Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By xbballbrandon23x
    xbballbrandon23x's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy Lg optimus s sound doesnt work. Only sound through headphone jack
    So Im in love with my phone. But im having a problem I plugged headphones in yesterday and now my headphones just slide in and out. No sound works on my phone untill i plug in something into the headphone jack. Then sound only works through the jack. Im not sure what to do No sound works on my phone at all. Should I just take it in.
    duffkitty likes this.
  2. #2
    tirith's Avatar
    Resident Linux Fiend
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Touchwiz LJC 4.1.1
    Default
    Taking it in would probably be the best option...
    Is the headphone icon indicated in the notification bar even when you don't have anything plugged into the headphone jack?
  3. #3
    O.a.T.'s Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Customized GB.
    Default
    Quote Originally Posted by xbballbrandon23x View Post
    Did you try powering it down/up? Always a good thing to try when strangeness happens.
  4. #4
    mr.longbough's Avatar
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Nameles v1
    Default
    If you haven't taken it in yet try blowing it out with compressed air. Might be dust or debris.
  5. #5
    trekkie1701c's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM10
    Default
    Had a similar issue on my old Palm Zire 31, and it was fixed by a full wipe.
    I've also heard that oil on the headphone jack can work, though I've never tried it.
  6. #6
    zefie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CyanogenMod 9
    Default
    the fact you say it just 'slides in and out' sounds like a mechanical failure in the headphone jack. The sensor tab that activates when a jack in plugged in sounds like it is jammed, thus no resistance inserting and removing the headphones, as well as no sound (it thinks they are still in)
    Either way it is a hardware issue and if it did this without abuse then it is up to Sprint or LG to make it right.
  7. #7
    scifan's Avatar
    Posts
    Global Posts
    423 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ZVD/ICE CM9 Alpha
    Default
    Hmmm... that's NOT good... that's similar to the headphone jack problem that resulted in 6 replacement palm Pre's...
  8. #8
    gnarshred's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Wanted to jump in and share my experiences. I have the optimus v. same thing happened after only a few weeks of ownership. Looking on the internet, I have found that this is a pretty common problem on all of the optimus models. I have tried everything. Power on/off, battery pull, full restore (even reloading from SD card...)
    Would really like more ideas, but I feel like I have done everything in my power... Is there anything I could do to completely reload the OS? (I thought thats what I did when I used the SD recovery) Seems like a completely fresh start could be a good move. Next move is going back to Best Buy, but we all know that is going to be a chore...
  9. #9
    jefboyardee's Avatar
    Posts
    Global Posts
    222 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    That jack has what they call normalling, a spring device that physically connects normal speaker audio when nothing is plugged in and disconnects speaker feed when headphones are plugged in. If the contacts become dirty, it can result in the problem you’re describing. My guess is you spilled something in there and mucked up the contacts...
  10. #10
    skife's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    stock
    Default
    Quote Originally Posted by jefboyardee View Post
    That jack has what they call normalling, a spring device that physically connects normal speaker audio when nothing is plugged in and disconnects speaker feed when headphones are plugged in. If the contacts become dirty, it can result in the problem youre describing. My guess is you spilled something in there and mucked up the contacts...
    not nessicarly spilled something in there. It was a really common problem with the PRE's like someone earlier in this thread said.
    a quick solution is using an old tooth brush dip it in rubbing alcohol and stick the bristles down the headphone jack and twist it around and try to clean it out the best you can. followed by spraying some duster down there to get everything out. (watch your eyes while doing this)
    usually fixed the pre's for awhile.
  11. #11
    asassinkid2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Lg optimus s sound doesnt work. Only sound through headphone
    I've tried everything in this forum and nothing has worked I am going to try to take my phone up to the store tomorrow
  12. #12
    Sillub's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Lg optimus s sound doesnt work. Only sound through headphone jack
    MY LG VS985 4G has a similar issue. It has a weird icon on the top like a symbol to plug a speaker into my phone. The speaker on my phone works, but I cannot hear through the normal ear speaker. Why is this happening?
  13. #13
    TJS69's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My LG Destiny LG121G has no sound, and if you press on that small icon it says "Turn off all sounds" is on. I cannot figure out how to turn that off. Where you should be able to adjust the Volume in settings, "Volume" is shown in a dim text that you cannot highlight (select). This just started happening today. Yesterday I couldn't answer phone when called ! I think it may be a software issue. - Tom
  14. #14
    Shirette Flowers's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tirith View Post
