1. nickg105's Avatar
    Hey everyone, I'm new here so I apologize if any of this has been covered already.
    Anyway, I'm having some trouble using JuiceDefender Free with my Optimus S. I would really prefer not to have to dump the app because it improves my battery life DRASTICALLY and I don't want to have to change that. But the app seems to randomly turn my data completely off and it won't reset unless I turn the phone off and back on again. And this morning it took 3-4 tries just to get my 3G to work with the app turned on. This seems to happen frequently after coming off the charger and I'm not quite sure what to do. Should I turn JuiceDefender off while charging? I'm running the default profile, btw.
    Thanks.
    03-01-2011 10:38 AM
  2. hamagc's Avatar
    Try setting up a custom profile and play with the settings. I haven't run into that issue at all.
    03-01-2011 12:33 PM
  3. mr.longbough's Avatar
    I used to have juice defender but if I manually manage data gps wifi and keep bluetooth off I get better battery life.just get a 3g widget and turn off data when not in use
    03-01-2011 02:23 PM
  4. chardog's Avatar
    dump juice defender, and run wifi when possible. disable gps, and enable them as needed.
    http://forum.androidcentral.com/lg-o...tery-life.html
    03-01-2011 03:14 PM
  5. ocellaris's Avatar
    I have better battery life after dumping Juice Defender. I use Quick Settings and just turn off GPS and data when I am not using them. I keep a short cut to Quick Setting on my home screen and just pull it up as needed. I use Wifi whenever I can as well, and texts and calls still come through with data off. I have gone 48+ hours on my phone without battery problems.
    03-01-2011 03:36 PM
  6. Queueyou's Avatar
    I had the same issue with JuiceDefender, sadly, I bought the app, and this newest version (the ui redone) has screwed the 3g stuff for me like what your describing. I took it off, however, before that, if you turn on and off airplane mode, it seemed to clear up the 3g issue (it was either that, or enable/disable 3g but one of those two works to get it back w/o reboot).
    03-01-2011 04:58 PM
  7. uberjam545's Avatar
    that used to happen to me and i use to just turn juice defender off until 3g came up then i would turn it back on. I got it to work normally by downloading a different one that was some kind of beta that so far has been working better for me then the normal one.
    Queueyou likes this.
    03-03-2011 08:11 PM
