Results 1 to 3 of 3
    OKH
    OKH is offline
    OKH's Avatar
    Posts
    Global Posts
    3 Global Posts
    Default Metro PCS F3/Motochopper issue
    I tried to root my F3 using Motochopper and it appeared to have gone well. I have the SU app (# icon) in my drawer however I get an error message "The superuser binary (su) must be updated" I'm offered two update options, neither of which work. I try to reinstall and get:
    2335 KB/s (1283460 bytes in 0.536s)[*] Pushing root tools...
    2819 KB/s (91980 bytes in 0.031s)
    2695 KB/s (1867568 bytes in 0.676s)
    2716 KB/s (969701 bytes in 0.348s)
    pkg: /data/local/tmp/Superuser.apk
    Failure [INSTALL_FAILED_ALREADY_EXISTS][*] Rooting phone...
    [+] This may take a few minutes.
    [-] Failure.[*] Cleaning up...[*] Exploit complete. Press enter to reboot and exit.
    The phone is unlocked, fwiw. I'm new to Android and am dead out of ideas. Any help would be greatly appreciated.
    Thanks!
  2. #2
    Default Re: Metro PCS F3/Motochopper issue
    Sorry no one can think of an answer. There's the #android chat room on irc on Freenode, though forums are generally better. Have you tried the XDA developers forums?
  3. #3
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default
    Quote Originally Posted by OKH View Post
    Thanks!
    When given the option to update. One tells you to update with TWRP/CWM. You need to have root access turned on in developer options within your settings. Set it to apps and adb.
    Then it will reboot into recovery and update from there
  1. Moto X - Apps randomly crashing, lock screen issues
    By nisecal in forum Moto X (2013)
    Last Post: 10-07-2015, 01:10 PM
  2. issue with VIBER on Galaxy S3
    By soso2565 in forum AT&T Galaxy S3
    Last Post: 01-20-2014, 11:43 AM
  3. Textra issue
    By Annie Droid in forum General Help and How To
    Last Post: 01-20-2014, 08:33 AM
  4. Wifi issue
    By deadlypepperpot in forum General Help and How To
    Last Post: 01-20-2014, 05:55 AM
  5. Galaxy Tab 2 10.1 Possible Battery Issue
    By jeffgravis in forum Samsung Galaxy Tab 2 10.1
    Last Post: 01-20-2014, 01:23 AM
