DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 4 of 4
    Default i NEED HELP!!!!
    my phone is saying that my sd card is blank or that it has unsupported filesystem. when i try to hook it up to my pc it says their is a problem using your sd card for mass storage. i have also tried using a card reader and that didnt work either. everytime i try and format the sd card it doesnt work it just pops up and say that the sd card is currently being checked then it stops trying to format it. i dont really want to lose everything that is on it but if i have to i will.anybody have any ideas???
  2. #2
    Default Re: i NEED HELP!!!!
    Any ideas? Yes. Do backups of your SD card more often because it sounds like yours went bad and you are screwed.
    Thanked by:
  3. #3
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Paranoid Android / CM7
    When did this problem occur? What has changed?
    What format did you use on it?
    Backups are key. I have had 2 SD card failures in the last 12 months: 1 after 10 months; the other after only one month.
    If you are inclined to spend a lot of money and want a pretty trophy with which to pass the next few years of your life that talks to you in a condescending voice, can't navigate to save its life, expects full control over all you do, demands $13 for a $3 purchase, allegedly has a single recessed button, needs an expensive computer and a credit card to do anything, hates your music and has purses designed just for it...
    Get married to someone you hate... or get an iPhone.
    New to LG's premium Android phone? Check out the Optimus S Welcome Guide.
    Used ROM Mangler on your Optimus S and having problems? Try this.
    It happened yesterday right after I dropped my phone. And I just used the phones formatting thing and it didn't work
    Sent from my LS670 using Android Central Forums
  1. New to Android phone and need help
    By ntapia82 in forum Samsung Moment
    Last Post: 04-26-2010, 05:40 PM
  2. Android Rookie with the HTC Hero I need help!!!!
    By bigrich34 in forum HTC Hero
    Last Post: 10-14-2009, 12:15 PM
  3. getting started, need help !
    By android for dummy in forum General Help and How To
    Last Post: 09-24-2009, 08:28 AM
  4. Need help regarding my google search bar on my g1
    By wabbit3119 in forum General Help and How To
    Last Post: 09-01-2009, 04:41 PM
  5. need help please
    By jfchica1987 in forum T-Mobile G1
    Last Post: 06-16-2009, 02:12 PM
