Starting a few days ago, my screen goes almost monochrome and blurry. I can still make things out well enough to use the phone but it is annoying. It seems to be happening more frequently each day. A reboot always fixes the problem. I have been using 2.3.3 DanteRom v4 for several months now. Could this be Rom related or is it likely a hardware issue? If you think I should try a different Rom, which would you recommend? Thanks.
