Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By blackops1125
    Thumbs down Is there anyway to turn off that annoying low battery warning?
    It is so annoying I can't stand it. Thanks, Stacey
  2. #2
    blackops1125's Avatar
    Advisor
    Posts
    Default
    You could always charge the battery.
    sent from my Reborn Optimus
    thenameisnigel likes this.
  3. #3
    Default Re: Is there anyway to turn off that annoying low battery warning
    Quote Originally Posted by blackops1125 View Post
    gah you beat me to it. I usually dont let my phone get so low, but do you mean the popup telling you to charge or the sound it makes?
    Yes that beeping sound. Can it be disabled?
  5. #5
    Quote Originally Posted by stacell72 View Post
    Are you rooted, and on what Rom?
    You can simply rename LowBattery.ogg to LowBattery.ogg.bak and it won't sound when it gets low. The popup will still show.
  6. #6
    hlxanthus's Avatar
    Posts
    Global Posts
    1,793 Global Posts
    Carrier
    RasbeanJelly/DanteRom v4
    Default
    Could you also replace it with some thing less obnoxious?
    Sent from my Optimus S using Tapatalk
  7. #7
    sblood86's Avatar
    Posts
    Carrier
    Quatrimus / CM10
    Quote Originally Posted by hlxanthus View Post
    Yes you could, as long as the file is .ogg and has the same name, than it's just a matter of deleting the old one and copying the new one in
  8. #8
    hlxanthus's Avatar
    Posts
    Global Posts
    1,793 Global Posts
    Carrier
    Default
    Quote Originally Posted by sblood86 View Post
    Okay, I thought that was a good idea. I tried to do it with file manager. Which of course would not let me move a new .ogg file over to the ui folder. Is there a preferred method of this?
  9. #9
    sblood86's Avatar
    Posts
    Carrier
    Quatrimus / CM10
    A root explorer of some sort should work, or you could also push the file using adb
    adb push file_name /path/to/put/file
    obviously the above example uses entirely false file names and directories
  10. #10
    use estrongs file manager and select root and HIAPK, then mount system. it's free and does the job.
  11. #11
    Default Re: Is there anyway to turn off that annoying low battery warning?
    O.m.f.g. I do realllllyyyy in HATE IT tooooo!!!!!
  12. #12
    hkll's Avatar
    Posts
    Your going to have to search for a mod to your phone, or some sort of script to add to your phone, but if your not too tech savvy, you might be stuck with it
    Sent from my LS670 using Android Central Forums
  13. #13
    Thumbs up Re: Is there anyway to turn off that annoying low battery warning?
    There is an application for that:
    https://play.google.com/store/apps/d....silentbattery
    You do not need to "root" or "jailbreak" your phone to use this app.
    It will work directly, on any smartphone.
  14. #14
    Thumbs up Solution
  15. #15
    On my Nexus 5, I get this annoying pop up that seems randomly set at 14 percent. Its a new phone so I know I never set it as I wouldnt set it at such an odd number anyway. I use my own apps and have my own battery information and alerts. I cant find any setting to disable it - Theres no settings in the battery section on the phone to begin with
    My phone isnt rooted and Im not going to...Its pretty annoying that thats the answer to every Android problem. I had a similar issue iwth the Galaxy Nexus so I dont konw if its some default built in feature. I just find 14 percent to be such an odd number to choose.
  16. #16
    jakeuten's Avatar
    Posts
    Global Posts
    56 Global Posts
    No, it's there for a reason
  17. #17
    Cool Re: Is there anyway to turn off that annoying low battery warning?
    Sorry Guys but I expect more from Android.
    The beep or bleep isn't the whole answer to my problem. Bought a brand new LG G3, which is great by the way, but as a user, I don't need to be reminded on everything that time flies. Especially on battery. I need the whole ;package to be removed from my device. I don't want my smartphone dim the display or anything else, I need it to work 100% until the battery dies. It takes only 90min, to charge back to 100% so waiting is just a matter of managing time during that 90min. but that annoying popup and beep is a stressor we don't need.
    So Who is able to find a Android solution to remove that problem from my LG G3 ?
    *.ogg don't work for me either. Couldn't find the LowBattery.ogg and I don't want to start playing with the root on my brand new phone.
  18. #18
    bigsupersquid's Avatar
    o_O
    Posts
    Carrier
    bigsuperROM_os2sd
    Quote Originally Posted by YoubiTheGreat View Post
    need the g3 forum, this is optimus s.
  19. #19
    You know what, this is obviously unhelpful, get off the internet and stay away.
