re-rooted it!
  13. #38
    klokateer123's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by Starcanball View Post
    If you have your custom recovery still they're gonna know it's rooted most likely.
    Sent from my LS670 using Android Central Forums
  14. #39
    Scrabbleloozer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Before you go to Sprint send an email to this guy.....www.qbking77.com he might be able to help you.
    Sent from my ASUS Transformer Pad TF700T using Android Central Forums
  15. #40
    hlxanthus's Avatar
    Posts
    Global Posts
    1,793 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default Please help me! I need this done fast and in the morning at 6
    I assume since you said you were about to go to sprint, this is going to come to late. The truth is, unless sprint has changed thier policy recently, it is not against policy to root thier devices. It is frowned apon but they will work on them. The service techs are not dummies and most likely root themselves (the ones I know do LOL). Just be honest but not forthcoming if you catch my drift. Tell them what's wrong. Hope it goes/went well and let us know!
  16. #41
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    even if they charge you to fix it it's gotta be cheaper than buying a new phone.
  17. #42
    hlxanthus's Avatar
    Posts
    Global Posts
    1,793 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    At sprint, if you take it into service if you dont have the extended warrenty the worst case is $35 for the repair or a refurb. Heck, if they can fix on site it is usually free.
  18. Thread Author  Thread Author    #43
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you to everyone for all the responses! I have made sure to thankeveryone and the repair will be free or I can just get a free new one because of my mom's insurance. Thank you and have a nice night everyone!
  19. Thread Author  Thread Author    #44
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Okay nevermind. I went to the Sprint store and they aren't allowed to touch rooted phones anymore. The guy showed me how to do it and he said it would surely work, but it didn't. Here's the link
    How to Root and Unroot LG Optimus S LS670
  1. Can anyone please help me out with this?
    By Sting23ray in forum Droid Bionic
    Last Post: 09-10-2011, 12:03 AM
  2. Please help me find this one game??
    By KMfiremedic111 in forum Android Games
    Last Post: 01-22-2011, 07:59 PM
  3. Replies: 3
    Last Post: 01-19-2011, 02:41 AM
  4. Can someone PLEASE help me with this wallpaper issue?
    By King Neptune117 in forum Motorola Droid X
    Last Post: 01-14-2011, 08:08 AM
  5. Can anyone help me listen to this website please?
    By seone in forum Verizon Droid Incredible
    Last Post: 11-02-2010, 12:25 AM
