KSmithInNY
#winning
Memory Card mount/unmount:
I have been paying really close attention since this thread and mine has not done it all day. Before it would do it CONSTANTLY (maybe 10x's a day). I'm thinking the formatting helped. I formatted mine the good old fashion way with gparted using my PC. I did not (nor would I) recommend using the default Android format SDcard option. Put the SDCard into your computer and use windows partition manager or gparted or whatever else to format that baby with FAT32. Make sure you copy all contents off the card first, then just copy back after formatting.
Please format your card in the way i state above and report back.
Almost 600 views on this thread, several people saying they are having the problem, a potential fix that worked beautifully for me, and not a single other person that tried it and reported back?
