Results 1 to 4 of 4
    Default LG Optimus Q Wifi Connection Help
    Hello I have just received a new phone, straight talk Android LG Optimus Q. So this is what happens when I try to connect to Wifi:
    1. I select the wifi I want to use
    2. It authenticates it
    3. Then it gets disabled, and I have to reconnect. And it does that over and over. It won't stay connected to the wifi. What do I do to fix this? I've searched around for a solution and can't find one.
  2. #2
    Default Re: LG Optimus Q Wifi Connection Help
    Welcome to Android Central! Check out this guide, and see if any of the tips help: [GUIDE] Troubleshooting Wi-Fi Connection Problems. If not, then let us know!
    In my house I have two wi-fi's. One wi-fi has a password you enter before you can get a connection, and the other one is like a guest hotel password, with a password once you use the browser. I can connect to this hotel like wifi. However, it bothers me a lot that I can't connect to the normal wifi. We don't have any problems with it right now, and it was happening at another wifi spot as well. From the troubleshooting guide I can't see what would be wrong though.
    And thank you as well! That did help to get connected to the guest wifi
  4. #4
    That's interesting--I've never seen a personal wifi network have a login webpage for sign in. I wonder if that setup might be confusing the device.
    Have you tried playing around with the router security settings as well? You could temporarily disable the router security to see if that's the root cause. If you can connect, then there's something about your security settings that isn't agreeing with your device.
  1. WTS: Verizon LG G2 White - Mint
    By willstilson in forum The Marketplace - Buy, Sell & Trade
    Last Post: 02-06-2014, 07:58 PM
  2. help. screen broked !!
    By lucianoxxx in forum Moto X
    Last Post: 12-29-2013, 03:01 PM
  3. Galaxy s4 wifi/data connection issues
    By hardrocker89 in forum Sprint Samsung Galaxy S4
    Last Post: 12-27-2013, 11:06 PM
  4. Help With Dashclock
    By TheTeapot35 in forum Google Nexus 4
    Last Post: 12-27-2013, 06:11 PM
  5. *HELP: no voicemail after installing dialer and visual voicemail app
    By rob damiani in forum General Help and How To
    Last Post: 12-27-2013, 05:12 PM
B
