Help with screen randomly becoming corrupted
jklhill
4
Starting a few days ago, my screen goes almost monochrome and blurry. I can still make things out well enough to use the phone but it is annoying. It seems to be happening more frequently each day. A reboot always fixes the problem. I have been using 2.3.3 DanteRom v4 for several months now. Could this be Rom related or is it likely a hardware issue? If you think I should try a different Rom, which would you recommend? Thanks.
jklhill
4
Wow! 270 views and not a single reply? Thanks for looking, anyway. I think I found the answer myself so I'll post it here in case someone else runs across the same problem. I had installed Skype a few days ago. That seems to have been causing the problem. I uninstalled Skype this morning and the problem has not reappeared. I'm glad it was that simple.
Eclipse2K
5,722
107
Thank you for posting your solution. Skype has never done that to me but I have noticed it hasn't run optimal as of late.
Samsung Galaxy Note 3 (Verizon)
tivativa
