Mine is very loud and annoying. Any way to silence it or turn it off?
uva silent widget is a no-go. camera gets locked out, force close on all instances.
Sent from my Optimus via Tapatalk
I havent tried smart measure yet but silentcam = stoneage_quality_pix.There are many apps in the market you can try , for instance this app has high reviews but costs .99cents
Smart Measure Pro - Android app on AppBrain
or if you want to try another free one
SilentCam - Android app on AppBrain
try a couple out see what works for you
for kicks I also tried 1 or 2 private-type apps that just kill all volume in general (silent mode). but I could just as well use the vol buttons on the side too, minus the footprint. maybe the rom chefs can cook up something for a future update, this should be accessible from the camera app settings imho.
