1. lillie jackson's Avatar
    It's also known as LU2300. Anyways, I got the phone yesterday, activated it and everything. I got home last night (I don't have service at home, I live in the middle of nowhere) turned on my wifi connection, and my internet and everything worked awesomely. Then I woke up this morning, and it says that there is no connection, though it is, in fact, connected, it shows full bars for my wifi. It's weird because it will go on youtube, and my browser works, to an extent, but it won't let me go to the market, or play any games that require a connection. I've tried turning my phone on and off, turning my wifi on and off, and restarting my router, I don't know what to do.
    11-21-2011 03:19 PM
  2. primetechv2's Avatar
    It might be saying No Connection simply because you're without a mobile network connection. I don't know if wifi counts. Toggle Airplane Mode (via the power button) and call a doctor in the morning if the problem persists.
    Welcome to Android. You can save a lot of juice by turning Airplane Mode on when you take your phone into a place with no signal.
    Sent from my LG-VM701 using Tapatalk
    11-27-2011 02:02 AM
  3. bhayden1994's Avatar
    SAME HERE. its got to be the most frustrating thing ever. Did you figure out how to fix it?
    12-27-2011 12:29 PM
  4. rick358's Avatar
    I was having the same problem. The solution was to change the WiFi sleep setting. I asked this question on another forum and the solution was in the Wireless & networks>wi-fi settings>menu>advanced>wi-fi sleep policy>never. This will lower the battery time some.
    12-31-2011 12:15 AM
  5. jcole20's Avatar
    LG L55C = Straight Talk/Net10 "LG Optimus Q"
    LU2300 = Much NICER Korean LG
    I have no clue why they chose to use the same name in two countries. You may find certain forums that say LG Optimus Q2... this is also not the Straight Talk/Net10 LG Optimus Q.
    They're completely different phones.
    As to your question... IF you have your Google Account setup in the phone, you should see the status bar and/or the wifi signal turn green when its synced with google. IME, if it doesn't turn green pretty quick I'm not synced and therefore do not have a signal. "Forget" the router you're using in Wireless settings and then reload it using your router password. Try again.
    01-11-2012 01:19 AM
  6. dinah_smiley's Avatar
    I am trying to download the drivers for the OQ. I have tried all the ones I could find but none work. You guys all seem to have moved past this point. Could you please point me in the right direction to the straight talk lg OQ drivers? Please please please.
    01-30-2012 06:18 PM
  7. jcole20's Avatar
    You're in the wrong section you should be in the virgin mobile optimus slider section, but go to lgs website and download their mobile support tool and you want the drivers for the l55c. Also delete/uninstall any drivers you've already installed prior first.
    Sent from my LGL55C using Tapatalk
    01-31-2012 10:47 AM
  8. ccinthecountry's Avatar
    Hi Rick358,
    Can you please tell me how you got to the wi-fi sleep policy on your phone? I have an LG Optimus Q and I'm desperately trying to connect to my work's wi-fi network with it. I show connected but can't make calls. I can't find 'menu' under my wi-fi settings... Thanks!
    03-20-2012 10:48 AM
  9. Dennison Brillo's Avatar
    I tried changing the wifi sleep settings it worked till I turned off the phone doing factory reset now.
    05-24-2012 10:54 PM
  10. jcole20's Avatar
    Lol wtf
    05-24-2012 11:50 PM
  11. krisjerran's Avatar
    I had a problem with the Wifi showing connected, but no actual connection. There seems to be a problem with the wi-fi driver on this phone (the LFL55C) getting stuck. The workaround I use is a free app in the Play Store called Wifi Fixer. It detects when the Wifi is turned on and intermittently pings the gateway to see if the connection is functional. If it gets no reply, it resets the connection. Since I've installed it I've almost never had a noticeable problem with my WiFi connection.
    tiffanymarch likes this.
    05-26-2012 01:19 PM
  12. tiffanymarch's Avatar
    Yesterday when I first woke up my phone was connected to wifi and it was working fine. When I left my bedroom and came downstairs to the living room it stopped working. It says that it is connected but the status bar is not turning green and nothing will work (browser, facebook, textplus app). I wanted to download the wifi fixer to see if it will work but how am I supposed to download anything when the wifi isnt working? I'm on my computer right now and it is connected to the same wifi signal and it is working. Can anybody help me figure out what the problem is???????
    06-15-2012 04:48 PM
  13. jcole20's Avatar
    Lol use the 3g to download it and toggle ur wifi on and off. Don't just leave it.
    06-15-2012 07:21 PM
  14. April wynn2007's Avatar
    Ok my phone has service it has 3 bars but when I call someone it gose to 0 bars and tells me I lost call
    06-04-2013 11:32 AM
